15 Replies Latest reply on Oct 3, 2017 10:28 AM by Captiv8r
    Coding CSS Cursor Property does not work in Rh(11) Preview Topic pane or CHM browser
    ROBOPM Level 1
      Hello all,
      Problem Description: When using CSS cursor Property (Controls what the mouse cursor will look like when it is located over the element); the application (Rh) does not read the cursor Property when implemented in a HTML help page. When previewing using Rh Preview Topic pane or a compiled CHM browser, it does not respond (e.g. hovering over an image map section of an image). However, it does work in IE, Chrome, and Mozilla.
      Steps to Reproduce: Paste the following code below into your Rh HTML page.
      <style type="text/css">/*<![CDATA[*/
      area {
      cursor: help     ! important ;
      /*]]>*/</style>
      </head>
      Actual Result: Hovering over an 'Image Map' section, the cursor does NOT change into a cursor help icon, rather than its default cursor pointer (when hovering over an image-map or hyperlink section).Using the CSS cursor Property code in CSS/HTML does NOT work in CHM browser relevant in the browsers (mentioned above) in which there is a mouse and cursor.
      Expected Result: Hovering over an 'Image Map' section, the cursor changes into a cursor help icon, rather than its default cursor pointer (when hovering over an image-map or hyperlink section).Using the CSS cursor Property code in CSS/HTML works in CHM browser relevant in the browsers (mentioned above) in which there is a mouse and cursor.
      Any Workarounds: Is this a bug? Alternatively, the rendering engine does not support certain CSS control what is displayed or not? I do not have any workarounds to provide the development team. Does your team have a workaround?
      Submitted (09/29/2017) Bug Id: RH-961
      Thank You!
      ~PM
      PS - Hi Peter and Rick
