I'm using Captivate for the first time. I downloaded the program, as well as the separate assets file, and installed it to the default location.
I restarted the computer after doing this. When I click on the themes option inside of Captivate, I am taken to this folder: C:\Users\Public\Documents\Adobe\eLearning Assets\Layouts\10_0\en_US
In that folder, there is a bpthemes folder, which is empty, and a file titled "white", which I'm guessing is the default theme.
If I browse through my files (outside of Captivate), I can find the ThemeColors folder that has a few different XML documents. I'm not sure if these are the themes, but if I navigate to this folder from captivate, they don't show up as a .cptm file, and there doesn't seem to be a way to open or even see other file types.
Themes are under the Big Button Themes, you only need to use Browse if you have a custom theme stored somewhere that doesn't show up with the thumbnails under the Themes button. Themes color palettes can be used by themes, the default themes are associated with such a color palette, but you can change them. Be careful when customizing a theme. All themes are responsive, but if yuo edit a theme in a normal, non-responsive project, you could screw the responsiveness of the theme and not be able to use it anymore as a responsive theme. There is some protection: you will not be able to save a responsive theme under the same name in a normal project.
Maybe some articles I wrote could offer you more details:
What's in a Theme - a Template? - Captivate blog
Some details about different folders, and customized items:
Captivate 8.0.1 Install? Keep your Customisation! - Captivate blog
I contacted support. I had to change the name of a folder and that fixed the problem. Thank you.
Justin,
What folder did you change?
And...
What did you change it to?
Thanx!
-Michael
