14 Replies Latest reply on Mar 28, 2018 1:10 AM by Jarda Bereza
    Script Unsmart 2.0 is done
    Jarda Bereza Level 4
      I need your help with testing.
      Also check settings inside script and try different settings.
      Download: Magic scripts for Photoshop
      Please make sure that you test version 2.0
      You also must copy file lexicon inside same folder.
      Major changes:
      - completely rewritten
      - added viewless method if smart object has no layer comps
      - opening and closing SO window only once if there are multiple instances
      - better, faster and more reliable SO active composition detection
      - Unsmart can now reproduce more deformations methods
      - big performance improvements
      - better artboards support for pixel perfect results
      - mask is added automaticaly only if layers inside smartObject canvas are outside canvas
      Reproduces from SO
      - pixel mask (including: link, density, feather)
      - disabled pixel mask
      - vector mask (including: link, density, feather)
      - disabled vector mask
      - blend modes, fill, opacity
      - name
      - color tag
      - deformation, position, scale
      - layer effects scaling including shapes strokes with gradients, patterns ect.
      - moves clipped layers to the SO group
      - if SO is linked with another layes new SO group will be also linked
      Can't reproduce
      - warp
      - SO filters
      Known issues
      - some deformations can't be reproduced with text layers or smart object vector layers. Nearest similar deformation is used.
      - you might see different result if smart object has more layer comps but none is selected
      - documents may not have compatible modes e.g. bits per pixels, color mode, pixel scaling
