Expand my Community achievements bar.
SOLVED
Dispatcher enable TTL not working
Avatar
Level 2
I enabled TTL in dispatcher any file and also set an Expires header to be sent back in the target page
I can see the 'Expires' header in response when i access the page in publisher
but when I access the page using webserver / dispatcher URL, that header is not seen in the response anymore.
Is it removed by the webserver when returning response to the browser?
also even after making this change, no TTL related file is created in the cache folder (besides the cached file for the accessed page)
Is something else to be done to enable this?
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
Not sure if the keywords are case-independent. Try "enableTTL".
Jörg
View solution in original post
Avatar
Employee Advisor
The TTL feature only controls the ttl of the cache entry in the dispatcher. You should enable the dispatcher header caching feature to carry on the expiration information you added to the page while rendering it on publish.
I found a nice explanation of it at [1], especially "Response header caching" and "Time based cache invalidation".
Jörg
[1] AEM Dispatcher 4.1.11 - (not) just yet another release
Avatar
Level 2
Thank you . I am getting error in the log that "enablettl property is not recognized". My dispatcher version is 4.2.2.
Avatar
Correct answer by
Employee Advisor
Jörg
