• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Twisties Triangle Image Color on Hover?
Enthusiast ,
Sep 25, 2017 Sep 25, 2017
RH 2017 (13.0.279)
Primary Output: Html Help (CHM)
Hi Folks,
We use twisties in our help project. These are the little triangle images that point downwards and to the right when you expand or collapse dropdown text.
Is there a way to get the output to show a different triangle image on a mouse-over? You can see in these dropspot links that we use a gray mouse-over color for the hover text. But the collapsed triangle and the expanded triangle for the twisties don't ever change on a hover.
I know it's a minor thing, and if it's not too much work, we would like to implement a third triangle color whenever we hover over the text so that it matches the text's hover color.
Here's part of our style sheet code. Yellow highlight deals with the current images we use in the twisties. The red arrow points to where we're defining the hover color:
However, I suspect the issue is more javascript related than CSS related, especially so for a .chm output. Has anyone ever done this with their twisties?
Views
386
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Sep 26, 2017 Sep 26, 2017
You are using the twisty method that ships with RoboHelp. On my site there is a method that uses javascript and you might be able to modify that.
I haven't seen anyone post a method of doing via CSS.
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
Votes
Translate
Translate
Report
Report
Enthusiast ,
Thanks Peter. If I remember right, we're actually using a variation from your site that Willam van Weelden tweaked for us. We do use javascript. There's a twisty.js file that we call. Was hoping someone had already figured this out. But I'll try and take a look.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I spent some time in the script. From what I can tell, It doesn't write the images at all.
The twisties functionality appears to rely on the style sheet for that.
I believe following the model of the CSS in the image in my initial post that something like this should work:
But it does nothing.
What are the x-open-image and x-close-image statements? I understand that they're loading the triangle images used by the twisty when the content is open or closed, but those don't look like regular CSS. A search on the internet doesn't return anything either.
Are these RH-specific conventions? Or some odd subset of CSS? My guess is RH-specific. But if so, what's converting it to actual usable CSS to displays the image?
Votes
Translate
Translate
Report
Report
Community Expert ,
Sorry I can't answer that, beyond my pay grade. Willam is the man for such questions and as his focus has changed, he no longer follows these forums.
As you have dealt with him directly, I suggest you make contact via his site. He will be able to tell you whether or not your objective is achievable and maybe point you in the right direction.
@petergrainge
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
In Multiscreen HTML output, the images are actually written in to the topic page, so I think the css code is just the (maybe proprietary?) reference RH uses to locate them during the generation process.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
