14 Replies Latest reply on Oct 17, 2017 5:42 AM by williamadowling
    Adobe Illustrator not responding !!
    karth80472045 Level 1
      Hello everyone,
      My script works for small size files upto 900kb it takes less than a minute , if it is more than 900 kb it is running for 1/2 hour  then it forces the illustrator to not respond and closes the illustrator.
      can anybody suggest how to make to run all files in a folder irrespective of file size .
      here is my code .
      var main_group_array;
      var error_file_name="";
      var can_path_item_array=[];
      var unit_intersect_point_array=[];
        var magentaColor6= new CMYKColor();
      magentaColor6.cyan = 75;//orange
      magentaColor6.magenta =100;
      magentaColor6.yellow = 0;
      magentaColor6.black = 0;
      var magentaColor10 = new CMYKColor();
      magentaColor10.cyan = 18.43;
      magentaColor10.magenta =100;
      magentaColor10.yellow = 100;
      magentaColor10.black = 10.2;//Brown
      var magentaColor9 = new CMYKColor();
      magentaColor9.cyan = 0;
      magentaColor9.magenta =99;
      magentaColor9.yellow = 0;
      magentaColor9.black = 0; //magenta 1
      var magentaColor7 = new CMYKColor();
      magentaColor7.cyan = 0;
      magentaColor7.magenta =97;
      magentaColor7.yellow = 0;
      magentaColor7.black = 0;//magenta 2
      var magentaColor8 = new CMYKColor();
      magentaColor8.cyan = 0;
      magentaColor8.magenta =95;
      magentaColor8.yellow = 0;
      magentaColor8.black = 0;//magenta 3
      var magentaColor4 = new CMYKColor();
      magentaColor4.cyan = 60.39;
      magentaColor4.magenta =32.94;
      magentaColor4.yellow = 100;
      magentaColor4.black = 14.51;//Green
      var magentaColor1 = new CMYKColor();
      magentaColor1.cyan = 56.47;
      magentaColor1.magenta =0;
      magentaColor1.yellow = 63.92;
      magentaColor1.black = 0;//LIGHT GREEN
      var magentaColor2 = new CMYKColor();
      magentaColor2.cyan = 19.61;
      magentaColor2.magenta =100;
      magentaColor2.yellow = 69.02;
      magentaColor2.black = 8.63;//Dark Brown
      var magentaColor3 = new CMYKColor();
      magentaColor3.cyan = 0;
      magentaColor3.magenta =69.8;
      magentaColor3.yellow = 100;
      magentaColor3.black = 0;//light orange
      var fileArray_title=[];
      sourceFolder = Folder.selectDialog( 'Select the folder with Illustrator files', '~' );
      files = sourceFolder.getFiles(/\.(svg|ai)$/i);
       fileArray_SM_name = get_csvfile("Select CIL CSV List");
        fileArray_title = get_csvfile("Select ID List CSV");
         error_file_name=sourceFolder.path+'/Tabledata.csv';
             error_file_name1=sourceFolder.path+'/Connector Numbers.csv';
              file_output=new File (error_file_name);
              file_output.open ('e');
               file_output.writeln ("CircuitFileName"+","+"LineNumber"+","+"Type"+","+"ConnectorNumber"+","+"TerminalNumber"+","+"FileName"+","+"DisplayName");
                 file_output1=new File (error_file_name1);
              file_output1.open ('e');
               file_output1.writeln ("Connector Number"+","+"file Name");
         function get_csvfile(Str_File)
          var csv_file;
          csv_file = File.openDialog (Str_File);
          if(!csv_file.exists)
              return;
           else
             fileArray_buffer = save_elements(csv_file);
          return fileArray_buffer;
      function save_elements( fileObj )
              var thisLine, csvArray;
               fileArray_save_elements =[];
                fileObj.open( 'r' );
               while( !fileObj.eof )
                         thisLine = fileObj.readln();
                         csvArray = thisLine.split( ',' );
                         fileArray_save_elements.push( csvArray );
             return fileArray_save_elements;
                fileObj.close();
           if(files.length == 0)
             alert("Folder doesnot have any file");
          if ( files.length > 0 )
              for ( file_iteration = 0; file_iteration < files.length; file_iteration++ )
                  sourceDoc = app.open(files[file_iteration]);
                    var fileExtension = sourceDoc.name.substr((sourceDoc.name.lastIndexOf('.') + 1));
                     if(fileExtension=="ai")
                         $.sleep(1000);
                         check_title(sourceDoc);
                         sourceDoc.save();
                          sourceDoc.close();
                           $.sleep(10000);
                     else
       function check_title(sourceDoc)
       for(var lays1=0;lays1<sourceDoc.layers.length;lays1++)
                 if(sourceDoc.layers.length==1)
                     mainloop4:
                     for(var grp1=0;grp1<sourceDoc.layers[lays1].groupItems.length;grp1++)
                      if(sourceDoc.layers[lays1].groupItems[grp1].name=="<CIRCUIT TITLE>")
              for (var tit=0;tit<sourceDoc.layers[lays1].groupItems[grp1].textFrames.length;tit++)
                  if(sourceDoc.layers[lays1].groupItems[grp1].textFrames[tit].kind ==  TextType.POINTTEXT)
                  if(sourceDoc.layers[lays1].groupItems[grp1].textFrames[tit].textRange.characterAttributes.size==12)
                       if(sourceDoc.layers[lays1].groupItems[grp1].textFrames[tit].contents.slice(0,3)=="CAN")
       check_artboard();
       unlock( activeDocument.layers);
       color_empty_pathitem();
       delete_group();
       delete_group1();
        check_circle_ungroup_CAN();
        ungroup_group_subgroup();
                        ungroup_group();
                        ungroup_units();
                        autoColor_updation();
                        AAA_check1();
                         Check_battery_AAA();
                        ungroup_units1();
                         remove_fuse_group();
                        check_fuse_ungroup();
                        check_dot_repeat();
                        check_connector();
                         rename_fuse_group();
                         line_check1_unit_CAN();
                         line_check1_unit_2_CAN();
                         reduce_opacity();
                         reduce_opacity_1();
                        group_connector_name();
                        move_rectangle();
                        circleFront();
                        group_Circle_name_CAN();
                        checking_circleGroup_CAN();
                        check_unwantedline_CAN();
                        renaming_path();
                        renaming_CAN();
                        Check_batteryline();
                        line_pathitem_inside_CAN()
                          error_check();
                          list_connector_names();
                         break mainloop4;
                      if(sourceDoc.layers[lays1].groupItems[grp1].textFrames[tit].contents.slice(0,7)=="CONSULT")
                          check_artboard();
       delete_group();
       delete_group1();
       check_circle_ungroup();
        ungroup_units();
         AAA_check1();
         ungroup_units1();
             check_dot_repeat();
             check_connector();
               line_check1_unit();
               line_check1_unit_2();
                 reduce_opacity();
                 reduce_opacity_1();
                 move_rectangle();
                 check_can_AAA_PATH();
                 circleFront();
                  group_name_normal();
                    checking_circleGroup_normal();
                    check_unwantedline_normal();
               renaming_path();
                        renaming_CAN();
                         line_pathitem_inside_normal();
                         write_to_link();
                          error_check();
                     break mainloop4;
                       if(sourceDoc.layers[lays1].groupItems[grp1].textFrames[tit].contents.slice(0,4)=="IPDM")
       delete_group();
       delete_group1();
        ungroup_units();
         AAA_check1();
         ungroup_units1();
            check_dot_repeat();
             check_connector();
             reduce_opacity();
                 reduce_opacity_1();
                  move_rectangle();
                  check_AAA_path_BCM();
                         write_to_link();
            error_check();
            break mainloop4;
            if(sourceDoc.layers[lays1].groupItems[grp1].textFrames[tit].contents.slice(0,3)=="BCM")
       delete_group();
       delete_group1();
        ungroup_units();
         AAA_check1();
         ungroup_units1();
            check_dot_repeat();
             check_connector();
             reduce_opacity();
                 reduce_opacity_1();
                  move_rectangle();
                         write_to_link();
                             error_check();
                             break mainloop4;
                    else
                       check_artboard();
       delete_group();
       delete_group1();
        ungroup_units();
         AAA_check1();
         ungroup_units1();
             check_dot_repeat();
             check_connector();
               line_check1_unit();
                 reduce_opacity();
                 reduce_opacity_1();
                 move_rectangle();
                 circleFront();
               renaming_path();
                        renaming_CAN();
                         write_to_link();
                           error_check();
                           break mainloop4;
      else if(sourceDoc.layers.length==3)
          if(sourceDoc.layers[lays1].name=="RANGE" || sourceDoc.layers[lays1].name=="ILLUST")
               for (var tit=0;tit<sourceDoc.layers[lays1].textFrames.length;tit++)
                  if(sourceDoc.layers[lays1].textFrames[tit].kind ==  TextType.POINTTEXT)
                  if(sourceDoc.layers[lays1].textFrames[tit].textRange.characterAttributes.size==12)
                         if(sourceDoc.layers[lays1].textFrames[tit].contents.slice(0,7)=="CONSULT")
                      check_artboard();
       delete_group();
       delete_group1();
        ungroup_units();
         AAA_check1();
         ungroup_units1();
             check_dot_repeat();
             check_connector();
               line_check1_unit();
                 reduce_opacity();
                 reduce_opacity_1();
                 move_rectangle();
                 circleFront();
               renaming_path();
                        renaming_CAN();
                         write_to_link();
                            error_check();
                       break ;
                        if(sourceDoc.layers[lays1].textFrames[tit].contents.slice(0,3)=="CAN")
                          check_artboard();
       delete_group();
       delete_group1();
                        ungroup_group();
                        ungroup_units();
                        AAA_check1();
                        ungroup_units1();
                        check_dot_repeat();
                        check_connector();
                         reduce_opacity();
                         reduce_opacity_1();
                        move_rectangle();
                        circleFront();
                        renaming_path();
