8 Replies Latest reply on Sep 28, 2017 3:23 AM by davescm
    PS: Auto-created smart object when placing can be editable but can't be overwritten
    DamonChen Level 1
      How to re-create problem:
      PS CC
      • New file
      • Go to Preferences in PS and check < Always create smart objects when placing >
      • Drag an image onto canvas
      • Image has been automatically converted into an Smart Object.
      • Double click into Smart Object
      • Unlock base layer
      • Use magic wand to remove some parts of image
      • Add layer mask
      • CMD+S the smart object
      ** Problem encountered at this point:
      Error message prompted:
      Can't save this document back to its original
      file format. Flatten layers and discard extra
      data as necessary then choose File > Save again.
      You can save the file using File > Save As, but the
      associated smart objects will not be updated.**
      Workaround:
      • Turn off < Always create smart objects when placing >
      • Drag image
      • Control click on layer and convert to smart object.
      • Double click on smart object and edit
      • Now save the smart object (No error message should prompt)
      Issue with auto-smart-object that it only allows for rescaling and some layer properties but not embedded smart object changes.
