• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Confirm File was downloaded and by whom?
New Here ,
Aug 12, 2008 Aug 12, 2008
Greetings
I use cffile for an administrator to upload documents (PDF) to a repository directory. The name of the file is captured to the DB when uploaded.
I need to confirm if/when an end user has downloaded the document, and any information I can capture (IP address, etc.?) using a yes/no flag field and a field to store IP address? The user's info is already a record in the DB, and their session variable is available at log-in.
Thanks in advance
newportri
TOPICS
Advanced techniques
Views
730
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Aug 13, 2008 Aug 13, 2008
What's the part you are having difficulty with?
Votes
Translate
Translate
Report
Report
New Here ,
Dan:
Thanks for your continued help!
I don't know how I would go about confirming that the user actually surfaced the PDF to read it or print it. They could log into the system but not necessarily download documents- I need to have a record that confirms which documents they actually accessed.
Thanks again-
newportri
Votes
Translate
Translate
Report
Report
LEGEND ,
You have to know how your site works. Specifically, you have to know the available methods of downloading documents.
Votes
Translate
Translate
Report
Report
New Here ,
Dan:
The administrator uploads all the documents to a repository. The name of the document (whatever.pdf) is sent to the DB in a field named "FileContents" along with all the information about it, creating a record.
Later, a user logs on and can now see a link to the document - something like
<cfquery name="surface" datasource="#Request.BaseDSN#">
SELECT new_bid_ID, FileContents
FROM Bid
WHERE new_bid_ID = 388
</cfquery>
<cfoutput query="surface"><a href="bids/documents/#FileContents#" target="_blank">Click Here to see this document</a></cfoutput>
Is there any way to confirm that a logged-in user hit the link?
Thanks again
newortri
Votes
Translate
Translate
Report
Report
LEGEND ,
The answer is in the anchor tag. Instead of going straight to the document, go to a cf page that allows you to collect your data before showing the pdf to the user.
Votes
Translate
Translate
Report
Report
New Here ,
Dan:
Sorry to ask an assuredly simple question, but would the page simply carry out some processing then cflocation or would the user need to take additional action?
There is a session variable "Session.user_id" floating around- So it would need to be an update action- updating a yes/no field like:
UPDATE ****
SET didthedocgetopened = yes
WHERE Session.user_id = #Session.user_id#
Thanks......
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
quote:
Originally posted by: newportri
Dan:
UPDATE ****
Thanks......
Ian answered the first part.
For logging, I would be adding records, not updating them. That enables you to not only see who accessed the file, but how often.
Votes
Translate
Translate
Report
Report
LEGEND ,
newportri wrote:
> Dan:
> action?
It could, but the usual solution is to use the <cfcontent...> tag to
deliver the desired content, the PDF document in your example, after all
desired logging and other processing.
It also allows for the PDF documents to not be in a web accessible
directory so that intelligent users can not by pass your security and
logging to directly access the document with a browser.
Votes
Translate
Translate
Report
Report
Resources
Documentation