                        renaming_CAN();
                         error_check();
                         break;
                if(sourceDoc.layers[lays1].textFrames[tit].contents.slice(0,4)=="IPDM")
       delete_group();
       delete_group1();
        ungroup_units();
         AAA_check1();
         ungroup_units1();
            check_dot_repeat();
             check_connector();
             reduce_opacity();
                 reduce_opacity_1();
                  move_rectangle();
                         write_to_link();
                           error_check();
                           break;
       function delete_group()
       for(var i=0;i<sourceDoc.layers.length;i++)
          for(var k=0;k<sourceDoc.layers[i].groupItems.length;k++)
               theObj = sourceDoc.layers[i].groupItems[k].pageItems;
               if( theObj.length==1)
              for(var z=0;z< theObj.length;z++)
                if (theObj[z].typename == "GroupItem") {
                  theObj[z].moveBefore(theObj[z].parent);
       function delete_group1()
      for(var z=0;z<sourceDoc.layers[i].groupItems[k].groupItems.length;z++)
          var path_found=0;
          for(var zz=0;zz<sourceDoc.layers[i].groupItems[k].groupItems[z].groupItems.length;zz++)
              if(sourceDoc.layers[i].groupItems[k].groupItems[z].groupItems[zz].name.slice(0,15)=="connectornumber")
                  if(sourceDoc.layers[i].groupItems[k].groupItems[z].pathItems.length==0 || sourceDoc.layers[i].groupItems[k].groupItems[z].textFrames.length==0)
                  var path_found=1;
        if(path_found==1)
              sourceDoc.layers[i].groupItems[k].groupItems[z].groupItems[zz].moveBefore(sourceDoc.layers[i].groupItems[k].groupItems[z].groupItems[zz].parent)
         function check_artboard()
      var abIdx = sourceDoc.artboards.getActiveArtboardIndex ();
      var abSrc = sourceDoc.artboards[abIdx];
      var moveX = 4000;
      var moveY = 800;
      if(abSrc.artboardRect[0]<0)
      var abSrc_L = abSrc.artboardRect[0] + moveX;
      var abSrc_T = abSrc.artboardRect[1]  + moveY
      var abSrc_R = abSrc.artboardRect[2] + moveX ;
      var abSrc_B = abSrc.artboardRect[3] +moveY
      abSrc.artboardRect = [abSrc_L, abSrc_T, abSrc_R, abSrc_B];
      var layers = sourceDoc.layers;
      for( var i = 0, ii = layers.length; i < ii; i++ ) {
          // clear any current selection
          sourceDoc.selection = null;
            for(var k=0;k<layers[i].groupItems.length;k++)
          // translate them using the moveX and moveY variables
          var curGroup = layers[i].groupItems[k];
          curGroup.translate( moveX, moveY );
      for(var s=0;s<layers[i].pathItems.length;s++)
             var curGroup = layers[i].pathItems[s];
      for(var t=0;t<layers[i].textFrames.length;t++)
             var curGroup = layers[i].textFrames[t];
      function unlock ( items ) {
          var i = items.length;
          if ( i ) {
           while ( i-- ) {
                  items[i].locked = false;
                  if ( items[i].typename === 'GroupItem' ) {
                      unlock( items[i].pageItems );              }
                      else if ( items[i].typename === 'Layer' ) {
                         unlock( items[i].layers );
      function check_circle_ungroup_CAN()
           for(var layer_item_index=0;layer_item_index<sourceDoc.layers.length;layer_item_index++)
              if(sourceDoc.layers[layer_item_index].pageItems.length>0)
                  layer_grp_item=sourceDoc.layers[layer_item_index].groupItems;
          for(var grp_main_index=0;grp_main_index<layer_grp_item.length;grp_main_index++)
      child_path_item_main=layer_grp_item[grp_main_index].pathItems;
        child_group_item=layer_grp_item[grp_main_index].groupItems;
          var count_groupfound=0;
       mainloopline:
        for(var grp_main_index1=0;grp_main_index1< child_group_item.length;grp_main_index1++)
            if(child_group_item[grp_main_index1].name.slice(0,15)=="connectornumber" )
                 count_groupfound=1;
                break mainloopline;
         if(count_groupfound==0)
                 mainloopline:
            child_path_item_main1=child_group_item[grp_main_index1].pathItems;
            for(var path_1=0;path_1<child_path_item_main1.length;path_1++)
                 var  path_type = type_of_path(child_path_item_main1[path_1]);
                 if(path_type=="Line Type 1" || path_type=="Line Type 2"  || path_type=="Line Type 3" || path_type=="Line Type 4"  || path_type=="Line Type 10" || path_type=="Circle Type 1"
                 || path_type=="Circle Type 2" || path_type=="Circle Type 3"|| path_type=="Circle Type 4"|| path_type=="Circle Type 5"
                 || path_type=="Circle Type 6"|| path_type=="Line Type 12")
                     theObj=layer_grp_item[grp_main_index].pageItems;
                       for(var z=theObj.length-1;z>=0 ;z--)
                   for (i=theObj[z].pageItems.length-1; i>=0; i--)
                  theObj[z].pageItems[i].moveAfter(theObj[z].pageItems[i].parent);
          break mainloopline;
      function check_circle_ungroup()
       mainloopline:
            if(child_group_item[grp_main_index1].name.slice(0,15)=="connectornumber")
                count_groupfound=1;
                 break mainloopline;
           mainloopline:
                 if(path_type=="Line Type 1" || path_type=="Line Type 2"  || path_type=="Line Type 3" || path_type=="Circle Type 1"
          break mainloopline;
      function remove_fuse_group()
          for(var group1=0;group1<sourceDoc.layers[lays1].groupItems.length;group1++)
             var text_found=0;
              for(var group2=0;group2<sourceDoc.layers[lays1].groupItems[group1].groupItems.length;group2++)
                  for(var text1=0;text1<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames.length;text1++)
                if(!sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames[text1].contents.match(/[A-Z][0-9]{1,3}$/)) continue;
                 text_found=1;
         if( text_found==1)
             for(var group3=0;group3<sourceDoc.layers[lays1].groupItems[group1].groupItems.length;group3++)
                 for(var path1=0;path1<sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].pathItems.length;path1++)
                     var path_type=type_of_path(sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].pathItems[path1])
                     if(path_type=="Rectangle Type 3")
                         sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].moveToBeginning(sourceDoc.layers[lays1]);
                         break;
      function ungroup_group()
              var count=0;
             var count_group=0;
      for(var z=0;z<theObj.length;z++)
          if(theObj[z].typename=="PathItem" || theObj[z].typename=="TextFrame")
              count++;
      for(var zzz=0;zzz<theObj.length;zzz++)
           if(theObj[zzz].typename=="GroupItem")
               count_group++;
      if(count==0 || (count==1 && count_group==1))
          for(var zz=0;zz<theObj.length;zz++)
               if(theObj[zz].typename=="GroupItem")
                    var count_text=0;
                   for(var zzzz=0;zzzz<theObj[zz].pageItems.length;zzzz++)
                       if(theObj[zz].pageItems[zzzz].typename=="PathItem" || theObj[zz].pageItems[zzzz].typename=="TextFrame" )
                           count_text=1;
                   if(count_text==0)
                       theObj[zz].pageItems[zzzz].moveBefore(theObj[zz].parent)
          else
              theObj[zz].moveBefore(theObj[zz].parent)
      function ungroup_group_subgroup()
                  for(var group3=0;group3<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems.length;group3++)
                      for(var group4=0;group4<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems[group3].groupItems.length;group4++)
                          if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems[group3].groupItems[group4].name.slice(0,15)=="connectornumber")
                              sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems[group3].moveToBeginning(sourceDoc.layers[lays1]);
                              break;
      function ungroup_units()
       theObj=child_group_item[grp_main_index1].pageItems;
        function AAA_check1()
          var count=0;
              if(sourceDoc.layers[lays1].groupItems[group1].name=="AAA")
              {    count =group1;
                  break;
        for(var group2=sourceDoc.layers[lays1].groupItems.length-1;group2>=0;group2--)
              if(sourceDoc.layers[lays1].groupItems[group2].name=="AAA")
                  if(count==group2)
              else
                  sourceDoc.layers[lays1].groupItems[group2].moveToBeginning(sourceDoc.layers[lays1].groupItems[count])
       function ungroup_units1()
             for(var k=0;k<layer_grp_item.length;k++)
       if( layer_grp_item[k].name=="AAA")
           theObj =layer_grp_item[k].pageItems;
                  theObj[z].pageItems[i].moveAfter( theObj[z].pageItems[i].parent);
       function check_dot_repeat()
              var arr=[];
              arr.length=0;
              if(sourceDoc.layers[lays1].groupItems[group1].name!="AAA")
                  for(var group2=0;group2<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;group2++)
                      if(sourceDoc.layers[lays1].groupItems[group1].pathItems[group2].name.slice(0,3)=="pin")
                          arr.push(sourceDoc.layers[lays1].groupItems[group1].pathItems[group2].name);
                  if(arr.length>1)
                      var sorted_arr = arr.slice().sort();
      var results = [];
      results.length=0;
      for (var i = 0; i < arr.length - 1; i++) {
          if (sorted_arr[i + 1] == sorted_arr[i]) {
              results.push(sorted_arr[i]);
      if( results.length>=1)
          for(var k=0;k<results.length;k++)
              for(var group3=0;group3<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;group3++)
                   if(sourceDoc.layers[lays1].groupItems[group1].pathItems[group3].name==  results[k])
                       sourceDoc.layers[lays1].groupItems[group1].pathItems[group3].remove();
                       break;
       function check_connector()
            for(var lays=0;lays<sourceDoc.layers.length;lays++)
                var arr=[];
      var arr1=[];
          for(var group1=0;group1<sourceDoc.layers[lays].groupItems.length;group1++)
                   arr.length=0;
      arr1.length=0;
              for(var group2=0;group2<sourceDoc.layers[lays].groupItems[group1].groupItems.length;group2++)
                  for(var text1=0;text1<sourceDoc.layers[lays].groupItems[group1].groupItems[group2].textFrames.length;text1++)
                      if(!sourceDoc.layers[lays].groupItems[group1].groupItems[group2].textFrames[text1].contents.match(/[A-Z][0-9]{1,3}$/)) continue;
                          arr.push(sourceDoc.layers[lays].groupItems[group1].groupItems[group2].textFrames[text1])
              if(arr.length>1)
              for(var sd=0;sd<arr.length;sd++)
                  for(csv_iter = 0;csv_iter < fileArray_SM_name.length; csv_iter++)
