When using the Classic Gallery in the web module everything seems to work as it did before. The Grid, Square and Track galleries will display the group of photos on the main page but when you click on a photo to display it then it sometimes works but generally the display corrupts and the only way to get out of it is to select a different Module like Library and then return the the Web module. This sometimes doesn't work unless you select the Classic Gallery before doing the module switches. For instance, this is what you see in the Track Gallery for the full photo. Lr2015.12. MacOS 10.13
Hi Bob,
Could you please try unchecking "Use Graphics Processor" by going to Lightroom's Preferences > Performance then relaunch Lightroom?
Regards,
Sahil
I will check the GPU when I get back to a computer in a couple of days but I am pretty sure I already did that during my testing of the issue and it did not make any difference. By the way, my High Sierra install was a fresh reformat and fresh reinstall of the software.
I checked and it's not working. Also, I just updated to Lightroom Classic CC and the Web Module is almost completely unresponsive. Even switching form a Track Gallery to HTML Gallery is not working. The Web Module seems completely stuck.
I am running Mac OS High Sierra 10.3 on a MacBook Pro 2016, Four Thunderbolt 3 Ports.
Any Idea, how to get it to work?
Peer
Try reset your Lightroom preference settings by holding down Shift+Option/Alt when launching Lr Classic CC.
It doesn't work to reset preferences. In 2015.12 the Grid Track and Square galleries were all broken under High Sierra. In Classic it seems only the Square Gallery is broken. Switching modules seems to reset things until you try to view a photo full size in the Square Gallery again. I haven't messed with the galleries enough to see if there are any other problems as I only use the Classic Gallery and it seem to work well in 2015 and Classic
Simon,
The Web Galleries seem to be working in Lightroom 7.1 and OSX 10.13.2. I don't know if it was a fix/change in Lightroom or OSX as I updated them on the same day but at least is seems to be working.
