4 Replies Latest reply on Oct 12, 2017 2:30 PM by Kevin-Monahan
    How to move back a "Lost Keyframe" ?
    SaarM
      I by mistake drag a keyframe too much (under the 00:00:00) in the timeline.. and now I cant find the key frame to move him or change him..
      anyone know how do i fix it ??
      thanks!
        • 1. Re: How to move back a "Lost Keyframe" ?
          DonaldDoss Level 1
          Put your playhead on your first visible keyframe
          Click on the property to select all keyframes(including you lost one)
          drag all the keyframes forward until your lost key is visible
          shift-click on the lost key to deselect it
          drag the rest of your keyframes back to line up with your playhead
          • 2. Re: How to move back a "Lost Keyframe" ?
            angie_taylor Adobe Community Professional
            As Donald said, Click on the property name to select all keyframes for the property. With them all selected you can drag them along the timeline till you see your lost one. Also, If you want to retime the keyframes while doing this, hold down the Alt key when you drag on the first or last keyframe in your selection. This will enable you to squash or stretch the animation.
            • 3. Re: How to move back a "Lost Keyframe" ?
              Roei Tzoref Adobe Community Professional
              another way to  find/move it is this:
              1. click the arrow to go to previous keyframe
              you are now on the keyframe... wherever it is! and indication will be the blue diamond turning on
              2. if you want to advance it further in time, press Alt+Right arrow - it will advance one frame, add Shift to the mix, and it will advance 10 frames... keep going until you see it appearing at the beginning of your timeline.
              • 4. Re: How to move back a "Lost Keyframe" ?
                Kevin-Monahan Adobe Employee
                Hi SaarM,
                Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
                Kevin