                    if(arr[sd].contents== fileArray_SM_name[csv_iter][0])
                          arr1.push( fileArray_SM_name[csv_iter][1])
                          break ;
          for(var sd1=0;sd1<arr1.length;sd1++)
              if(arr1[0]==arr1[sd1])
              else
                  var count_error=0;
                  group_main=sourceDoc.layers[lays].groupItems[group1];
                        for(var error=0;error<sourceDoc.layers[lays].groupItems[group1].groupItems.length;error++)
                                    if(group_main.groupItems[error].name==group_main.name+ "Error:")
                                         var max_area_path=find_rectangle_path_with_large_area(group_main);
        var x_axis=Math.abs(max_area_path.pathPoints[0].anchor[0]);
                        var y_axis=Math.abs(max_area_path.pathPoints[0].anchor[1]);
                        var textRef =group_main.groupItems[error].textFrames.add();
      textRef.contents =arr[sd1].contents+" Different unit present inside the group" ;
      textRef.top =y_axis ;
      textRef.left = x_axis+20 ;
      textRef.textRange.characterAttributes.size = 10;
      count_error++;
      if(count_error==1)
      else
                                     var newGroup  =group_main.groupItems.add();
                                  newGroup.name = group_main.name+ "Error:";
                        var textRef = newGroup.textFrames.add();
      newGroup.moveToEnd(group_main);
          arr.length=0;
      arr1.length=0;
      function check_fuse_ungroup()
          var layer_item=sourceDoc.layers
           for(var layer_item_index=0;layer_item_index<layer_item.length;layer_item_index++)
              if(layer_item[layer_item_index].pageItems.length>0)
                  layer_grp_item=layer_item[layer_item_index].groupItems;
       mainloopfuse:
          break mainloopfuse;
        function line_check1_unit_CAN()
          var count=0;
              mainloop12:
                      for(var path=0;path<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems.length;path++)
                          var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path]);
                          if(path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3"  )
                              for(var text=0;text<sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames.length;text++)
                                  if(!sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text].contents.match(/[A-Z][0-9]{1,3}$/)) continue;
                                      var count_error=0;
                  group_main=sourceDoc.layers[lays1].groupItems[group1];
                        for(var error=0;error<sourceDoc.layers[lays1].groupItems[group1].groupItems.length;error++)
      textRef.contents ="Unwanted line present inside the group" ;
      count_error++;
      if(count_error==1)
      else
      break mainloop12;
       function line_check1_unit_2_CAN()
              var count_group_found=0;
                mainloop12:
                     if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].name.slice(0,15)=="connectornumber")
                         count_group_found=1;
                         break  mainloop12;
                 if(  count_group_found==1)
                      for(var path=0;path<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;path++)
                          var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path]);
                              var count_error=0;
      count_error++;
      if(count_error==1)
      else
      function reduce_opacity()
                  for(var path1=sourceDoc.layers[lays1].groupItems[group1].pathItems.length-1;path1>=0;path1--)
                      var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1]);
                      if(path_type=="Anchor point" && (sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name.slice(0,3)=="pin"
                      || sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name.slice(0,4)=="FUSE" || sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name.slice(0,2)=="FL"))
                          sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].opacity=0;
                      else if(path_type=="Anchor point" && sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name=="")
                           sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].remove()
                           for(var path2=sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems.length-1;path2>=0;path2--)
                      var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2]);
                      if(path_type=="Anchor point" && (sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name.slice(0,3)=="pin"
                     || sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name.slice(0,4)=="FUSE" || sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name.slice(0,2)=="FL" ))
                          sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].opacity=0;
                      else if(path_type=="Anchor point" && sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name=="")
                           sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].remove()
      function reduce_opacity_1()
              for(var path1=0;path1<sourceDoc.layers[lays1].pathItems.length;path1++)
                  var pathtype=type_of_path(sourceDoc.layers[lays1].pathItems[path1]);
                  if(pathtype=="Anchor point")
                     sourceDoc.layers[lays1].pathItems[path1].opacity=0;
      function circleFront()
          for(var group=0;group<sourceDoc.groupItems.length;group++)
          for(var path1=0;path1<sourceDoc.groupItems[group].pathItems.length;path1++)
              var  path_type = type_of_path(sourceDoc.groupItems[group].pathItems[path1]);
              if(path_type=="Circle Type 1" || path_type=="Circle Type 2" || path_type=="Circle Type 3" || path_type=="Circle Type 4" || path_type=="Circle Type 5"
                || path_type=="Circle Type 6")
            sourceDoc.groupItems[group].pathItems[path1].moveToBeginning(sourceDoc.groupItems[group].pathItems[path1].parent);
      function group_Circle_name_CAN()
          var count_group =1;
           for(var path=0;path<sourceDoc.pathItems.length;path++)
                 var  path_type = type_of_path(sourceDoc.pathItems[path]);
                     if((sourceDoc.pathItems[path].parent.name!="AAA" || sourceDoc.pathItems[path].parent.parent.name!="AAA")&& (sourceDoc.pathItems[path].parent.name=="") && (sourceDoc.pathItems[path].parent.name!="Shield") &&  (sourceDoc.pathItems[path].parent.name.slice(0,1)!="L"))
                           if(sourceDoc.pathItems[path].parent.pathItems.length>=3)
                               sourceDoc.pathItems[path].parent.name="CircleGroup"+count_group;
                               count_group++
                           else if(sourceDoc.pathItems[path].parent.pathItems.length<3)
                               for(var path1=0;path1<sourceDoc.pathItems[path].parent.pathItems.length;path1++)
                                   sourceDoc.pathItems[path].parent.pathItems[path1].strokeColor=magentaColor1;
                                      sourceDoc.pathItems[path].parent.pathItems[path1].strokeWidth=3;
                           else
                           else if(sourceDoc.pathItems[path].parent.name=="Shield")
                               sourceDoc.pathItems[path].parent.name="Shield"+count_group;
                               count_group++
                       else {
           function group_name_normal()
          var count_group =1
                     if((sourceDoc.pathItems[path].parent.name!="AAA" || sourceDoc.pathItems[path].parent.parent.name!="AAA")&& (sourceDoc.pathItems[path].parent.name=="") && (sourceDoc.pathItems[path].parent.name!="Shield") )
                               count_group++
                           else
                               count_group++
                       else {
        function checking_circleGroup_CAN()
            for(var path=0;path<sourceDoc.layers[lays1].groupItems.length;path++)
              if(sourceDoc.layers[lays1].groupItems[path].name.slice(0,11)=="CircleGroup" || sourceDoc.layers[lays1].groupItems[path].name.slice(0,6)=="Shield" || sourceDoc.layers[lays1].groupItems[path].name.slice(0,3)=="AAA" || sourceDoc.layers[lays1].groupItems[path].name.slice(0,1)=="L"  )
              for(var path_group=0;path_group<sourceDoc.layers[lays1].groupItems[path].pathItems.length;path_group++)
                 var  path_type = type_of_path(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group]);
                 if(path_type=="Circle Type 2" || path_type=="Circle Type 5")
                     var x_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[0]));
                     var y_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[1]));
                    var x_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[0]));
                     var y_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[1]));
                     var x_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[0]));
                     var y_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[1]));
                     var x_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[0]));
                     var y_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[1]));
                     if(x_pathtype< x_pathtype2)
                      x_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[0]))  ;
                     y_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[1]));
                     x_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[0]));
                     y_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[1]));
                 if(y_pathtype1<y_pathtype3)
                     y_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[1]));
                     x_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[0]));
                     y_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[1]));
                      x_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[0]));
             if(x_pathtype== x_pathtype2)
                 var x_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[0]));
                 var y_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[1]));
                  var x_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[0]));
                     var y_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[1]));
                      var x_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[0]));
                     var y_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[1]));
                       var x_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[0]));
                     var y_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[1]));
                         var y_pathtype3=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[2].anchor[1]));
                         var y_pathtype1=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[0].anchor[1]));
                            var x_pathtype=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[3].anchor[0]));
