Hi all I am a student who works with the Creative Cloud and recently we started to work with scripts... but I'm no coding pro.
I was wondering if anyone can help me combine these two functions into one and make sure to stop the script if there ARE locked layers in the document and display the alert. (The user has to unlock the layers and run the script again).
Also if you guys can do me an extra favor and add an extra code that will place the last layer on each page which is the background (which is the locked one) as last as well in the new layers if that is possible. Because if I use the second function the background layer is placed between the layers and covers the other items.
I will be really thankful if someone can help me out!
function first () {
var doc = app.activeDocument;
for(var i = 0; i < doc.pages.length; i++) {
$.writeln('\'I\'m on page ' + i);
var page = doc.pages;
for(var j = 0; j < page.pageItems.length; j++) {
var item = page.pageItems
if(item.locked === true) {
// do something to the page item so you can
// find it visually
$.writeln('found a locked item');
item.fillColor = doc.swatches[5]; // normally it is
alert("Locked Item found,please unlock and start again");
first();
Main(); // < cmd (ctrl)+shift+K
// If you want the script to be un-doable, comment out the line above, and remove the comment from the line below
//app.doScript(Main, undefined, undefined, UndoModes.ENTIRE_SCRIPT,"Run Script");
function Main() {
// Check to see whether any InDesign documents are open.
// If no documents are open,the script will display an error message.
if (app.documents.length > 0) {
myDoc.viewPreferences.showRulers = true;
myDoc.viewPreferences.showFrameEdges = true;
myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS;
myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
myDoc.viewPreferences.strokeMeasurementUnits = MeasurementUnits.POINTS;
myDoc.viewPreferences.textSizeMeasurementUnits = MeasurementUnits.POINTS;
myDoc.guidePreferences.guidesShown = true;
myDoc.guidePreferences.guidesSnapto = true;
myDoc.viewPreferences.rulerOrigin = RulerOrigin.SPREAD_ORIGIN;
pictureLayer = app.activeDocument.layers.add ({name: "Beelden Laag"});
textLayer = app.activeDocument.layers.add({name: "Tekst Laag"});
app.activeDocument.rectangles.everyItem().itemLayer = pictureLayer;
app.activeDocument.groups.everyItem().itemLayer = pictureLayer;
app.activeDocument.textFrames.everyItem().itemLayer = textLayer;
myDoc.transparencyPreferences.blendingSpace = BlendingSpace.CMYK;
alert("The changes have been made!");
else {
alert("No InDesign documents are open. Please open a document and try again.");
Hi Christopherm,
You can try this...
Main();
function Main() {
if(app.documents.length > 0){
var flag = first();
if(flag == true){
else {
function first () {
return false;
return true;
