This will be in actions. I want to collapse a group, or maybe all groups. Only collapse - if current group already collapsed, will do nothing.
Any idea?
I have not found a way to collapse an layer group that exists and is expanded in an action. There is not shortcut or menu item for collapsing a target group and collapsing a group while recording an action does not record anything into the action. You can target several layer in an action and create a layer group from the selected layers and the group will be created collapsed. I found al link to a script that can buliarca's scripts BCM Tools
Howevet the scripy is a toggle it will opwn a colla
...Copy link to clipboard
Howevet the scripy is a toggle it will opwn a collapse targeted layer group. You can assign a shortcut to the script.
Thank you sir, I appreciate it.
Read the documentation well there may be a problem with that script if there are vector layer mask within the group
Wow, so powerful. Especially those scripts about invisible layers are really handy in actions. Thanks again.
Yes Actions have a problem with selecting layers relatively forward backwards front and back for only visible layers are selected by Photoshop. If an action turn off a layers visibility the targets other layers it can not select the layer with its visibility off except by name. Scripts can target any layer using the correct logic.