                              var x_pathtype2=Math.abs(Math.round(sourceDoc.layers[lays1].groupItems[path].pathItems[path_group].pathPoints[1].anchor[0]));
                   for(var lays2=0;lays2<sourceDoc.layers[lays2].layers.length;lays2++)
                     for(var path1=0;path1<sourceDoc.layers[lays2].layers[lays2].groupItems.length;path1++)
                       for(var path_group1=0;path_group1<sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems.length;path_group1++)
                          var  path_type1 = type_of_path(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1]);
                          if(path_type1=="Line Type 2" || path_type1== "Rectangle Type 5")
                              for(var path_points=0;path_points<(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints.length-1);path_points++)
                                  var x_pathline=Math.abs(Math.round(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points].anchor[0]));
                                  var y_pathline=Math.abs(Math.round(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points].anchor[1]));
                                 if((x_pathline> x_pathtype2) &&    (x_pathline<x_pathtype) && (y_pathline> y_pathtype3) &&    (y_pathline<y_pathtype1) )
                                       if(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].parent.name==sourceDoc.layers[lays2].groupItems[path].pathItems[path_group].parent.name)
                                        sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].name="Blue Color Line"
                                        sourceDoc.layers[lays2].layers[lays2].groupItems[path].pathItems[path_group].name="Blue Color Circle"
                                       else
                                           sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].strokeColor =magentaColor1;
                                             sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].strokeWidth =3;
                                  else if((x_pathline> x_pathtype2) &&    (x_pathline<x_pathtype) )
                                      if(y_pathline< y_pathtype3)
                                          var x_pathline1=Math.abs(Math.round(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points+1].anchor[0]));
                                  var y_pathline1=Math.abs(Math.round(sourceDoc.layers[lays2].layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points+1].anchor[1]));
                                  if((x_pathline1>x_pathtype2) && (x_pathline1<x_pathtype))
                                      if((y_pathline1>  y_pathtype3)&&(y_pathline1>  y_pathtype1))
                                            if(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].parent.name==sourceDoc.layers[lays2].groupItems[path].pathItems[path_group].parent.name)
                                        sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].name="Blue Color Line"
                                        sourceDoc.layers[lays2].groupItems[path].pathItems[path_group].name="Blue Color Circle"
                                       else
                                           sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].strokeColor =magentaColor1;
                                             sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].strokeWidth =3;
                                       else if((y_pathline1> y_pathtype3) &&(y_pathline1< y_pathtype1))
                                       else
                           else if(y_pathline> y_pathtype3)
                              var x_pathline1=Math.abs(Math.round(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points+1].anchor[0]));
                                  var y_pathline1=Math.abs(Math.round(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points+1].anchor[1]));
                                 if((y_pathline1>  y_pathtype3)&&(y_pathline1<y_pathtype1))
                                       else
                                       else if((y_pathline1<y_pathtype3) &&(y_pathline1<  y_pathtype1))
                                       else
                            else if((y_pathline> y_pathtype3) &&    (y_pathline<y_pathtype1) )
                                      if(x_pathline< x_pathtype2)
                                if((y_pathline1>y_pathtype3) && (y_pathline1<y_pathtype1))
                                      if((x_pathline1>  x_pathtype2)&&(x_pathline1>  x_pathtype))
                                       else
                                       else if((x_pathline1> x_pathtype2) &&(x_pathline1< x_pathtype))
                                       else
                                             sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].strokewidth =3;
                             else if(x_pathline> x_pathtype2)
                                      if((x_pathline1<  x_pathtype2)&&(x_pathline1<  x_pathtype))
                                       else
                                       else
               else if(path_type=="Circle Type 1" || path_type=="Circle Type 4")
                      for(var lays2=0;lays2<sourceDoc.layers.length;lays2++)
                     for(var path1=0;path1<sourceDoc.layers[lays2].groupItems.length;path1++)
                       for(var path_group1=0;path_group1<sourceDoc.layers[lays2].groupItems[path1].pathItems.length;path_group1++)
                          var  path_type1 = type_of_path(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1]);
                          if(path_type1=="Line Type 1" || path_type1== "Rectangle Type 11" || path_type1== "Line Type 10" || path_type1== "Line Type 4")
                              found_line:
                              for(var path_points=0;path_points<(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints.length-1);path_points++)
                                  var x_pathline=Math.abs(Math.round(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points].anchor[0]));
                                  var y_pathline=Math.abs(Math.round(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[path_points].anchor[1]));
                                  var x_pathlast=Math.abs(Math.round(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints.length-1].anchor[0]));
                                   var y_pathlast=Math.abs(Math.round(sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints[sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].pathPoints.length-1].anchor[1]));
                                        sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].name="Black Color Line"
                                        sourceDoc.layers[lays2].groupItems[path].pathItems[path_group].name="Black Color Circle"
                                       else
                                   else if((x_pathlast> x_pathtype2) &&    (x_pathlast<x_pathtype) && (y_pathlast> y_pathtype3) &&    (y_pathlast<y_pathtype1) )
                                        break found_line;
                                       else
                                       else
                                       else
                                       else
                                       else if((y_pathline1< y_pathtype3) &&(y_pathline1<  y_pathtype1))
                                       else
                                       else
                                         sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].name="BlackColor Line"
                                       else
                                       else
                                       else
              else if(path_type=="Circle Type 3" || path_type=="Circle Type 6")
                          if(path_type1=="Line Type 3" || path_type1== "Rectangle Type 5")
                                        sourceDoc.layers[lays2].groupItems[path1].pathItems[path_group1].name="Red Color Line"
                                        sourceDoc.layers[lays2].groupItems[path].pathItems[path_group].name="Red Color Circle"
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
           function checking_circleGroup_normal()
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                          if(path_type1=="Line Type 1" || path_type1== "Rectangle Type 11")
                              found_line:
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
                                       else
       function check_unwantedline_CAN()
          for(var path1=0;path1<sourceDoc.pathItems.length;path1++)
          if(sourceDoc.pathItems[path1].name=="Black Color Circle" || sourceDoc.pathItems[path1].name=="Blue Color Circle" || sourceDoc.pathItems[path1].name=="Red Color Circle")
              var group2=sourceDoc.pathItems[path1].parent;
              for(var group3=0;group3<group2.pathItems.length;group3++)
                  var path_type=type_of_path(group2.pathItems[group3]);
                        if(path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3" || path_type=="Line Type 4" || path_type=="Line Type 10")
                            if(group2.pathItems[group3].name=="")
                                 group2.pathItems[group3].strokeColor=magentaColor3;
                        group2.pathItems[group3].strokeWidth=5;
      function check_unwantedline_normal()
                        if(path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3")
            function  renaming_path()
                    for(var path1=0;path1<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;path1++)
                       var path_type=type_of_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1]);
                       if(path_type=="Rectangle Type 5" || path_type=="Rectangle Type 11" || path_type=="Circle Type 1" || path_type=="Circle Type 2"
                       || path_type=="Circle Type 3" || path_type=="Circle Type 4" || path_type=="Circle Type 5" || path_type=="Circle Type 6" ||
                            if(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name!="")
                               sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name=""
            function  renaming_CAN()
                var count_line=1;
                           else if(check (sourceDoc.layers[lays1].groupItems[group1].name))
                        else
                        path_type=="Line Type 10" || path_type=="Line Type 12" )
                            sourceDoc.layers[lays1].groupItems[group1].name="L"+count_line;
                            count_line++;
                            break;
        function error_check()
      for (var lay=0;lay<sourceDoc.layers.length;lay++)
         for(var group=0;group<sourceDoc.layers[lay].groupItems.length;group++)
             for(var group1=0;group1<sourceDoc.layers[lay].groupItems[group].groupItems.length;group1++)
                 if(sourceDoc.layers[lay].groupItems[group].groupItems[group1].name==sourceDoc.layers[lay].groupItems[group].name+"Error:")
                     var max_area_path=find_rectangle_path_with_large_area(sourceDoc.layers[lay].groupItems[group]);
