1 Reply Latest reply on Sep 25, 2017 9:31 PM by Ten A
    illustrator javascript for "Identify the overset text in all text frames and reduce the font size" below are the script are identify the overset on selected text frame
    s_ashok Level 1
      i want to identify the overset text in all text frames and reduce the font size for all overset text frames.
      But the script only run on selected text frame.
      #target illustrator
      test();
      function test(){
      var doc = app.activeDocument;
      var sel = doc.selection[0];
      var contents = sel.contents;
      for(var i = 0; i < sel.lines.length; i++){
      contents = contents.replace(sel.lines[i].contents, "");
      //alert(contents);
          reduceSizeOfOversetText(app.selection[0]);
      function reduceSizeOfOversetText(t) {
              var d;
              while (
                  d = t.duplicate(),
                  d.name = 'temp',
                  d.convertAreaObjectToPointObject(),
                  d = t.parent.textFrames['temp'],
                  d.contents.replace(/[\x03\r]/g, '') !== t.contents.replace(/[\x03\r]/g, '')
                  d.remove();
               //   alert(t.textRange.characterAttributes.size)
                      if ((t.textRange.characterAttributes.size)<5.5)
                  alert("Text has been overflown  with point size of 5 points, please check the overflow text and fix as per SOP")
                 return;
                   // return false;
                 //break;
                 // exit()
                  t.textRange.characterAttributes.size -= 1;
             d.remove();
      kindly help on this.
      Thanks in advance
      Regards
      Ashok
