6 Replies Latest reply on Feb 12, 2018 8:14 AM by Gamers_Command_Center
    After Effects not releasing memory after RAM render.
    A. Raitano Level 1
      Hello,
      This is my first post so forgive me if I forget to include some information.  My specs are
      OS: Win 10
      CPU: Intel i5 7600k
      MB: MSI z270-A Pro
      RAM: 16gb DDR4
      GPU: GTX 750ti
      SSD: 1tb
      The problem I am having is when I do a RAM preview render AE has been crashing.  I opened up task manager to see if it is a RAM thing and it seems to be.  As it approaches the limit set for AE (in the preferences menu: 6gb) it crashes.  Setting the limit higher (10gb) does nothing much better and this is why...  When I preview, I watch the RAM usage creep up in task manager and it goes up quick.  When I am done previewing, the usage stays at that same level even when I adjust something in my project (which I assume would release what was in memory so it can do a new preview).  The clip I am rendering is not very long (15 seconds max and really it crashes at about 5 seconds of render) and only uses 2 instances of Trapcode Particular.
      To rephrase after a long winded explanation:  I can RAM preview but each subsequent preview adds to the memory usages of my allowable RAM.  For example, if I have 10gb of RAM allocated to AE and I preview something that takes up 50% of that amount and I need to adjust something, the next preview adds to that 50% so if I preview the same amount again, I run out of RAM and AE crashes.  Is this normal and am I making any sense?
      Thanks for any advice.
      Adam Raitano
