2 Replies Latest reply on Oct 1, 2017 7:14 AM by JJMack
    Opening images as smart objects
    johnd91536914
      I am trying to do some image blending by opening images from Lightroom or ACR as smart objects in PS. When the images open in PS I get a message, "This smart object must be rasterized before processing. Edit contents will no longer be available." It results in that I can't edit the images until I rasterize them but if I do I can no longer keep them as smart objects meaning I cannot go back into ACR to do any adjustments.
      can anybody help me?
        • 1. Re: Opening images as smart objects
          Benjamin Root MVP & Adobe Community Professional
          You should be able to do some things, such as transform. You won’t be able to use the brush tool, for instance, directly on the layer. If you need to directly edit the layer, duplicate and rasterize. Otherwise, do as much as possible with new, empty layers and adjustment layers, etc. so they are non-destructive.
          • 2. Re: Opening images as smart objects
            It has to do with how Smart Objects layers are processed. Photoshop renders pixels for the layer's smart object and uses these pixels as the layers content.  These pixels can not be change with Photoshop tools they can only be worked on for the layers composite view like you can add smart filers like a blur the layers rendered pixels are not changed but  they are blurred into the document image composite view.  If you turn off the visibility of all the other layers it will look like the layer's pixels have been blurred  But you wiil see they have not if you turn the visibility of the smart filter off.   All smart object layers also have and associated transform,  The actual object may be a different size then the pixels you see in the documents composite image view.  Use Ctrl+T the layer may be larger than canvas size and being clipped the the document canvas size.
            You can not use tools like Paint brushes to change some pixels or delete some pixels  with an eraser or a selection cut.  You can blend the layer by changing the layers blending mode.  You can not blend anything into the pixels the have been  rendered by Photoshop for use as the layers content.  The Object's content they can only be changed by opening the Object and working on the object and committing changes.  Photoshop will then update the smart object and render a new set of pixels for the updated object.
