4 Replies Latest reply on Sep 28, 2017 7:23 PM by nandancmv
    Convert field (number) to words
    nandancmv
      i need to convert field (number) to words ending "number only" and field 2 (number) to words ending "hundrud","thousand","ten thousand","lakhs"," tenlakhs " , "crore" "Rupees"," paise "  when i am using, event.value = ConvertToWord(this.getField("field 1"
      required output  if field 1 is 150 field 2 show "one fifty numbers only"
      field 2 validation script
      function ConvertToHundreds(num)
      aTens = [ "Twenty", "Thirty", "Forty", "Fifty", "Sixty", "Seventy", "Eighty", "Ninety"];
      aOnes = [ "Zero", "One", "Two", "Three", "Four", "Five", "Six", "Seven", "Eight", "Nine",
      "Ten", "Eleven", "Twelve", "Thirteen", "Fourteen", "Fifteen", "Sixteen", "Seventeen",
      "Eighteen", "Nineteen" ];
      var cNum, nNum;
      var cWords = "";
      num %= 1000;
      if (num > 99) {
      /* Hundreds. */
      cNum = String(num);
      nNum = Number(cNum.charAt(0));
      cWords += aOnes[nNum] + " Hundred";
      num %= 100;
      if (num > 0)
      cWords += " "
      if (num > 19) {
      /* Tens. */
      cNum = String(num);
      cWords += aTens[nNum - 2];
      num %= 10;
      if (num > 0)
      cWords += " ";
      if (num > 0) {
      /* Ones and teens. */
      nNum = Math.floor(num);
      cWords += aOnes[nNum];
      return cWords;
      function ConvertToWords(num)
      var aUnits = [ "Thousand", "Million", "Billion", "Trillion", "Quadrillion" ];
      var cWords = (num >= 1 && num < 2) ? " Numbers Only" : " Numbers Only";
      var nLeft = Math.floor(num);
      for (var i = 0; nLeft > 0; i++) {
      if (nLeft % 1000 > 0) {
      if (i != 0)
      cWords = ConvertToHundreds(nLeft) + " " + aUnits[i - 1] + " " + cWords;
      else
      cWords = ConvertToHundreds(nLeft) + " " + cWords;
      nLeft = Math.floor(nLeft / 1000);
      num = Math.round(num * 100) % 100;
      if (num > 0)
      cWords += ConvertToHundreds(num) + " "
      else
      cWords += " ";
      return cWords;
      field 2 custom calculation script
      event.value = "";
      var f = this.getField("No of Bonds A Minimum 2 Maximum 500In Numbers");
      if(f.valueAsString != "") {
      event.value = ConvertToWords(f.value);
      required output  if field 3 is 15000072.89 field 4 show "One crore fifty lakhs seventy two rupeese and eight nine pise only"
      field 4 validation script given
      var cNum, nNum;
      var cWords = "";
      num %= 1000;
      if (num > 99) {
      /* Hundreds. */
      cNum = String(num);
      num %= 100;
      if (num > 0)
      cWords += " "
      if (num > 19) {
      /* Tens. */
      cNum = String(num);
      num %= 10;
      if (num > 0)
      cWords += " ";
      if (num > 0) {
      return cWords;
      var cWords = (num >= 1 && num < 2) ? "Only" : "Only";
      if (i != 0)
      else
      if (num > 0)
      cWords += ConvertToHundreds(num) + " ";
      else
      cWords += " ";
      return cWords;
      field 4 custom calculation script
      event.value = ConvertToWords(this.getField("field 3").value);
        • 1. Re: Convert field (number) to words
          Is this a working solution you are sharing with us, or a question? If it is a question, what is the question, please?
          • 2. Re: Convert field (number) to words
            nandancmv Level 1
            its a question
            question 1
            i am created four field  and given this javascript under custom validation script in 2nd and 4 th java script respectively but it is not working properly either both field showing " Numbers Only" or  "Rupees only" i need both work in different field
            Quistion 2
            i need to convert this to thousand ten thousand one lakhs tenlakhs crore  currency format from
            Thousand", "Million", "Billion", "Trillion", "Quadrillion" format
            • 3. Re: Convert field (number) to words
              Question 1: the code you posted seems to have been written as a calculation script, not a validation script. You need to write a new script, I think.
              Question 2: you will need to understand and rewrite the code to accomodate these extra word meanings.
              • 4. Re: Convert field (number) to words
                nandancmv Level 1
                question number 1 explanation
                i given custom calculation script in
                event.value = "";
                and then given custom calculation script in Field 4 also
                then the  function ConvertToWordsConvertToWords written in validation script this is separate program in different field as given the details above one should end with numbers only and other  should show rupeese only both re working individually field 4 working correctly if i delete field 2 validation script   and field 2 working correctly if i delete field 4 validation script both validation script starting  as given below
