2 Replies Latest reply on Sep 28, 2017 3:11 AM by Cyanide77
    Refine Edge tool causes consistent crashing [Windows 10 PS CC 2017]
    Cyanide77
      As the title says. Not sure what is causing it. In a select and mask workspace. Using refine edge tool to fix up some hair (using onion overlay). Sometimes there is a lot of artifacting and then it just freezes and crashes or it just crashes within two 'strokes'. Couldnt find any crash logs in the photoshop log folder. I'm not sure what the refine mask tool uses, my assumption is it is GPU since my ram and cpu is pretty good but I dont have a dedicated GPU in my laptop, however it does have the latest intel integrated graphics. Some explanation or a fix would be great, Cheers
      Pic: https://i.imgur.com/tMkuGwi.jpg
      Specs:
                   Machine name: HP
                     Machine Id: {08B1FFF3-D8BE-48D0-ADF6-8E45646AA06A}
               Operating System: Windows 10 Home 64-bit (10.0, Build 15063) (15063.rs2_release.170317-1834)
                       Language: English (Regional Setting: English)
            System Manufacturer: HP
                   System Model: HP Spectre x360 Convertible 13-w0XX
                           BIOS: F.34
                      Processor: Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz (4 CPUs), ~2.9GHz
                         Memory: 16384MB RAM
            Available OS Memory: 16266MB RAM
                      Page File: 8424MB used, 10272MB available
                    Windows Dir: C:\WINDOWS
                DirectX Version: DirectX 12
            DX Setup Parameters: Not found
               User DPI Setting: 120 DPI (125 percent)
             System DPI Setting: 144 DPI (150 percent)
                DWM DPI Scaling: Enabled
                       Miracast: Available, with HDCP
      Microsoft Graphics Hybrid: Not Supported
                 DxDiag Version: 10.00.15063.0000 64bit Unicode
      Card name: Intel(R) HD Graphics 620
             Manufacturer: Intel Corporation
                Chip type: Intel(R) HD Graphics Family
                 DAC type: Internal
              Device Type: Full Device
               Device Key: Enum\PCI\VEN_8086&DEV_5916&SUBSYS_827E103C&REV_02
            Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
      Device Problem Code: No Problem
      Driver Problem Code: Unknown
           Display Memory: 8260 MB
         Dedicated Memory: 128 MB
            Shared Memory: 8132 MB
             Current Mode: 1920 x 1080 (32 bit) (60Hz)
      Windows Crash Log:
      Log Name:      Application
      Source:        Application Error
      Date:          27/09/2017 12:41:16 PM
      Event ID:      1000
      Task Category: (100)
      Level:         Error
      Keywords:      Classic
      User:          N/A
      Computer:      HP
      Description:
      Faulting application name: Photoshop.exe, version: 18.1.1.252, time stamp: 0x58fefd04
      Faulting module name: ntdll.dll, version: 10.0.15063.608, time stamp: 0x8274fd8b
      Exception code: 0xc0000374
      Fault offset: 0x00000000000f775f
      Faulting process id: 0x18a8
      Faulting application start time: 0x01d33737c1577625
      Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
      Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
      Report Id: be0664c3-33af-41e7-95f3-c121a7724863
      Faulting package full name:
      Faulting package-relative application ID:
      Event Xml:
      <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
          <Provider Name="Application Error" />
          <EventID Qualifiers="0">1000</EventID>
          <Level>2</Level>
          <Task>100</Task>
          <Keywords>0x80000000000000</Keywords>
          <TimeCreated SystemTime="2017-09-27T02:41:16.295487300Z" />
          <EventRecordID>24341</EventRecordID>
          <Channel>Application</Channel>
          <Computer>HP</Computer>
          <Security />
        </System>
        <EventData>
          <Data>Photoshop.exe</Data>
          <Data>18.1.1.252</Data>
          <Data>58fefd04</Data>
          <Data>ntdll.dll</Data>
          <Data>10.0.15063.608</Data>
          <Data>8274fd8b</Data>
          <Data>c0000374</Data>
          <Data>00000000000f775f</Data>
          <Data>18a8</Data>
          <Data>01d33737c1577625</Data>
          <Data>C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe</Data>
          <Data>C:\WINDOWS\SYSTEM32\ntdll.dll</Data>
          <Data>be0664c3-33af-41e7-95f3-c121a7724863</Data>
          <Data>
          </Data>
          <Data>
          </Data>
        </EventData>
      </Event>