                     if (max_area_path=="[PathItem ]")
                         max_area_path.strokeColor=magentaColor6;
                         max_area_path.strokeWidth=3;
                         for(var text=0;text<sourceDoc.layers[lay].groupItems[group].groupItems[group1].textFrames.length;text++)
                          sourceDoc.layers[lay].groupItems[group].groupItems[group1].textFrames[text].hidden=true ;
             else
                 for(var i=0;i<sourceDoc.layers[lay].groupItems[group].textFrames.length;i++)
                     sourceDoc.layers[lay].groupItems[group].textFrames[i].textRange.characterAttributes.fillColor=magentaColor6;
         function line_pathitem_inside_CAN()
          if(check(sourceDoc.layers[lays1].groupItems[group1].name))
      var path_type= type_of_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1]);
      if(path_type=="Rectangle Type 2" || path_type=="Rectangle Type 10")
      var x_path=Math.round(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[0]);
       var y_path=Math.round(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[1]);
       var x_path1=Math.round(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[2]);
      var y_path1=Math.round(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[3]);
      for(var group2=0;group2<sourceDoc.layers[lays2].groupItems.length;group2++)
          if(check1(sourceDoc.layers[lays2].groupItems[group2].name))
          for(var path2=0;path2<sourceDoc.layers[lays2].groupItems[group2].pathItems.length;path2++)
              var path_type1=type_of_path(sourceDoc.layers[lays2].groupItems[group2].pathItems[path2])
              if( path_type1=="Line Type 1" ||  path_type1=="Line Type 2" ||  path_type1=="Line Type 3" ||  path_type1=="Line Type 4" ||
              path_type1=="Line Type 10")
                  for(var point1=0;point1<(sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].pathPoints.length-1);point1++)
                      var x_point=Math.round(sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].pathPoints[point1].anchor[0]);
                      var y_point=Math.round(sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].pathPoints[point1].anchor[1]);
                      if(x_point> x_path && x_point<x_path1 && y_point<y_path1)
                           var x_point1=Math.round(sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].pathPoints[point1+1].anchor[0]);
                      var y_point1=Math.round(sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].pathPoints[point1+1].anchor[1]);
                      if(x_point1> x_path && x_point1<x_path1 &&   y_point1>y_path)
                          sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].strokeColor=magentaColor10;
                         sourceDoc.layers[lays2].groupItems[group2].pathItems[path2].strokeWidth=5
                  else if(x_point> x_path && x_point<x_path1 && y_point>y_path)
                      if(x_point1> x_path && x_point1<x_path1 &&   y_point1<y_path1)
                  else if(y_point<y_path && y_point>y_path1 &&  x_point<x_path)
                      if(y_point1<y_path && y_point1>y_path1 &&  x_point1>x_path1)
                    else if(y_point<y_path && y_point>y_path1 &&  x_point>x_path1)
                      if(y_point1<y_path && y_point1>y_path1 &&  x_point1<x_path)
       function line_pathitem_inside_normal()
              if( path_type1=="Line Type 1" ||  path_type1=="Line Type 2" ||  path_type1=="Line Type 3" )
      function check (nme) {
          if( (/^([A,B,C,D,E,F,H,K,M,N,R,T,Y][0-9]{1,3}:){1,9}$/).test( nme ) == false) {
              return false; }
          return true;
      function check1 (nme)
          if( (/^([L][0-9]{1,3}:){1,9}$/).test( nme ) == false) {
              return false; }
          return true;
      function line_cross()
          for(var group1=0;group1<sourceDoc.layers[lays2].groupItems.length;group1++)
              if(sourceDoc.layers[lays2].groupItems[group1].name!= "AAA")
                  var reg=/([L][0-9]{1,3})$/
                     if(reg.test(sourceDoc.layers[lays2].groupItems[group1].name.slice(0,sourceDoc.layers[lays2].groupItems[group1].name.length)))
                  for(var path1=0;path1<sourceDoc.layers[lays2].groupItems[group1].pathItems.length;path1++)
                      var path_type=type_of_path(sourceDoc.layers[lays2].groupItems[group1].pathItems[path1]);
                          if(path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3" || path_type=="Line Type 10" || path_type=="Line Type 12")
                             var count_liner=check_line_points_end(sourceDoc.layers[lays2].groupItems[group1].pathItems[path1],sourceDoc.layers[lays2].groupItems[group1]);
                             if(count_liner==2)
                             else
                                 sourceDoc.layers[lays2].groupItems[group1].pathItems[path1].strokeColor=magentaColor6;
       function check_line_points_end(Line_item,line_item2)
           var  count_linecheck=0;
            var x_point= Math.round(Line_item.pathPoints[0].anchor[0]);
                                  var y_point=Math.round(Line_item.pathPoints[0].anchor[1]);
                                    var x_point1= Math.round(Line_item.pathPoints[(Line_item.pathPoints.length)-1].anchor[0]);
                                  var y_point1=Math.round(Line_item.pathPoints[(Line_item.pathPoints.length)-1].anchor[1]);
                          for(var group2=0;group2<sourceDoc.layers[lays1].groupItems.length;group2++)
                              for(var path2=0;path2<sourceDoc.layers[lays1].groupItems[group2].pathItems.length;path2++)
                                  var path_type1=type_of_path(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2]);
                                 if(path_type1=="Anchor point" || path_type1=="Circle Type 1"  || path_type1=="Circle Type 2" ||  path_type1=="Circle Type 3" ||  path_type1=="Circle Type 4"
                                     ||  path_type1=="Circle Type 5" ||  path_type1=="Circle Type 6" || path_type1=="Rectangle Type 8"  )
                         if(path_type1=="Anchor point")
                                     var x_point1dot= Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[0].anchor[0]);
                                  var y_point1dot=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[0].anchor[1]);
                                  var xdiff=Math.abs(Math.abs(x_point)-Math.abs(x_point1dot));
      var ydiff=Math.abs(Math.abs(y_point)-Math.abs(y_point1dot));
      var xdiff1=Math.abs(Math.abs(x_point1)-Math.abs(x_point1dot));
      var ydiff1=Math.abs(Math.abs(y_point1)-Math.abs(y_point1dot));
      if(((xdiff>=0&&xdiff<=1.8)&&(ydiff>=0&&ydiff<=1.8) )|| ((xdiff1>=0&&xdiff1<=1.8)&&(ydiff1>=0&&ydiff1<=1.8) ))
          count_linecheck++;
            if(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.slice(0,3)=="pin" && sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.slice(0,4)!="pinx" && (sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.substr(4,1)!="*")
            && (sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.substr(4,1)!="@"))
              var rect=rectangle_function_decide(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2]);
              if(rect!=0)
                  if(rect.fillColor.cyan==0 && rect.fillColor.magenta==0 &&  rect.fillColor.yellow==25 && rect.fillColor.black==0)
                      var text= text_matching(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect);
                       if(text!=0 && text!=1)
               var compound=check_compound_path(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect,text);
                  if(compound==0)
                   var cil_text=check_cil(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect,text);
                      if(cil_text!=0 )
                          file_output.writeln(sourceDoc.name+","+line_item2.name+","+"L"+","+cil_text+","+text.contents)
                      else
                          sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].strokeColor=magentaColor6;
                          sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].opacity=50;
                  else
                      sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].strokeColor=magentaColor10;
                  else if(text==1)
                      var cil_text=check_cil_ground(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect,text);
                        if(cil_text!=0 )
                          file_output.writeln(sourceDoc.name+","+line_item2.name+","+"L"+","+cil_text+","+text)
                      else
                  else
                       sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].strokeColor=magentaColor3;
                  else if(rect.fillColor.cyan==0 && rect.fillColor.magenta==25 &&  rect.fillColor.yellow==25 && rect.fillColor.black==0)
                       var text= text_matching_fuse(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect);
                          if(text!=0)
                              if(text.contents.match(/^[A-Z]*$/))
                                  var cil_text="FL-"+text.contents;
                               else if(text.contents.match(/^\d{1,4}$/))
                                    var cil_text="FUSE"+text.contents;
                               else
              else
                    sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].strokeColor=magentaColor4;
                  else if(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.slice(0,3)=="pin" && sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.slice(0,4)!="pinx" && (sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.substr(4,1)=="*")
              if(rect!=0 )
                   var text= text_matching_star(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect);
                      if(text!=0)
                   if(compound==1)
                   var  cil_text=[];
                   var cil_text=check_cil_star(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect,text);
                     if(cil_text!=0 )
                          var connector_number_text=[];
                   var connector_number_text=check_connect_csv(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect,text,cil_text[0],cil_text[1]);
                 if(connector_number_text!=0)
                     file_output.writeln(sourceDoc.name+","+line_item2.name+","+"L"+","+connector_number_text[0]+","+cil_text[0])
                          file_output.writeln(sourceDoc.name+","+line_item2.name+","+"L"+","+connector_number_text[1]+","+cil_text[1])
                      else
                  else
                  else
                  else
                else
              else if(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.slice(0,4)=="FUSE" || sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.slice(0,2)=="FL")
              if(rect!=0 )
                  var text=rectangle_function_decide_fuse(sourceDoc.layers[lays1].groupItems[group2],sourceDoc.layers[lays1].groupItems[group2].pathItems[path2],rect);
