Hello everyone,
I recently intalled the Adobe Creative Cloud App for my Macbook Air (Early 2015) running macOS High Sierra (10.13) and downloaded the latest verison of Adobe Lightroom CC (2015), but every time I try tu launch Lightroom, it crashes and it gaves an error saying "Lightroom quit unexpectedly".
I don't know what to do, I've looked on the internet for possible solutions, but none seem to work.
I also read on a post on this forum, to try and launch it from Terminal, and read for error displayed on Terminal, which I did and said the following:
objc[2312]: Class MacExePath is implemented in both /Library/Application Support/Adobe/OOBE/PDApp/P7/adobe_licutil.app/Contents/MacOS/adobe_licutil (0x1f6454) and /Applications/Utilities/Adobe Application Manager/P7/axlibv7.dylib (0x1f1d1ac). One of the two will be used. Which one is undefined.
objc[2313]: Class MacExePath is implemented in both /Library/Application Support/Adobe/OOBE/PDApp/P7/adobe_oobelib.dylib (0xc6d6090) and /Library/Application Support/Adobe/OOBE/PDApp/P7/axlibv7.dylib (0xc8071ac). One of the two will be used. Which one is undefined.
objc[2313]: Class MacExePath is implemented in both /Library/Application Support/Adobe/OOBE/PDApp/P7/adobe_oobelib.dylib (0xc6d6090) and /Applications/Utilities/Adobe Application Manager/P7/adobe_upgrade.dylib (0xca9f1ac). One of the two will be used. Which one is undefined.
Abort trap: 6
Could someone help me with this problem?
I was finally able to fix all my problems:
To fix the crashing at launching Lightroom issue, I just had to grant Read & Write permissions to Lightroom.app for every account on my MacBook (System, Admin, Everyone, and even adding [UserName]).
And to fix the crashing at opening Preferences issue, I just had to hold the Shift + Option keys while launching Lightroom.
Thanks to everyone who tried to help, and I hope this also helps people in similar situations!
Have you tried to deactivate the GPU support?
Take a look here: Adobe Lightroom GPU Troubleshooting and FAQ
Regards
Axel
I have tried, but I can't deactivate it from Preferences because it won't launch; and also, I can't edit the com.adobe.Lightroom6.plist file because the line useAutoBahn = true is nowhere to be found there.
I really don't think this is the GPU problem. I think you need to update your Lightroom to 2015.12
There seems to be no updates available at the moment.
But earlier you stated the version of your Lightroom is 2015. If that's correct, then there are updates to 2015.12, and you can download them and install them manually from Download Photoshop Lightroom
Hi Joebro,
Sorry for the crash, as you stated that the latest version of Lightroom is crashing on your computer, is it specifically after the update of macOS High Sierra (10.13), or was it also crashing prior to the update of macOS?
Also, did you try the troubleshooting steps for GPU as mentioned by Axel?
Could you please share the crash logs for Lightroom crashing.
Regards
Tanuj
It ocurred after the update to macOS High Sierra.
Could you tell me how to share the crash logs?
Hi!
on my MBP late 2016 and iMac late 2014 i´ve the same problem with Lightroom 5.
On Sierra i´ve no problems. Since i´ve updated to High Sierra, my LR crashes every time when i go to the HSL / Color / B&W. The new pricing model from Adobe is no solution for me as a private hobby photographer.
Is it possible to fix the problem without an update?
Thx
The solution oil my iMac with Lightroom, as detailed above solved my problem. I have no other ideas to help you.
Adobe Lightroom CC (2015) is not the latest version of LR. There are reports that Lightroom CC 2015.12 fixes (some) problems with High Sierra. So you need to update your LR to 2015.12
I read on the Internet that the problem may be that Lightroom didn't have the appropiate permissions to launch, so I went to the Applications folder, selected on Lightroom.app and edited the permission to Read & Write for every single account; then, I tried to launch Lightroom, and it worked! The only problem right now is that I can't open Preferences beacuse it crashes every time I try to.
I am wondering if the upgrade to High Sierra changed the permissions. This has been speculated before, with other operating systems upgrades, and obviously those permissions were not a problem before you upgraded to High Sierra ... hmmm ...
Exactly! I didn't have any problems before High Sierra! Anyway, I'm glad I was able to solve the issue!
Which lightroom version do you have? I have lightroom CC(2015) it says 6.0
I tried to apply your solution.. Couldn't succedd.. I grant permission, and shit+option didn't make any change.. Can you help..
Try granting Read & Write permissions to:
Notes:
Thanks you folks ! I did all the read-write stuff on all folders as described. Then LR opened to my last gallery. I then created a new catalog. When I try to open that (it has no images yet), LR crashes and closes. Any more ideas?
Lates new version of Lightroom Classic. Worked fine on High Sierra until I opened an alder project. then crashed as soon as it opened. I updated all permissions as I had dione previously for ALL users to r/W and still crashes on opening.
this is happening for me now, into november. anyone find workarounds or fixes? i have read the previous fixes, and i just updated to high sierra when this occurred; never before crashed.
To resolve the problem of crashing I did the following. Upgraded to High Sierra 10.13.1
Uninstalled Lightroom
Reinstalled Lightroom
Make sure every one of the folders mentioned in the beginning of this post were marked as READ/WRITE my every possible user
Rebooted the system.
Ran Disk Utility with First Aid, (no errors).
All was well after that.
PS: Make sure that you reinstall LATEST RELEASE of Lightroom !
I hop that this helps.
I use Lightroom EVERY DAY !
if I were do do the following steps.. would it delete all my images in Lightroom and all I have been working on?
I did not have to.
I will try that but here's my crash log:
LR launches, I se my gallery and it then crashes. I have also had problems with copying files and Apple Mail crashing.
Process: Adobe Lightroom [1463]
Path: /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
Identifier: Adobe Lightroom
Version: Adobe Lightroom [1125239] (6.12)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Lightroom [1463]
User ID: 501
Date/Time: 2017-10-06 16:39:03.400 -0400
OS Version: Mac OS X 10.13 (17A405)
Report Version: 12
Anonymous UUID: 43C22853-B118-2B42-1F00-C7B0D26093A9
[When a Staff person asks for private information hover your mouse over their name]
[you may then click the Message option in the popup window to send a private email]
[long crash log removed... please only send a crash log to a technician, when asked]
