1 Reply Latest reply on Aug 11, 2008 2:50 AM by Newsgroup_User
    icu4jSortQuery
    dongzky Level 1
      Hi Paul or anyone else who may have understanding on this,
      I have a few questions on this method you created for sorting the query.
      1. Since this method was created using icu4j collator, does it mean that the <cfquery> tag for cf doesn't return a correct sorting especially for Farsi where CF doesn't support? Let's assume a certain scenario. What if my db, Oracle, happens to support Farsi. Is it still recommended to use the icu4jSortQuery method? If so, how would this affect the performance especially in the speed?
      2. For query of query in CF, this will definitely not return a correct sorting order even if Oracle supports Farsi since query of query in CF is CF level. How can we use the icu4jSortQuery? Or maybe this is not the method to be used, right?
      3. Also, correct me if I'm wrong, the icu4jSortQuery is only meant for sorting 1 column?
      Thanks.
        • 1. Re: icu4jSortQuery
          Level 7
          no, this was primarily for use w/query of query or array sort which always used
          unicdoe code point value, which for some collations is incorrect.
          use the db.
          > right?
          no, you need to test that assumption first. using the code point value's not
          always wrong, only for *some* collations (i'm not 100% sure about farsi but i
          might guess it won't sort correctly as farsi's not arabic like french & german
          sort the same char differently). try a regular QofQ first, then the core java
          one (though the icu4j one should perform better).
          the info on how to install & use that CFC is contained in the CFC itself:
          - icu4jSortQuery returns query sorted on given collate locale. required
          arguments are
          toSort, query to sort,
          sortColumn column in toSort to use in collation. this sort is based on
          icu4j lib com.ibm.icu.text.Collator class.
          other non-required arguments:
          -- sortDir direction to sort query on, Asc (ascending) or Desc (descending).
          default is Asc
          -- retainSortID boolean indicating whether to return generated collate sort ID,
          default is false
          -- thisLocale java style locale (en_US, th_TH, etc.) to base collation on.
          defaults to en_US
          -- thisStrength collator strength value, sets level of comparison difference,
          valid values are IDENTICAL, PRIMARY, SECONDARY, QUATERNARY and the default of
          TERTIARY. the exact assignment of strengths varies locale to locale
          -- thisDecomposition determines how strings are decomposed in comparison. valid
          values:
          --- NO_DECOMPOSITION ignores accents, etc. fastest sort but wrong in many locales
          --- CANONICAL_DECOMPOSITION includes accents and chars with special formats,
          most complete but slowest, default.
          > 1 column?
          yup. you're welcome to extend it ;-) hint, have a look at the collateSortID.
