5 Replies Latest reply on Sep 25, 2017 4:49 PM by robdillon
    Adobe Flash - Error, "Access of Undefined Property"
    bens47991640
      How to fix an undefined property compiler error in Adobe Flash CS6?
        • 1. Re: Adobe Flash - Error, "Access of Undefined Property"
          bens47991640 Level 1
          Also, need to know how to create a Mouse Click Event.
          Ex:
          Master.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_131);
          function fl_MouseClickHandler_131(event:MouseEvent):void
            fscommand("exec", "Master_Supply_List.app");
          • 2. Re: Adobe Flash - Error, "Access of Undefined Property"
            RandomlyFish Level 3
            Something that is undefined, does not exist. So your code is trying to access something that doesn't exist. Could you paste the code you're using?
            • 3. Re: Adobe Flash - Error, "Access of Undefined Property"
              /* Stop at This Frame
              The Flash timeline will stop/pause at the frame where you insert this code.
              Can also be used to stop/pause the timeline of movieclips.
              stop()
              /* Mouse Click Event
              Clicking on the specified symbol instance executes a function in which you can add your own custom code.
              Instructions:
              1. Add your custom code on a new line after the line that says "// Start your custom code" below.
              The code will execute when the symbol instance is clicked.
              MainMenu.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_100);
              function fl_MouseClickHandler_100(event:MouseEvent):void
                gotoAndStop(1);
              Instructions:
              Song_1.addEventListener(MouseEvent.CLICK, fl_MouseClickHandler_101);
              function fl_MouseClickHandler_101(event:MouseEvent):void
                fscommand("exec", "Song_1.app");
              • 4. Re: Adobe Flash - Error, "Access of Undefined Property"
                For the error, does it say what line is causing it?
                • 5. Re: Adobe Flash - Error, "Access of Undefined Property"
                  robdillon Most Valuable Participant
                  The error is trying to tell you that something in the code can't be found. The problem may not be a property, it may be an object. If you, for instance, put your code in frame 1 of the timeline and some object that is referenced, Song_1, for instance, doesn't appear in frame 1, then the Actionscript can't resolve the object with the code. Another common problem is a simple typo: Song_1 is not the same as song_1, to Actionscript for instance.
