OK, so I figured out how to make a 360 panorama picture through Ps, but now how do I export it and which file, also what do I need to be able to view it like on FB?.
Thanks. Jim L.
You use a 360 panorama viewer https://www.google.com/search?q=360+panorama+viewer&oq=360+panorama+viewer&aqs=chrome..69i57j0l5.100...
I need to view 360 panoramas embedded in pdf, not a separate viewer linking to a panorama
you questioned this a bit longer ago, but maybe it's helpful to answer: as pdf supports javascript, it might be possible to view a 360 image inside a pdf with a js based 360 viewer (as the most players on the market do). the main problem could be: from where should it get the image data. i'm not sure it can be handled without retrieving the panorama image data from an online source. with the historic capability of pdf to integrate flash files (.swf) this was possible as such an swf could be self contained, including image data. another possibility might be via the 3D capabilities of pdf: https://helpx.adobe.com/acrobat/using/displaying-3d-models-pdfs.html
Thanks JJMack
