1. Re: Could Not Save Because...file already in use or was left open by another application error message
Dean Utian Sep 22, 2017 10:53 PM (in response to evie22)Are you saving to a local hard drive, external drive or network?
I'd also check the properties of the file to make sure it is not read only (check in File Explorer - right click on the file and go to Properties).
2. Re: Could Not Save Because...file already in use or was left open by another application error message
theangietaylor Sep 23, 2017 12:14 AM (in response to evie22)If you don't have the file
open in another application it could be that somebody else on the same network has it open? Or it could be a file permissions issue? Have you checked the File permissions?
3. Re: Could Not Save Because...file already in use or was left open by another application error message
MountainWalker Dec 7, 2017 5:56 PM (in response to evie22)An extremely annoying bug, has nothing to do with another application, the error appears out of nowhere, can't believe in 2017 photoshop has such serious bugs.
Anyway I've solved it by closing all my open pictures and turning all my open directories into thumbnails, I believe the pictures that are open on windows are the problem, why it has to do with photoshop? no clue.
I use windows 10 with photoshop cc 2017 -
4. Re: Could Not Save Because...file already in use or was left open by another application error message
mglush Dec 7, 2017 10:32 PM (in response to evie22)When you save the file to a pdf, do you have an existing pdf that you are saving over? If so, that could be your issue. If the file is open when saving to a pdf, it can't write over the existing file and you will get an error. Make sure the files are closed, and let us know if you are still having issues.
