8 Replies Latest reply on Sep 27, 2017 7:45 AM by jank63750246
    PS always downsize picture
    jank63750246
      Hello
      I've got problem, I've tried to save raw picture (cr2) as tif format. Raw has 5760x3840 but tif always has 3960x2640, I think it could be set in Raw Camera, only way I found is set size manualy to 5760x3840, but it isn't convinient because when size will be other I'll have to change it again. Doesn't have any option which allow us to don't change the picture size, it always have to do it manualy?
        • 1. Re: PS always downsize picture
          Per Berntsen Adobe Community Professional
          Uncheck the box next to "Dostosuj rozmiar", and the pixel dimensions will not be changed.
          • 2. Re: PS always downsize picture
            D Fosse Adobe Community Professional & MVP
            (since I don't speak Polish )
            • 3. Re: PS always downsize picture
              jank63750246 Level 1
              This box was unchecked by default and all of images have been changed to 3960x2640
              I've tried to set higher size 25MP, but image was scalled to 6123x4082 :/
              option Don't enlarge [Nie powiększaj] set size to default it means 3960x2640
              • 4. Re: PS always downsize picture
                This screenshot shows that you are using a camera which takes 10,5 megapixel pictures, or you have set the camera to take that format.
                (3960 x 2640 = 10.5 million)
                So if you want to enlarge, you have to check the Dostosuj rozmiar box and enter the dimensions.
                • 5. Re: PS always downsize picture
                  This can only mean two things.
                  • Either this is the real size out of the camera. If so, it would look and behave exactly like this. Are you sure they are not jpegs, or some "small" raw variety?
                  • Or there is a corrupt preferences file. I can't recall how you reset ACR preferences - anyone?
                  • 6. Re: PS always downsize picture
                    I think it's something wrong with PS, too,
                    It's medium raw, bellow is in exif, but actually something strange is there from me:
                    Filename - IMG_000001.CR2
                    ImageWidth - 5760
                    ImageLength - 3840
                    BitsPerSample - 8 8 8
                    Compression - 6 (JPG)
                    Make - Canon
                    Model - Canon EOS 5D Mark III
                    StripOffset - 91232
                    Orientation - Top left
                    StripByteCount - 2082829
                    XResolution - 72
                    YResolution - 72
                    ResolutionUnit - Inch
                    DateTime - 2000:01:01 02:58:39
                    Artist -
                    Copyright -
                    ExifOffset - 446
                    ExposureTime - 1/160 seconds
                    FNumber - 7.10
                    ExposureProgram - Manual control
                    ISOSpeedRatings - 400
                    Recommended Exposure Index - 400
                    ExifVersion - 0230
                    DateTimeOriginal - 2000:01:01 02:58:39
                    DateTimeDigitized - 2000:01:01 02:58:39
                    ComponentsConfiguration - YCbCr
                    ShutterSpeedValue - 1/166 seconds
                    ApertureValue - F 7.03
                    ExposureBiasValue - 0
                    MeteringMode - Center weighted average
                    Flash - Flash not fired, compulsory flash mode
                    FocalLength - 70 mm
                    UserComment -
                    SubsecTime - 00
                    SubsecTimeOriginal - 00
                    SubsecTimeDigitized - 00
                    FlashPixVersion - 0100
                    ColorSpace - Uncalibrated/Unknown (-1)
                    ExifImageWidth - 3960
                    ExifImageHeight - 2640
                    InteroperabilityOffset - 69800
                    FocalPlaneXResolution - 2710.47
                    FocalPlaneYResolution - 2716.05
                    FocalPlaneResolutionUnit - Inch
                    CustomRendered - Normal process
                    ExposureMode - Manual
                    White Balance - Manual
                    SceneCaptureType - Standard
                    Owner Name -
                    Lens Info - 70  70  0  0
                    Lens Model - 70mm
                    Lens Serial Number - 0000000000
                    GPS information: -
                    GPSVersionID - 2.3.0.0
                    Maker Note (Vendor): -
                    Macro mode - Normal
                    Self timer - Off
                    Quality - RAW
                    Flash mode - Not fired
                    Sequence mode - Single or Timer
                    Focus mode - MF
                    Image size - Large
                    Easy shooting mode - Manual
                    Digital zoom - None
                    Contrast - Normal
                    Saturation - Normal
                    Sharpness - Low , -32769
                    ISO Value - 32767
                    Metering mode - Center weighted
                    Focus type - Auto
                    AF point selected - 0
                    Exposure mode - Manual
                    Focal length - 70 - 70 mm (1 mm)
                    Flash activity - Not fired
                    Flash details -
                    Focus mode 2 - 65535
                    Auto ISO - 100
                    Base ISO - 400
                    White Balance - Fluorescent
                    Sequence number - 0
                    Camera Temperature - 27 C
                    Flash bias - 0 EV
                    Subject Distance - 0.00
                    Image Type - Canon EOS 5D Mark III
                    Firmware Version - Firmware Version 1.2.3
                    Owner Name -
                    Sharpness (EOS 1D) - 0
                    Directory index (EOS 450D) - 0
                    File index (EOS 450D) - 1
                    AF point selected - Off (Manual Focus)
                    Num AF Points - 61
                    Valid AF Points - 61
                    AF Image Width - 5760
                    AF Image Height - 3840
                    File number - 000 - 0000
                    Sharpness (A0) - 3
                    Thumbnail: -
                    JpegIFOffset - 80324
                    JpegIFByteCount - 10908
                    • 7. Re: PS always downsize picture
                      There is a setting in the camera for Medium Raw - 3960 x 2640.
                      See the clip below from DPReview - Canon EOS 5D Mark III Review: Digital Photography Review
                      So you have change the setting from MRAW to Raw in the camera to get the full resolution.
                      Option
                      Values / Actions
                      Notes
                      Shooting tab 1
                      Quality • RAW
                      RAW
                      MRAW
                      SRAW
                      • JPEG
                      Large Fine
                      Large Normal
                      Medium Fine
                      Medium Normal
                      Small1 Fine
                      Small1 Normal
                      Small2
                      Small3
                      - JPEG Large = 5760 x 3840
                      - JPEG Medium = 3840 x 2560
                      - JPEG Small1 = 2880 x 1920
                      - JPEG Small2 = 1920 x 1280
                      - JPEG Small3 = 720 x 480
                      - RAW = 5760 x 3840
                      - MRAW = 3960 x 2640
                      - SRAW = 2880 x 1920
                      Turn front dial to change RAW image, turn rear dial for JPEG.
                      • 8. Re: PS always downsize picture
                        ok., its' everythig clear now, IrfanView had mislead us,  it save raw as tif in  5760 x 3840 resolution, and we don't know why and where is problem
                        thanks a lot