              if(text!=0  )
                               else
                  else
                  else if(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name=="pinx")
                        file_output.writeln(sourceDoc.name+","+line_item2.name+","+"L"+","+"-"+","+"-")
                    else if(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].name.substr(4,1)=="@")
             if(path_type1=="Circle Type 1"  || path_type1=="Circle Type 2" ||  path_type1=="Circle Type 3" ||  path_type1=="Circle Type 4"
                                     ||  path_type1=="Circle Type 5" ||  path_type1=="Circle Type 6")
                                       var x_pathtype2=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].visibleBounds[0]);
                                       var x_pathtype=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].visibleBounds[2]);
                                       var y_pathtype1=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].visibleBounds[3]);
                                       var y_pathtype3=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].visibleBounds[1]);
                if(((x_point>= x_pathtype2)&&(x_point<= x_pathtype) &&(y_point<=y_pathtype3) && (y_point>=y_pathtype1)) ||
      ((x_point1>= x_pathtype2)&&(x_point1<= x_pathtype) &&(y_point1<=y_pathtype3) && (y_point1>=y_pathtype1)))
          count_linecheck++;
            if(path_type1=="Rectangle Type 8")
            var arrow_x=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[0].anchor[0]);
            var arrow_y=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[0].anchor[1]);
             var arrow_x1=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[1].anchor[0]);
            var arrow_y1=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[1].anchor[1]);
             var arrow_x2=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[2].anchor[0]);
            var arrow_y2=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path2].pathPoints[2].anchor[1]);
          if(arrow_x==arrow_x1)
              if(arrow_y>arrow_y1)
                  if(((x_point>=arrow_x)&&(x_point<=arrow_x2 || x_point>=arrow_x2)&&(y_point>=arrow_y1) &&(y_point<=arrow_y)) ||
        ((x_point1>=arrow_x)&&(x_point1<=arrow_x2 || x_point1>=arrow_x2)&&(y_point1>=arrow_y1) &&(y_point1<=arrow_y)))
            count_linecheck++;
        else if(arrow_y<arrow_y1)
             if(((x_point<=arrow_x2 ||x_point>=arrow_x2 )&&(y_point>=arrow_y) &&(y_point<=arrow_y1)) ||
        ((x_point1<=arrow_x2 ||x_point1>=arrow_x2 )&&(y_point1>=arrow_y) &&(y_point1<=arrow_y1)))
            count_linecheck++;
      else
          if(arrow_y==arrow_y1)
             if(((x_point>=arrow_x1)&&(x_point<=arrow_x)&&(y_point>=arrow_y2) &&(y_point<=arrow_y1)) ||
        ((x_point1>=arrow_x1)&&(x_point1<=arrow_x)&&(y_point1>=arrow_y2) &&(y_point1<=arrow_y1)))
           count_linecheck++;
      return count_linecheck;
      function rectangle_function_decide(main_group_path,pindot)
          var main_grp_path_flag=0;
      var sub_grp_path_flag=0;
      var wire_to_wire_rect=[];
      var wire_to_wire_rect_fuse=[];
          for(var path1=0;path1<main_group_path.pathItems.length;path1++)
              var path_type= type_of_path(main_group_path.pathItems[path1]);
              if( path_type=="Rectangle Type 2" || path_type=="Rectangle Type 10")
                  var x_path=Math.round(main_group_path.pathItems[path1].visibleBounds[0]);
       var y_path=Math.round(main_group_path.pathItems[path1].visibleBounds[1]);
       var x_path1=Math.round(main_group_path.pathItems[path1].visibleBounds[2]);
      var y_path1=Math.round(main_group_path.pathItems[path1].visibleBounds[3]);
      var x_point=Math.round(pindot.pathPoints[0].anchor[0]);
      var y_point=Math.round(pindot.pathPoints[0].anchor[1]);
      if(x_point>=x_path && x_point<=x_path1 && y_point<=y_path && y_point>=y_path1)
      main_grp_path_flag=1;
      wire_to_wire_rect.push(main_group_path.pathItems[path1]);
      else if( path_type=="Rectangle Type 3")
      wire_to_wire_rect_fuse.push(main_group_path.pathItems[path1]);
      for(var group1=0;group1<main_group_path.groupItems.length;group1++)
            for(var path1=0;path1<main_group_path.groupItems[group1].pathItems.length;path1++)
              var path_type= type_of_path(main_group_path.groupItems[group1].pathItems[path1]);
                  var x_path=Math.round(main_group_path.groupItems[group1].pathItems[path1].visibleBounds[0]);
       var y_path=Math.round(main_group_path.groupItems[group1].pathItems[path1].visibleBounds[1]);
       var x_path1=Math.round(main_group_path.groupItems[group1].pathItems[path1].visibleBounds[2]);
      var y_path1=Math.round(main_group_path.groupItems[group1].pathItems[path1].visibleBounds[3]);
       sub_grp_path_flag=1;
       wire_to_wire_rect.push(main_group_path.groupItems[group1].pathItems[path1]);
      else if(path_type=="Rectangle Type 3")
      wire_to_wire_rect_fuse.push(main_group_path.groupItems[group1].pathItems[path1]);
      if((main_grp_path_flag==1 || sub_grp_path_flag==1) && wire_to_wire_rect.length==1)
        return wire_to_wire_rect[0];
      else if((main_grp_path_flag==1 || sub_grp_path_flag==1) && wire_to_wire_rect_fuse.length==1)
          return  wire_to_wire_rect_fuse[0];
      else
          return 0;
       function text_matching(main_group_path,pindot,rect)
          var wire_to_wire_text=[];
          var count_text_found=0;
          var count_path=0;
          for(var text=0;text<main_group_path.textFrames.length;text++)
              if(main_group_path.textFrames[text].contents.match(/^\d{1,3}[A-Z]$/) || main_group_path.textFrames[text].contents.match(/^\d{1,4}$/))
                  if(main_group_path.textFrames[text].contents==(pindot.name.slice(4,pindot.name.length)))
                    var x_text=Math.round(main_group_path.textFrames[text].anchor[0]);
                    var y_text=Math.round(main_group_path.textFrames[text].anchor[1]);
                     var x_pindot=Math.round(pindot.pathPoints[0].anchor[0]);
                     var y_pindot=Math.round(pindot.pathPoints[0].anchor[1]);
                     var x_diff=Math.abs(x_text- x_pindot);
                     var y_diff=Math.abs(y_text-y_pindot);
                     if((x_diff>=0 && x_diff<=14) && (y_diff>=0 && y_diff<=12))
                         count_text_found=1;
                         wire_to_wire_text.push(main_group_path.textFrames[text]);
      for(var path=0;path<main_group_path.pathItems.length;path++)
          var path_type=type_of_path(main_group_path.pathItems[path]);
          if(path_type=="Anchor point")
              count_path++;
      if(count_path==1 && main_group_path.textFrames.length==0)
          return 1;
          else if(count_text_found==1 && wire_to_wire_text.length==1)
              return wire_to_wire_text[0];
          else
              return 0;
          function text_matching_star(main_group_path,pindot,rect)
                  if(main_group_path.textFrames[text].contents==(pindot.name.slice(5,pindot.name.length)))
                         count_text_found=1;
          var count_path=0;
              count_path++;
          return 1;
          else
              return 0;
      function check_compound_path(main_group_path,pindot,rect,text_item)
          var compound_path_present=0;
          for(var compound=0;compound<main_group_path.pageItems.length;compound++)
              if(main_group_path.pageItems[compound].typename=="CompoundPathItem")
                    var x_path= Math.abs(Math.round(main_group_path.pageItems[compound].position[0]));
                  var y_path=Math.abs(Math.round(main_group_path.pageItems[compound].position[1]));
                    var x_text=Math.abs(Math.round(text_item.anchor[0]));
                      var y_text=Math.abs(Math.round(text_item.anchor[1]));
                        if( (x_text-x_path)>0 && (x_text-x_path)<15)
                             if((Math.abs(y_text-y_path)>0 && Math.abs(y_text-y_path)<6))
                            compound_path_present=1;
                for(var group=0;group<main_group_path.groupItems.length;group++)
                    for(var compound=0;compound<main_group_path.groupItems[group].pageItems.length;compound++)
                        if(main_group_path.groupItems[group].pageItems[compound].typename=="CompoundPathItem")
                            var x_path= Math.abs(Math.round(main_group_path.groupItems[group].pageItems[compound].position[0]));
                  var y_path=Math.abs(Math.round(main_group_path.groupItems[group].pageItems[compound].position[1]));
            if(compound_path_present==1)
                return 1;
            else
                return 0;
        function check_cil_ground(main_group_path,pindot,rect,text_item)
          var s=[];
          var array = main_group_path.name.split(":");
          if(array==null)
              return 0;
          else
              main_loop1:
              for(var jj=0;jj<array.length;jj++)
              if(array[jj] == fileArray_SM_name[csv_iter][0])
                  if(text_item==fileArray_SM_name[csv_iter][2])
                      var terminal_found=1;
                      s.push(fileArray_SM_name[csv_iter][0]);
                      break  main_loop1;
      if(terminal_found==1 && s.length==1)
          return s[0];
      else
          return 0;
        function check_cil(main_group_path,pindot,rect,text_item)
          var s=[];
          if(array==null)
              return 0;
          else
              main_loop1:
                  if(fileArray_SM_name[csv_iter][1]=="WIRE TO WIRE")
                        if(text_item.contents==fileArray_SM_name[csv_iter][2])
                      if(array.length==3)
                      var x_rect=Math.round(rect.visibleBounds[0]);
                      var y_rect=Math.round(rect.visibleBounds[1]);
                      var x_rect1=Math.round(rect.visibleBounds[2]);
                      var y_rect1=Math.round(rect.visibleBounds[3]);
                      var x_dot=Math.round(pindot.pathPoints[0].anchor[0]);
                      var y_dot=Math.round(pindot.pathPoints[0].anchor[1]);
                      var y_diff=Math.abs(y_dot-y_rect);
                       var y_diff1=Math.abs(y_dot-y_rect1);
                      var x_diff=Math.abs(x_dot-x_rect);
                      var x_diff1=Math.abs(x_dot-x_rect1);
                      var arr_x=Math.round(array[0].anchor[0]);
                      var arr_y=Math.round(array[0].anchor[1]);
                      var arr1_x=Math.round(array[1].anchor[0]);
                      var arr1_y=Math.round(array[1].anchor[1]);
                      if(x_dot>=x_rect && x_dot<=x_rect1 && y_diff>=0 && y_diff<=2)
                                 if(arr_y>arr1_y)
                      s.push(array[0]);
                      break  main_loop1;
                  else
                      s.push(array[1]);
                      break  main_loop1;
              else if(x_dot>=x_rect && x_dot<=x_rect1 && y_diff1>=0 && y_diff1<=2)
                    if(arr_y<arr1_y)
                      s.push(array[1]);
                      break  main_loop1;
