I edit in VS Code and need to run my scripts via the Windows command line.
So I type:
"E:\ADOBE\Adobe After Effects CC 2017\Support Files\AfterFX.exe" -r "C:\Users\User\Documents\Adobe Scripts\example_script.jsx"
AfterEffects gets in the foreground and is for whatever reason resized but the script isn't called.
The script isn't called because if I put random characters in the script it doesn't give me an error.
If I run the script in AfterEffects (File - Scripts - Run Script File) it runs perfectly.
Here is almost the same thread with an answer to your question:
Re: starting AE + script via .bat file: AE immediately exits
Thanks a lot! I didn't search for a *.bat file but this helps a lot!
