Continuing my series of studies on ScriptUI.
How to insert a logo.png in the center of the document through a "Select Folder" button, so that the path of that folder is registered in the user interface (ScriptUI).
Same as the image below:
Thank you!
...#target photoshop
var myFile = new File('c/')
var mask = '*.png'
var doc = activeDocument;
var dlg = new Window('dialog','Add a logo to the image');
dlg.alignChildren = ['top','left'];
dlg.btnGp = dlg.add('group');
dlg.btnGp.logoCk = dlg.btnGp.add('checkbox',undefined,'Add a logo');
dlg.btnGp.logoBtn = dlg.btnGp.add('button',undefined,'Select a file');
dlg.btnGp.logoPath = dlg.btnGp.add('statictext',undefined,'');
dlg.btnGp.logoPath.size = [400,15];
dlg.b
Are you talking about just getting a folder of files that you can then insert the png, or are you talking about getting the path for the png to insert into files?
Hi Chuck Uebele how are you buddy!
I'm planning a dialog box with buttons and checkbox, the purpose I want, would add a button called "select folder" to locate and insert a file.png inside document whenever the checkbox called "Add Logo" is enabled then the "Select Folder" button would be active and when I clicked this button, I would look for the file.png file in some folder so that the path is registered in the dialog giving a more professional look to the project.
#target photoshop
var mask = '*.png'
dlg.btnGp.logoBtn.enabled = false;
dlg.btnGp.logoPath.enabled = false;
dlg.ok = dlg.add('button',undefined,'Okay');
dlg.btnGp.logoCk.onClick = function (){
if(this.value){
dlg.btnGp.logoBtn.enabled = dlg.btnGp.logoPath.enabled = true;
else{
dlg.btnGp.logoBtn.enabled = dlg.btnGp.logoPath.enabled = false;
dlg.btnGp.logoBtn.onClick = function(){
myFile = File.openDialog ('Select a sogo file', mask, false);
if(myFile !=null){dlg.btnGp.logoPath.text = myFile.fsName};
dlg.ok.onClick = function(){
try{
if(dlg.btnGp.logoCk.value&&myFile.exists){
placeFile (myFile)
raster ();
catch(e){}
dlg.close();
dlg.show();
function placeFile(file){
var idPlc = charIDToTypeID( "Plc " );
var desc9 = new ActionDescriptor();
var idIdnt = charIDToTypeID( "Idnt" );
desc9.putInteger( idIdnt, 3 );
var idnull = charIDToTypeID( "null" );
desc9.putPath( idnull, new File( file ) );
var idFTcs = charIDToTypeID( "FTcs" );
var idQCSt = charIDToTypeID( "QCSt" );
var idQcsa = charIDToTypeID( "Qcsa" );
desc9.putEnumerated( idFTcs, idQCSt, idQcsa );
var idOfst = charIDToTypeID( "Ofst" );
var desc10 = new ActionDescriptor();
var idHrzn = charIDToTypeID( "Hrzn" );
var idRlt = charIDToTypeID( "#Rlt" );
desc10.putUnitDouble( idHrzn, idRlt, 0.000000 );
var idVrtc = charIDToTypeID( "Vrtc" );
desc10.putUnitDouble( idVrtc, idRlt, 0.000000 );
desc9.putObject( idOfst, idOfst, desc10 );
executeAction( idPlc, desc9, DialogModes.NO );
function raster(){
var idrasterizeLayer = stringIDToTypeID( "rasterizeLayer" );
var desc12 = new ActionDescriptor();
var ref1 = new ActionReference();
var idLyr = charIDToTypeID( "Lyr " );
var idOrdn = charIDToTypeID( "Ordn" );
var idTrgt = charIDToTypeID( "Trgt" );
ref1.putEnumerated( idLyr, idOrdn, idTrgt );
desc12.putReference( idnull, ref1 );
executeAction( idrasterizeLayer, desc12, DialogModes.NO );
Perfect Chuck Uebele as always, you did a great job. Just one more curiosity. Would it be possible for the directory (folder path) of the last inserted image to be registered so that whenever I open the dialog? It would be something similar to the script "Image Processor ..." Thank you very much for sharing your knowledge.
That could be added and so could logo resizing relative to image size be added. Scripting is powerful. But you need to be able to code in javascript or VBS or Applescript.
If you want to use the same logo, just hard code the path in line 2 of my above example.
var myFile = new File('/c/logo.png')
Perfect!Chuck Uebele Thank you very much for your time and help. JJMack Thank you for your alternatives, they are very useful.
If you know the png logo file and you know the size you want it to be relatve to an image's size and you want it centered you do not need the script to have a ScriptUI dialog and that script can be batched.
If you want to be able to select at png logo, specify the relative size the logo should be and be able to choose where the logo should be placed on the image then the script needs to have a ScriptUI dialog.
If you want to be able to batch that script. The script may be programmed as a Photoshop plug-in so you can record using the plug-in script in an action. The plug-in script will record the settings you used in its dialog recording the action into the action step. When the action is played the plug-in script will bypass displaying its dialog and use the recorded settings passed by the actions script step.
A script could also be programmed as a batch process and not need to include Plug-in support. Where you select which image files that should have the logo added in the script User Interface..
The script posted above woud not wok will IMO with different size image and different size logo png files.
Here is a script I posted several time to places a logo on the bottom of images. It has no dialog you you customize it by editing the first few variable statements. it handle size well. Images and logos can be any reasonable size. Logo PNG file should be created large for downsizing works better then up sizing.
http://www.mouseprints.net/old/dpr/PlaceWatermark.jsx
Ps-Design
I see you have 0 points so your most likely relatively new to these forums however you record shows you are interested in Photoshop Scripting which means you not normal. Most Photoshop never write a Photoshop Script. Let me introduce myself. I hack some at Photoshop scripting. Scripting is quite hard for me for I do not know JavaScript and I can not type so I'm always in error correction mode. You will see typing errors and spelling errors in all my appends and most may be hard to read. So why do I do it? I'm trying to keep the gray matter between my ears functioning. It the best and most powerful tool I have when using Photoshop. And I do know something about Photoshop and feel I can actually help others.
Hopefully from my append here you now realize the are basically three types of Scripts. Ones without Dialogs, Ones that have a dialog and are always interactive. And ones that have a dialog that are Photoshop Plug-in that they can be used interactively or fully automated without displaying a dialog.
I often will first prototype most of what I want in a script in an action where I will throw in some interactive steps where I will need to use scripting logic. Action can also use scripts and I have written some simple scripts for use in actions so actions can do thing normally actions can not.
You ask about scripting Photoshop to place a logo centered on an image with some dialog. But I did not post one or did I?
A little gray matter use. If I use the PlaceWatermak.jsx JJMack posted in an action what can I do?
Step 1 menu file>scripts>PlaeceWatermark
Step 2 Select All
Step 3 menu layer>align layers to selection Horizontal center
Step 4 menu layer>align layers to selection Vertical center
what else can I do
Step 5 Add layer style
Step 6 Save As jpg
But that action has no dialog how can I doe tahe with ans Action
Menu File>Automate>Batch
in dialog select input image folder
select place watermark action
check override save as
select destination folder
Yes I'm a hacker.... Welcome PS-Design
Ps you could leave out the save as and use the action with Image Processor script or Image Processor Pro Plug-in script....
They also have dialogs can save more then jpeg image files and can also resize image to fit the size you want...
Happy Hacking....