                  else
                      s.push(array[0]);
                      break  main_loop1;
              else if(y_dot>=y_rect1 && y_dot<=y_rect && x_diff1>=0 && x_diff1<=2)
                  if(arr_x>arr1_x)
                      s.push(array[0]);
                      break  main_loop1;
                else
                      s.push(array[1]);
                      break  main_loop1;
               else if(y_dot>=y_rect1 && y_dot<=y_rect && x_diff>=0 && x_diff<=2)
                  if(arr_x<arr1_x)
                      s.push(array[1]);
                      break  main_loop1;
                else
                      s.push(array[0]);
                      break  main_loop1;
          else
                break  main_loop1;
              else
                      break  main_loop1;
          return s[0];
      else
          return 0;
         function text_matching_fuse(main_group_path,pindot,rect)
              if(main_group_path.textFrames[text].contents.match(/^[A-Z]*$/)  || main_group_path.textFrames[text].contents.match(/^\d{1,4}$/))
                         count_text_found=1;
          else
              return 0;
      function rectangle_function_decide_fuse(main_group_path,pindot,rect)
           var x_path=Math.round(rect.visibleBounds[0]);
                 var y_path=Math.round(rect.visibleBounds[1]);
                 var x_path1=Math.round(rect.visibleBounds[2]);
                 var y_path1=Math.round(rect.visibleBounds[3]);
                  var path_type=type_of_path(main_group_path.groupItems[group1].pathItems[path1]);
                  if(path_type=="Line Type 5" || path_type=="Line Type 6")
                          var x_line=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[0].anchor[0]);
                             var y_line=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[0].anchor[1]);
                             var x_line1=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[(main_group_path.groupItems[group1].pathItems[path1].pathPoints.length)-1].anchor[0]);
                             var y_line1=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[(main_group_path.groupItems[group1].pathItems[path1].pathPoints.length)-1].anchor[1]);
                             var x_diff_dot=Math.abs(x_dot-x_line);
                             var y_diff_dot=Math.abs(y_dot-y_line);
                               var x_diff_dot1=Math.abs(x_dot-x_line1);
                             var y_diff_dot1=Math.abs(y_dot-y_line1);
                             if(x_line>= x_path && x_line<=x_path1 && y_line>=y_path1 && y_line<=y_path)
                                 if((( x_diff_dot>=0 &&  x_diff_dot<=3) && (y_diff_dot>=0 && y_diff_dot<=3)))
                                     x_line2=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[(main_group_path.groupItems[group1].pathItems[path1].pathPoints.length)-1].anchor[0]);
                                     y_line2=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[(main_group_path.groupItems[group1].pathItems[path1].pathPoints.length)-1].anchor[1]);
                                             if(sourceDoc.layers[lays1].groupItems[group2].name.slice(0,4)=="FUSE" || sourceDoc.layers[lays1].groupItems[group2].name.slice(0,2)=="FL")
                                             for(var path4=0;path4<sourceDoc.layers[lays1].groupItems[group2].pathItems.length;path4++)
                                                 var path_type3=type_of_path(sourceDoc.layers[lays1].groupItems[group2].pathItems[path4]);
                                                 if(path_type3=="Rectangle Type 3")
                                                     var x_fuse_point=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path4].visibleBounds[0]);
                              var y_fuse_point=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path4].visibleBounds[1]);
                                var x_fuse_point1=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path4].visibleBounds[2]);
                              var y_fuse_point1=Math.round(sourceDoc.layers[lays1].groupItems[group2].pathItems[path4].visibleBounds[3]);
                               var diff_fuse_y1=Math.abs(Math.abs(y_fuse_point)- Math.abs( y_line2))
                              var diff_fuse_y2=Math.abs(Math.abs(y_fuse_point1)- Math.abs( y_line2))
                              if(x_fuse_point>x_path && x_fuse_point<x_path1 && y_fuse_point>y_path1 &&  y_fuse_point<y_path)
                                   if(((x_fuse_point< x_line2) && (x_fuse_point1>x_line2)) && (diff_fuse_y2>=0 && diff_fuse_y2<=2))
                                       for(var text=0;text<sourceDoc.layers[lays1].groupItems[group2].textFrames.length;text++)
                                           if(sourceDoc.layers[lays1].groupItems[group2].textFrames[text].contents.match(/^[A-Z]*$/))
                                               if(pindot.name==("FL"+sourceDoc.layers[lays1].groupItems[group2].textFrames[text].contents))
                                                   return sourceDoc.layers[lays1].groupItems[group2].textFrames[text];
                                           else if(sourceDoc.layers[lays1].groupItems[group2].textFrames[text].contents.match(/^\d{1,4}$/))
                                                 if(pindot.name==("FUSE"+sourceDoc.layers[lays1].groupItems[group2].textFrames[text].contents))
                                                   return sourceDoc.layers[lays1].groupItems[group2].textFrames[text] ;
               else if((( x_diff_dot1>=0 &&  x_diff_dot1<=3) && (y_diff_dot1>=0 && y_diff_dot1<=3)))
                   x_line2=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[0].anchor[0]);
                                     y_line2=Math.round(main_group_path.groupItems[group1].pathItems[path1].pathPoints[0].anchor[1]);
                                            else if(sourceDoc.layers[lays1].groupItems[group2].textFrames[text].contents.match(/^[A-Z]*$/))
       else
           return 0;
      function check_cil_star(main_group,pindot,rect1,text1)
             var arr1=[];
                  mainloop4:
                      if(sourceDoc.layers[lays1].groupItems[group1].name=="Variant Terminal")
                              if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].name=="Star Terminal")
                                for(var text2=0;text2<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames.length;text2++)
                                    if(text1.contents==sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames[text2].contents)
                                        for(var text3=0;text3<sourceDoc.layers[lays1].groupItems[group1].textFrames.length;text3++)
                                            if(sourceDoc.layers[lays1].groupItems[group1].textFrames[text3].contents.match(/^\d{1,3}[A-Z]$/) || sourceDoc.layers[lays1].groupItems[group1].textFrames[text3].contents.match(/^\d{1,4}$/))
                                                arr1.push(sourceDoc.layers[lays1].groupItems[group1].textFrames[text3].contents);
                                    else
                                    else
                                        continue mainloop4;
          if(arr1.length==2)
              return arr1;
          else
              return 0;
        function check_connect_csv(main_group_path,pindot,rect1,text1,ter1,ter2)
          var s=[];
          if(array==null)
              return 0;
          else
              main_loop1:
                  if(ter1==fileArray_SM_name[csv_iter][2])
                      break  main_loop1;
      var array1=main_group_path.name.split(":");
       if(array1==null)
              return 0;
          else
              main_loop2:
              for(var jj=0;jj<array1.length;jj++)
              if(array1[jj] == fileArray_SM_name[csv_iter][0])
                  if(ter2==fileArray_SM_name[csv_iter][2])
                      var terminal_found1=1;
                      break  main_loop2;
      if(terminal_found1==1 && terminal_found==1  && s.length==2)
         return s;
      else
          return 0;
      function find_rectangle_path_with_large_area(main_group)
          var alll_path_array=[];
          var max_area_path=0;
          var max_path_item;
          for(big_path_index=0;big_path_index<main_group.pathItems.length;big_path_index++)
              max_area_path=Math.abs(main_group.pathItems[0].area);
              max_path_item=main_group.pathItems[0];
            if(Math.abs(main_group.pathItems[big_path_index].area)>max_area_path)
              max_path_item=main_group.pathItems[big_path_index];
                max_area_path=Math.abs(main_group.pathItems[big_path_index].area);
          for(sub_group_big_group_index=0;sub_group_big_group_index<main_group.groupItems.length;sub_group_big_group_index++)
              for(sub_group_path_item=0;sub_group_path_item<main_group.groupItems[sub_group_big_group_index].pathItems.length;sub_group_path_item++)
          //    alll_path_array.push(main_group.groupItems[sub_group_big_group_index].pathItems)
           if(Math.abs(main_group.groupItems[sub_group_big_group_index].pathItems[sub_group_path_item].area)>max_area_path)
                  max_path_item=main_group.groupItems[sub_group_big_group_index].pathItems[sub_group_path_item];
                max_area_path=Math.abs(main_group.groupItems[sub_group_big_group_index].pathItems[sub_group_path_item].area);
          return max_path_item;
      function group_connector_name()
              var arr=[];
              for(var group2=sourceDoc.layers[lays1].groupItems[group1].groupItems.length-1;group2>=0;group2--)
                  for(var text=0;text<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames.length;text++)
                      if(!sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames[text].contents.match(/[A,B,C,D,E,F,H,L,M,N,P,R,T][0-9]{1,3}$/)) continue;
                          arr.push(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].textFrames[text].contents)
              for(var text1=sourceDoc.layers[lays1].groupItems[group1].textFrames.length-1;text1>=0;text1--)
                  if(!sourceDoc.layers[lays1].groupItems[group1].textFrames[text1].contents.match(/[A,B,C,D,E,F,H,L,M,N,P,R,T][0-9]{1,3}$/)) continue;
                      arr.push(sourceDoc.layers[lays1].groupItems[group1].textFrames[text1].contents)
              if(arr.length==1)
                  sourceDoc.layers[lays1].groupItems[group1].name=arr[0]+":"
               else if(arr.length>1)
              var sorted_arr= removeDuplicates(arr)
      for(var k=0;k<sorted_arr.length;k++)
           if(k==0)
                    var test=sorted_arr[k]+":"
                else
                    var test=test+sorted_arr[k]+":"
        sourceDoc.layers[lays1].groupItems[group1].name=test
      else
      function removeDuplicates(num) {
        var x,
            len=num.length,
            out=[],
            obj={};
        for (x=0; x<len; x++) {
          obj[num[x]]=0;
        for (x in obj) {
          out.push(x);
        return out;
      function rename_fuse_group()
