• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Only Works if Left on USB device?
New Here ,
Aug 11, 2008 Aug 11, 2008
1)Created on RoboHelp 7.0.2 (from trial version) and generated for UNIX.
2)Transferred WebHelp to USB Drive.
3) WebHelp can be started from USB Drive on UNIX platform.
(However, TOC in left-hand frame does not correctly size vertically--limited to about 2 inches )
4) Content seems to "continually refresh" (it just flashes progress bar...never see page) when WebHelp transferred to UNIX (Solaris 10 Update5 with Firefox 2.0.0.11) from USB Drive and activated from Desktop by opening initial topic.
Views
411
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
Generating "without skin" seems to eliminate "continual refresh"....however TOC vertical sizing issue remains.
Votes
Translate
Translate
Report
Report
New Here ,
When run from USB Thumb Drive:
Contents Tab: does not size Vertically and there is NO Horizontal Scroll Bar.
Index, Search & Glossary Tabs show both Vertical and Horizontal Scroll Bars when selected.
Votes
Translate
Translate
Report
Report
Community Expert ,
So the issue is that the window covers a certain depth but the TOC only goes down a small proportion of that and does not continue and display the rest of the TOC?
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 12, 2008 Aug 12, 2008
If I am on the right track, see the last post in this thread.
http://tinyurl.com/5tppvj
Also search on Firefox with your history set way back. You will get quite a lot of hits but I am sure I have seen this somewhere before.
Votes
Translate
Translate
Report
Report
New Here ,
In a generated project the TOC displays within the navigation pane as expected...but the navigation pane is somehow "limited" to the initial TOC display with none of the 4 books open. (Firefox/UNIX)
When same project is viewed on Windows Browser the TOC is capable of expanding the full height of the navigation pane on the left side (with all 4 books open and easilly viewed)
It seems to have something to do with the "generated" scripts (?DHTML?) If I manually edit and add an entry to the TOC the topic is just out of view at the bottom "limit" of the navigation pane. The navigation pane appears to be full height on the left side.....however the TOC will only display within the original height with all Books closed? It is however nice enough to provide a vertical scroll-bar on the right-hand side of the navigation pane...so I can scroll down to look at opened books.....:)
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
So the difference is between Firefox and Windows?
Does FF have the Firebug add-on installed? If it does, disable it and try again.
If you could post some images somewhere and add links here it would help.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
