• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
PSE version 6 won't recognise dng files
Community Beginner ,
Sep 22, 2017 Sep 22, 2017
I use PSE 6 and have the adobe dng converter so I can convert the Sony ARW files from my A350 dslr. It has worked well without problems. I recently upgraded my camera to a Sony A68 and whilst the ARW files from that camera convert to dng format in the converter, PSE 6 tells me it cannot open the dng file as it is the wrong type of file, but it still opens dng files converted from the old A350. Is there a work round to this?
Views
679
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
You don't say which version of DNG converter? You can download the up to date version from one of the links below:
Get the latest DNG Converter Mac  | Win
Votes
Translate
Translate
Report
Report
Sorry, forgot to add I'd downloaded the latest version 9.12.1.790 of DNG converter as I thought the reason I was having problems was an older version. It converted the ARW files to dng but PSE6 still wouldn't recognise them.
Votes
Translate
Translate
Report
Report
LEGEND ,
I can’t think why the DNGs are not recognised. Have the files been processed using Sony or third party software?
Votes
Translate
Translate
Report
Report
Sep 23, 2017 Sep 23, 2017
No Jon, just downloaded onto my computer and converted in the dng converter as I've always been doing. To re-iterate, RAW files from my A350 convert readily to dng format and are then read by PSE6 . When I first tried to convert the RAW files from the new A68 the DNG converter didn't recognise the, so I updated the converter and the files were then recognised, and then converted but PSE6 still refused to recognise them.
Votes
Translate
Translate
Report
Report
Community Expert ,
What operating system are you using?
You probably have camera raw 4.6 or earlier in your pse 6.
You can check by going to Help>About Plug-In>Camera Raw (windows) or Photoshop Elements>About Plug-In>Camera Raw (mac).
Up date to camera raw 5.6 and then the dngs should open in pse 6.
windows
Adobe - Photoshop Elements : For Windows : Camera Raw 5.6 update
mac
Adobe - Photoshop Elements : For Macintosh : Camera Raw 5.6 update
sample image from here
Sony A68 Review - Sample Images | PhotographyBLOG
Votes
Translate
Translate
Report
Report
Hi Jeff. DNG files converted from my Sony A350 RAWs already open in PSE6. I was wondering why the DNG files converted from the A68 would be any different. Are there different types of DNG file? btw Camera RAW 5.5 seems to be the latest update for PSE6. 5.6 seems to be for PSE8. (I'm thinking of giving in to progress and buying PSE15 which will open all my Sony RAWs direct without having to convert them to DNG format.)
Votes
Translate
Translate
Report
Report
Community Expert ,
The 5.6 version listed on the updates page works in pse 6 even though it's under pse 8.
Since the Sony A68 is newer, it has more specs that need to be supported in dngs converted from newer cameras
and are not always supported in older camera raw plugins.
One can however set the Compatibility mode of the converter so the dngs work with older camera raw versions.
In your case setting the Compatibility mode to 4.1 and newer before converting the Sony A68 files should enable
them to open in pse 6 without updating the camera raw plugin, but the file size will be much bigger than if you
update pse 6 to the camera raw 5.6 plugin and leave the Compatibility Mode at the Default 7.1 and newer when
converting the files.
Votes
Translate
Translate
Report
Report
LATEST
Thanks Jeff. The older versions already work. I currently have it set to 7.1 and later. That said, I've removed PSE6 now and downloaded PSE15  so it's no longer a problem.
Votes
Translate
Translate
Report
Report
