Hi
I get the "There was an error opening this document, the network path can not be found" when i try to open a .pdf on a file share.
I have tried the latest version of adobe reader and also the 2nd latest but its the same error.
Word and any other documents works fine.
Ive tried different network paths with different PDF files but same with every pdf.
Ive tried to repair Adobe, re-install it.
It works fine to move the .pdf to the local hard drive and open it there.
I have not tried to turn the "secure mode" off.
I have checked your forums as with others and most of the replies indicate that it should be a specific version that's creates the error, is there anyone who has a solution on this?
Cheers.
Hello Rasmusl,
Sorry for the delay in response to your query and apologize for the inconvenience caused. As per the description above, you are not able to open the PDF file as the network path cannot be found, Is that correct?
Please refer and try the troubleshooting steps from the following links which discuss the similar issue
Cannot open files on the network server. Link: https://forums.adobe.com/thread/1325352
Adobe Reader 11.0.9 will not open PDF's from network shares Link: https://forums.adobe.com/thread/1578551
For testing purpose, disable the Protected mode from Preferences, and check.
Note: Make sure you enable the Protected mode back as Protected Mode keeps your system safe from external vulnerabilities and exploits. One should always keep it enabled.
Hope this helps, and let us know how it goes.
Regards,
Anand Sri.
