1 Reply Latest reply on Oct 2, 2017 5:27 AM by Akash Sharma
    CS6 13.0.6  Deactivate greyed out
    leec27940162
      Usually the Deactivate option on my CS6 (Mac - Yosemite) functions just fine.
      (I tend to deactivate CS6 when I upgrade my OS just in case I need to reinstall everything from a backup system drive if things go wrong).
      However, I find it greyed out, along with updates and product registration.
      I've done a full update of all Adobe products with the Bridge updates (Adobe Application Manager), and it now tells me everything is up to date.  I've run Onyx on my Mac to clean up my Mac system and I've done a full restart of everything.
      Someone has mentioned that I can repair CS with my original disc, (I have a copy on a DVD), but not sure how to do that - even if it actually works.
      I'm drawing something of a blank and am reluctant to update my OS before fixing this.  Any thoughts?
      I copied my system info which is below if it helps:
      Adobe Photoshop Version: 13.0.6 (13.0.6 20131025.r.54 2013/10/25:21:00:00) x64
      Operating System: Mac OS 10.10.5
      System architecture: Intel CPU Family:6, Model:23, Stepping:6 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
      Physical processor count: 8
      Processor speed: 3000 MHz
      Built-in memory: 16384 MB
      Free memory: 9972 MB
      Memory available to Photoshop: 15003 MB
      Memory used by Photoshop: 70 %
      Image tile size: 1024K
      Image cache levels: 4
      OpenGL Drawing: Enabled.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      OpenGL Allow Old GPUs: Not Detected.
      OpenCL Version: 1.2 (Jun 12 2016 22:57:23)
      OpenGL Version: 2.1
      Video Rect Texture Size: 16384
      OpenGL Memory: 2047 MB
      Video Card Vendor: NVIDIA Corporation
      Video Card Renderer: NVIDIA Quadro 4000 OpenGL Engine
      Display: 2
      Display Depth: 32
      Display Bounds: top=22, left=1920, bottom=1200, right=3520
      Video Renderer ID: 16918272
      Video Card Memory: 2047 MB
      Display: 1
      Main Display
      Display Depth: 32
      Display Bounds: top=0, left=0, bottom=1200, right=1920
      Serial number: 91199169745665416630
      Application folder: /Applications/Adobe Photoshop CS6/
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        Untitled, 446.8G, 361.2G free
      Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
      Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
      Additional Plug-ins folder: not set
      Installed components:
         adbeape.framework   adbeape   3.3.8.19346   66.1025012
         AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
         adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
         AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
         AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
         AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
         AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
         AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
         AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
         AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
         AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
         AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
         AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
         AdobeLinguistic.framework      17206
         AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
         AdobeOwl.framework   AdobeOwl   5.0.4   79.517869
         AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
         AdobePDFSettings.framework   AdobePDFSettings   1.4
         AdobePIP.framework   AdobePIP   7.0.0.1686
         AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
         AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
         AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
         AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
         AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
         ahclient.framework   ahclient   1.7.0.56
         aif_core.framework   AdobeAIF   3.0.00   62.490293
         aif_ocl.framework   AdobeAIF   3.0.00   62.490293
         aif_ogl.framework   AdobeAIF   3.0.00   62.490293
         AlignmentLib.framework   xcode   1.0.0.1
         amtlib.framework.framework   amtlib   6.0.0.75
         boost_date_time.framework   boost_date_time   6.0.0.0
         boost_signals.framework   boost_signals   6.0.0.0
         boost_system.framework   boost_system   6.0.0.0
         boost_threads.framework   boost_threads   6.0.0.0
         Cg.framework   NVIDIA Cg
         CIT.framework   CIT   2.1.0.20577   146758
         data_flow.framework   AdobeAIF   3.0.00   62.490293
         dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
         dvacore.framework   dvacore   6.0.0.0
         dvamarshal.framework   dvamarshal   6.0.0.0
         dvamediatypes.framework   dvamediatypes   6.0.0.0
         dvaplayer.framework   dvaplayer   6.0.0.0
         dvatransport.framework   dvatransport   6.0.0.0
         dvaunittesting.framework   dvaunittesting   6.0.0.0
         dynamiclink.framework   dynamiclink   6.0.0.0
         FileInfo.framework   FileInfo   66.145433   66.145433
         filter_graph.framework   AdobeAIF   3.0.00   62.490293
         hydra_filters.framework   AdobeAIF   3.0.00   62.490293
         ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
         ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
         image_compiler.framework   AdobeAIF   3.0.00   62.490293
         image_flow.framework   AdobeAIF   3.0.00   62.490293
         image_runtime.framework   AdobeAIF   3.0.00   62.490293
         LogSession.framework   LogSession   2.1.2.1681
         mediacoreif.framework   mediacoreif   6.0.0.0
         PlugPlug.framework   PlugPlug   3.0.0.383
         UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
         wrservices.framework
      Required plug-ins:
         Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
         Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Average 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
         Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Camera Raw 9.1.1 (461), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Camera Raw Filter 9.1.1 (461), Copyright © 2015 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
         Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Cineon 13.0.6 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
         Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Collada DAE 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
         Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crop and Straighten Photos 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
         Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Difference Clouds 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
         Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Eazel Acquire 13.0.6 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
         Embed Watermark NO VERSION - from the file “DigiSign.plugin”
         Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         FastCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
         Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
         IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         JPEG 2000 13.0.6 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
         Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
         Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
         Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
         Matlab Operation 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Measurement Core 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
         Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         MMXCore Routines 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
         Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Multiprocessor Support 13.0.6 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
         Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         NTSC Colors 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
         Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
         OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         PCX 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
         Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Photoshop 3D Engine 13.0.6 x001  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
         Picture Package Filter 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
         Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pixar 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
         Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Portable Bit Map 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
         Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Radiance 13.0.6 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
         Read Watermark NO VERSION - from the file “DigiRead.plugin”
         Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
         ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
         Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Solarize 13.0.6 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
         Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
         Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
         Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
         Wireless Bitmap 13.0.6 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
         ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
      Optional and third party plug-ins:
         AJA Capture © 2013 AJA Video Systems Inc. - from the file “AJACapture.plugin”
         AJA Export © 2013 AJA Video Systems Inc. - from the file “AJAExport.plugin”
         AJA Settings © 2013 AJA Video Systems Inc. - from the file “AJAExport.plugin”
         BackgroundFilter 2.200, Copyright © 2003-2012 Google - from the file “BackgroundFilter.plugin”
         Canon Print Studio Pro Canon Print Studio Pro Version 2.0.0 Copyright CANON INC. 2012-2015 - from the file “CNPSPPI01.plugin”
         Canon Print Studio Pro Canon Print Studio Pro Version 2.0.0 Copyright CANON INC. 2012-2015 - from the file “CNPSPPI02.plugin”
         Color Efex Pro 4 4.200, Copyright © 2000-2013 Google - from the file “Color Efex Pro 4.plugin”
         Dfine 2 2.200, Copyright © 2003-2012 Google - from the file “Dfine2.plugin”
         FineStructuresFilter 2.200, Copyright © 2003-2012 Google - from the file “FineStructuresFilter.plugin”
         HDR Efex Pro 2 2.100, Copyright © 2000-2013 Google - from the file “HDR Efex Pro 2.plugin”
         HotPixelsFilter 2.200, Copyright © 2003-2012 Google - from the file “HotPixelsFilter.plugin”
         Imagenomic Plug-in Console 1.2 (c) 2010 Imagenomic, LLC. - from the file “ImagenomicPluginConsole.plugin”
         Merge to HDR Efex Pro 2 2.100, Copyright © 2000-2013 Google - from the file “HDR Efex Pro 2 Automation.plugin”
         Nik Collection Selective Tool 2.105, Copyright © 2000-2013 Google - from the file “SelectivePalette.plugin”
         Noiseware 5.0.1 © 2004-2012 Imagenomic, LLC - from the file “Noiseware.plugin”
         PortraitPro NO VERSION - from the file “PSFilterPPLauncher.plugin”
         Portraiture 2.3 © 2004-2012 Imagenomic, LLC - from the file “Portraiture.plugin”
         Realgrain 2.0.0 © 2004-2013 Imagenomic, LLC - from the file “Realgrain.plugin”
         ShadowsFilter 2.200, Copyright © 2003-2012 Google - from the file “ShadowsFilter.plugin”
         Sharpener Pro 3: (1) RAW Presharpener 3.100, Copyright © 2000-2012 Google - from the file “SHP3RPS.plugin”
         Sharpener Pro 3: (2) Output Sharpener 3.100, Copyright © 2000-2012 Google - from the file “SHP3OS.plugin”
         Silver Efex Pro 2 2.100, Copyright © 2000-2013 Google. - from the file “Silver Efex Pro 2.plugin”
         SkinFilter 2.200, Copyright © 2003-2012 Google - from the file “SkinFilter.plugin”
         SkyFilter 2.200, Copyright © 2003-2012 Google - from the file “SkyFilter.plugin”
         StrongNoiseFilter 2.200, Copyright © 2003-2012 Google - from the file “StrongNoiseFilter.plugin”
         Topaz DeNoise 5 CS3 (10.0) ©1993-2007 Adobe Systems Incorporated - from the file “Topaz_denoise5.plugin”
         Viveza 2 2.100, Copyright © 2012 Google - from the file “Viveza2.plugin”
         WhiteWindowWorkaround 1.0.6, Copyright 2013-2014 - from the file “WhiteWindowWorkaround.plugin”
      Plug-ins that failed to load: NONE
      Flash:
         EasyPanel
         Mini Bridge
         Kuler
      Installed TWAIN devices: NONE
