2 Replies Latest reply on Oct 30, 2006 1:17 AM by Newsgroup_User
    ppt slides with video
    Level 7
      hi,
      I have publishing problems: 54 ppt slides associated with flv files,
      altogether ca. 140 mb, will produce a http error saying that there is
      not enough memory to complete this task or another message: couldn't map
      file names. I managed to upload the presentation only after renaming the
      .flv files and reattach them to the slides. But it is still not safe.
      After making some minor changes on the presenation I got the same error.
      Is there a limit for uploading slides with video files? Is there
      anything that can be done? I get the impression that the Breeze server
      has problems reading the video folder, because the error appears when
      the server is still reviewing the files. Once it starts uploading there
      is no problem any more.
      Regards
      Kathrin
        • 1. Re: ppt slides with video
          billcorrigan
          I don't know the full answer to your problem but I do know there is a 100 MB limit to what you can publish to the server. Try a test with a small number of slides to see if it works.
          -Bill
          • 2. Re: ppt slides with video
            Level 7
            > -Bill
            hi,
            I read about the 100 mb limit, but I thought it referred only to the ppt
            presentation itself. I took away 20 slides from the 54 slides and this
            worked out fine. Whole size of the presentation as indicated on the
            server about 109, this is close to the limit.
            I tried another way of uploading: I exported locally as a .zip file,
            started the upload from the breeze manager and it worked. I uploades a
            presentation with ca. 170 mb.
            Kathrin
