1 Reply Latest reply on Oct 26, 2017 8:27 AM by Tariq Dar
    Firma Digitale da convalidare, come fare
    manuledri
      buongiorno,
      ho fatto tutta la procedura per apporre una firma digitale con l'Aruba Key su un file, ma mi compare sempre la schermata qui sotto...
      ho fatto la procedura di convalida firme, ma il problema non si risolve...
      aiutatemi per favore
      grazie mille
      manuele
      p.s. potete contattarmi anche al 393 9355954
        • 1. Re: Firma Digitale da convalidare, come fare
          Tariq Dar Adobe Employee
          Hi Manuele,
          Sorry for the delay in response.
          I assume this file has multiple signatures, if yes you may try to validate signature one by one.
          If there is any problem with a signature while validating try the following steps:
          • Select the signature which has the problem and right click on it. It will display a pull-down menu. Select Show Signature Properties” menu item. Check Signature Properties window.
          • Click on Show Certificate" button. It will open Certificate Viewer window.
          • From Certificate Viewer window, click on Trust tab. It will display Trust Settingsand the certificate is not trusted.
          • If you received the PDF document from a trusted source or the certificate is from a trusted source, click on “Add to Trusted Identities” button. Otherwise skip here and don’t validate your signatures.
          • It will prompt you a message Trusting certificates directly from a document is usually unwise. Are you sure you want to do this?”. Click on OK button if you tryst the source. Otherwise, stop to continue to next steps.
          • Now it will display “Import Contact Setting” window. Select “Use this certificate as a trusted root“ checkbox and click on OK button to import contact settings into your system.
          • Now the signature is validated and it will display Signature is VALID, signed by the message in Signature Properties.
          • Click on Close button to close the Signature Properties window.
          Please let us know if that helps. Or if you have already found a resolution/workaround to this query, please reply to third with your findings that will help.
          -Tariq Dar
