3 Replies Latest reply on Oct 26, 2017 3:24 AM by qtb000
    PhoneGap Build doesn't build for iOS
    andersborglund Level 2
      Attempting to build for iOS now takes a very long time as well (and fails; see below). Android builds fine though.
      I use cli-7.0.1.
      The following build commands failed:
      Ld /Users/phonegap/Library/Developer/Xcode/DerivedData/AyTvsGeoPromos-cfbqmqepryqzmmacseypye jimavh/Build/Intermediates/ArchiveIntermediates/AyTvsGeoPromos/IntermediateBuildFilesPath/ AyTvsGeoPromos.build/Release-iphoneos/AyTvsGeoPromos.build/Objects-normal/arm64/AyTvsGeoPr omos normal arm64
      (1 failure)
      Error code 65 for command: xcodebuild with args: -xcconfig,/private/tmp/gimlet/2112464/project/cordova/build-release.xcconfig,-workspace,A yTvsGeoPromos.xcworkspace,-scheme,AyTvsGeoPromos,-configuration,Release,-destination,gener ic/platform=iOS,-archivePath,AyTvsGeoPromos.xcarchive,archive,CONFIGURATION_BUILD_DIR=/pri vate/tmp/gimlet/2112464/project/build/device,SHARED_PRECOMPS_DIR=/private/tmp/gimlet/21124 64/project/build/sharedpch
      /Users/phonegap/gimlet/bin/system_ruby: line 22: shell_session_update: command not found
