• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Touch gestures on mobile when exported to .oam file and used in Adobe Captivate
Engaged ,
Sep 22, 2017 Sep 22, 2017
Hello,
I've been working on several projects in Adobe Animate which are all HTML5 canvas projects and have been coded using javascript. I'm using the exported .oam files to be placed in a Captivate course and everything is working fine, until I realized that the drag/slide interactions I have built-in weren't written for touch gestures (I'm not a coder/programmer, so I apologize for my incorrect terminologies which I'm sure I'll use).
I tried adding both
createjs.Touch.enable(stage);
and
createjs.Touch.enable(this.stage);
to the first frame where all my code is, but neither have worked on the iPhone 7 I am using to test (in Chrome browser). They work fine when tested in Chrome on the desktop, and even after I embed them in Captivate and publish the Captivate file they work fine on the desktop, but on the iPhone the .oam file will lose all interactivity and rearranges the size of one of movieclips?
I'm not sure if this is something I need to correct on the Animate end or the Captivate end?
Any help would be much appreciated.
Thanks.
Views
229
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Sep 27, 2017 Sep 27, 2017
Update on the original issue - to clarify if the issue was on the Captivate end or the Animate end I tested my animate movie by itself as an .html file on my iPad. This fixed the issue of not being able to drag and slide my moving objects, so I imagine the issue lies somewhere within Captivate and the publishing process from there.
However - when I tested it on my iPad there was a noticeable offset between where my finger was and the moving object - this offset does not exist when tested in the
Votes
Translate
Translate
Adobe Employee ,
Sep 25, 2017 Sep 25, 2017
I am checking with the Animate team about where the issue lies. Stay tuned.
Preran
Votes
Translate
Translate
Report
Report
Engaged ,
Thanks.
Votes
Translate
Translate
Report
Report
Engaged ,
However - when I tested it on my iPad there was a noticeable offset between where my finger was and the moving object - this offset does not exist when tested in the same browser (Google Chrome) on my desktop.
Any ideas into why this is?
Thanks.
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
NEVERMIND - I figured out the offset issue.
Votes
Translate
Translate
Report
Report
