1 Reply Latest reply on Aug 12, 2008 1:13 AM by dietmar.paulus
    Writing to an xml file
    Ludo99 Level 1
      I have an xml file that I use to populate a dataGrid in a flex application.
      Is it possible to update the xml file - for example; use a Form component to add a new record?
      Thanks.
        • 1. Re: Writing to an xml file
          dietmar.paulus Level 1
          Hey with Flex and FlashPlayer 9 it is not possible to save or change a file (expcept SharedObjects) locally without downloading, due to security restrictions. With AIR you can. You also can send data to a server, save the file on the server and then download it with the FileReference Class.
          With the new FlashPlayer 10 you have the abbility to save files through the FileRefereceClass.
          Cheers
          Dietmar
