3 Replies Latest reply on Sep 26, 2017 3:42 PM by Jeff Arola
    DNG Converter 9.12.1 only shows Camera Raw 7.1 after install
    Dogpilot
      I have tried installing this a couple of times and it still will only show Camera raw 7.1 in preferences. I tried using it as the stand alone application and in Lightroom 6.12, neither can see the RAW files of my Nikon D850, seems stuck on 7.1, even after I delete all the library files and pref files in preferences and re-install. So any way to get this un-stuck?
        • 1. Re: DNG Converter 9.12.1 only shows Camera Raw 7.1 after install
          ccastleb Adobe Employee
          This version in preferences is a backwards compatibility mode. It will only change if/when there is a revision of the DNG sdk or another technical reason why a previous version of ACR/LR would require a new compatibility mode to work with images from a newer camera model(s).
          To work with your Nikon D850 files in the current version of LR, you can use the 9.12.1 DNG Converter to select a folder of D850 NEF files and run the conversion with the compatibility mode set to ACR 7.1 (and any other settings you choose such as embedding the original raw, JPEG preview size, etc.). Once you convert the NEF files to DNG, you should be able to import the DNGs into LR.
          Hope that helps.
          Regards,
          - Chris
          • 2. Re: DNG Converter 9.12.1 only shows Camera Raw 7.1 after install
            Dogpilot Level 1
            Thank you for replying. That is indeed useful to know, However the problem persists, as the NEF files remain greyed out when I go to the DNG Converter directly and run that program. This happens regardless if I read from the XQD card or transfer the files to the desktop and try to read them. Same issue on my MacBook Pro.
            • 3. Re: DNG Converter 9.12.1 only shows Camera Raw 7.1 after install
              Jeff Arola Adobe Community Professional
              Lightroom hasn't been updated yet to read the Nikon D850 nefs.
              With the dng converter, when selecting the images to convert, one selects just the folder not the nef files inside.
