9 Replies Latest reply on Sep 27, 2017 5:20 PM by gener7
    macOS 12.13 High Sierra: Apple Color Picker not drawing properly in Photoshop CC 2017
    AsburyParkJoe
      Did a clean install if macOS 10.13 High Sierra yesterday. Also did clean installs of all the Adobe CC apps I use including Photoshop CC 2017. I switched from Adobe color pickers to Apple color pickers & found a bug. When the Apple color picker is called, the color picker draws only the color drag control and the lower swatches, anything above that is white - no color wheel. Click on the Cancel or Okay button that screen goes away, and the color picker window is drawn a second time. This time it has the color wheel, all the rest of the controls and swatches, but is still missing the row of icons that should be at the top of the color picker, to choose other Apple system pickers, as well as 3rd party picker. The area where they should be is just blank.
      Also called Adobe support to report the issue. Figured I'd post here to see if anyone else is having the same issue.
      And yes ... I know this is what happens when one jumps into the shallow end of the OS upgrade pool —head first. Guess I like to bleed a little.
      Mind you, the color picker works, but I can't select other color pickers that I use regularly. And so it goes ...
      Also, so far, everything else seems to be working normally. But I haven't pushed the Photoshop pedal to the metal yet.
      Apple Color Picker
