1. Re: Need help with low res low poly 3D
davescm Sep 27, 2017 2:44 AM (in response to kbos)1 person found this helpfulHi
You don't have the range of controls in Photoshop 3D that you do in a full 3D programme but a few things you can do :
1. Restrict the pixel size of your image.
2. Keep to 8 bit
3. In 3D Properties for scene - set surface style to "flat". Unfortunately in Photoshop you cannot control the mesh to use fewer polygons - which would have made the surfaces more visible*
4. Limit the render quality in Preferences - 3D
* If you want greater control over the mesh use a 3D program such as Blender
Below is a sphere with normal 3D default settings and the steps above for comparison
Dave
2. Re: Need help with low res low poly 3D
davescm Sep 27, 2017 3:32 AM (in response to davescm)1 person found this helpfulAn alternative approach using Blender to restrict the number of faces on the model and a posterize adjustment layer to limit the colour palette
Dave
3. Re: Need help with low res low poly 3D
kbos Sep 27, 2017 11:34 PM (in response to davescm)This is just what I was looking for thank you!
I do use Autodesk Maya '15 but I was thinking Photoshop might work better for lower resolution graphics I will try to adjust my settings in both programs and see what gives the best results.
Thanks again Dave I have so many projects in my head I can try out now!
-Kelly
4. Re: Need help with low res low poly 3D
davescm Sep 28, 2017 1:32 AM (in response to kbos)You're welcome - have fun
Dave