                  var fuse_path=0;
                          fuse_path=1;
                          break;
                  if(fuse_path==1)
                  var text_found=0;
                          for(var text=0;text<sourceDoc.layers[lays1].groupItems[group1].textFrames.length;text++)
                              if(sourceDoc.layers[lays1].groupItems[group1].textFrames[text].contents.match((/^[A-Z]*$/)))
                                  sourceDoc.layers[lays1].groupItems[group1].name=="FL-"+sourceDoc.layers[lays1].groupItems[group1].textFrames[text].contents+":";
                                  text_found=1;
                              else if(sourceDoc.layers[lays1].groupItems[group1].textFrames[text].contents.match((/^\d{1,4}$/)))
                                  sourceDoc.layers[lays1].groupItems[group1].name=="FUSE"+sourceDoc.layers[lays1].groupItems[group1].textFrames[text].contents+":";
                                   text_found=1;
                          if(text_found==0)
                                var count_error=0;
                               var group_main=sourceDoc.layers[lays1].groupItems[group1];
                        for(var error=0;error<group_main.groupItems.length;error++)
      textRef.contents ="Fuse Terminal Number is not present" ;
      count_error++;
      if(count_error==1)
      else
      function move_rectangle()
                 for(path2=sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems.length-1;path2>=0;path2--)
                     sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].moveAfter(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].parent)
      function Check_batteryline()
              for(var group1=sourceDoc.layers[lays1].groupItems.length-1;group1>=0;group1--)
                 if(path_type=="Rectangle Type 1" || path_type=="Rectangle Type 4" || path_type=="Rectangle Type 12" || path_type=="Rectangle Type 13" )
                     var x_bat=sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[0];
                     var y_bat=sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[1];
                     var x_bat1=sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[2];
                     var y_bat1=sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].visibleBounds[3];
                      for(var line=0;line<sourceDoc.layers[lays2].groupItems.length;line++)
                          for(var line1=0;line1<sourceDoc.layers[lays2].groupItems[line].pathItems.length;line1++)
                                var  path_type1 = type_of_path(sourceDoc.layers[lays2].groupItems[line].pathItems[line1]);
                 if(path_type1=="Line Type 1" || path_type1=="Line Type 3"  )
                     var x_line=sourceDoc.layers[lays2].groupItems[line].pathItems[line1].pathPoints[0].anchor[0];
                     var y_line=sourceDoc.layers[lays2].groupItems[line].pathItems[line1].pathPoints[0].anchor[1];
                     var x_line_end=sourceDoc.layers[lays2].groupItems[line].pathItems[line1].pathPoints[sourceDoc.layers[lays2].groupItems[line].pathItems[line1].pathPoints.length-1].anchor[0];
                     var y_line_end=sourceDoc.layers[lays2].groupItems[line].pathItems[line1].pathPoints[sourceDoc.layers[lays2].groupItems[line].pathItems[line1].pathPoints.length-1].anchor[1];
                     if(((x_line>x_bat) && (x_line<x_bat1) && (Math.abs(y_line-y_bat1))<=3)|| ((x_line_end>x_bat) && (x_line_end<x_bat1) && (Math.abs(y_line_end-y_bat1))<=3))
                         if(sourceDoc.layers[lays2].groupItems[line].pathItems[line1].parent.name=="AAA" || sourceDoc.layers[lays2].groupItems[line].pathItems[line1].parent.parent.name=="AAA")
                         else
                              for(var lays3=0;lays3<sourceDoc.layers.length;lays3++)
                      sourceDoc.layers[lays2].groupItems[line].pathItems[line1].moveToBeginning(sourceDoc.layers[lays1].groupItems[group1]);
      function Check_battery_AAA()
         for(var lays1=0;lays1<sourceDoc.layers.length;lays1++)
                 if(path_type=="Rectangle Type 1" || path_type=="Rectangle Type 4" ||  path_type=="Rectangle Type 12" )
                     check_battery_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1],group1)
      function check_battery_path(path_item,group_position)
          for(var group3=sourceDoc.layers[lays1].groupItems.length-1;group3>=0;group3--)
              for(var text=0;text<sourceDoc.layers[lays1].groupItems[group3].textFrames.length;text++)
                  if(sourceDoc.layers[lays1].groupItems[group3].textFrames[text].contents=="BATTERY" || sourceDoc.layers[lays1].groupItems[group3].textFrames[text].contents.slice(0,15)=="IGNITION SWITCH")
                     if(group3==group_position)
                         if(sourceDoc.layers[lays1].groupItems[group3].name=="AAA" || sourceDoc.groupItems[group3].parent.name=="AAA")
                         else
                             move_to_AAA_Battery(sourceDoc.layers[lays1].groupItems[group3]);
                             break;
      function move_to_AAA_Battery(group_item)
                     group_item.moveToBeginning(sourceDoc.layers[lays1].groupItems[group1])
      function remove_dot_pathitem()
                  if(sourceDoc.layers[lays1].groupItems[group1].groupItems.length==0 && sourceDoc.layers[lays1].groupItems[group1].textFrames.length==0)
                      var path_found=0;
                         if(path_type!="Anchor point")
                              path_found=1;
                 if(path_found==0)
                     sourceDoc.layers[lays1].groupItems[group1].remove();
      function color_empty_pathitem()
              if(sourceDoc.layers[lays1].name=="Layer 1" || sourceDoc.layers[lays1].name=="ILLUST")
           if(sourceDoc.layers[lays1].pathItems[path1].name!="DocumentResizeTextFrame")
               sourceDoc.layers[lays1].pathItems[path1].strokeColor=magentaColor3;
                sourceDoc.layers[lays1].pathItems[path1].strokeWidth=3;
      function check_text_empty_high()
                  if(sourceDoc.layers[lays1].groupItems[group1].groupItems.length==0 && sourceDoc.layers[lays1].groupItems[group1].pathItems.length==0)
                      if(sourceDoc.layers[lays1].groupItems[group1].textFrames.length==1)
                      if(sourceDoc.layers[lays1].groupItems[group1].textFrames[0].contents.slice(0,2)!="To")
                      if( sourceDoc.layers[lays1].groupItems[group1].textFrames[0].textRange.characterAttributes.size!=12)
                          sourceDoc.layers[lays1].groupItems[group1].textFrames[0].textRange.characterAttributes.fillColor=magentaColor6;
                          sourceDoc.layers[lays1].groupItems[group1].textFrames[0].textRange.characterAttributes.size==7.5
        function line_check1_unit()
          var count=0;
              mainloop12:
                          if(path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3" || path_type=="Line Type 4" || path_type=="Line Type 10" )
                                      var count_error=0;
      count_error++;
      if(count_error==1)
      else
      break mainloop12;
      function line_check1_unit_2()
                mainloop12:
                         break  mainloop12;
                              var count_error=0;
      count_error++;
      if(count_error==1)
      else
      function check_can_AAA_PATH()
                   if(path_type=="Line Type 10")
                       if(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].parent.name!="AAA"  )
                           sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].strokeColor=magentaColor3;
                           sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].strokeWidth=5;
      function check_AAA_path_BCM()
                   if(path_type=="Line Type 10" || path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3"  )
      function write_to_link()
              if(sourceDoc.layers[lays1].groupItems[group1].name=="Link")
                  if(sourceDoc.layers[lays1].groupItems[group1].textFrames[text].contents.slice(0,2)=="To")
                          var s=Checking_Link_group_properties_power(sourceDoc.layers[lays1].groupItems[group1].textFrames[text],sourceDoc.layers[lays1].groupItems[group1]);
                          if(s!=0 || s!=null)
                            var tr=get_file_name_id(s);
                            if(tr!=null && tr!=0)
                                  file_output.writeln(sourceDoc.name+","+"L"+","+"L"+","+"-"+","+"-"+","+tr+","+s)
         function Checking_Link_group_properties_power(text_frames_to_check,main)
          var result_to_link_check;
          var one_line_link_name_s="";
          var one_line_link_name="";
          var text_buffer_array="";
          if(text_frames_to_check!=null)
          if(text_frames_to_check.lines.length>1)
          one_line_link_name=Make_one_line(text_frames_to_check);
                 var text_buffer_array = one_line_link_name[0];
              for( array_iteration_value = 1 ;array_iteration_value<one_line_link_name.length; array_iteration_value++)
                 text_buffer_array = text_buffer_array+one_line_link_name[array_iteration_value];
          one_line_link_name_s=one_line_link_name.toString();
          else if(text_frames_to_check.lines.length==1)
          text_buffer_array=text_frames_to_check.contents;
                  result_to_link_check =  title_checking_link(text_buffer_array);
                              if(result_to_link_check != 0 || result_to_link_check != null )
                              return result_to_link_check;
                               else
                                            if(text_frames_to_check.parent.name == "Link")
                                             var x_axis=Math.abs(Math.round(text_frames_to_check.textPath.pathPoints[0].anchor[0]));
                        var y_axis=Math.abs(text_frames_to_check.textPath.pathPoints[0].anchor[1]);
                        var r=main.groupItems.add();
                          r.name=main.name+"Error:"
                                      var textRef = r.textFrames.add();
                                      textRef.contents =text_buffer_array+"_Mismatch";
      r.moveToEnd(main);
                                              return 0;
        function Make_one_line(SM_name_near_connector)
          var temperory_index = 0;
          var temp,internaltextframe_index;
          var internaltextframe;
          internaltextframe = [];
          var internaltextframe_2;
          internaltextframe_2 = [];
         internaltextframe_index=0;
         var count_buff = 0;
         var temperory_string = "";
              for(line_len=0;line_len<SM_name_near_connector.lines.length;line_len++)
                  internaltextframe[internaltextframe_index] = SM_name_near_connector.lines[line_len].contents;
                  internaltextframe_index++;
          for(assign_textframe = 0;assign_textframe<internaltextframe.length;assign_textframe++)
              internaltextframe_2[assign_textframe] = [];
              if(internaltextframe.length>1)
            for(text_iteration = 0;text_iteration<internaltextframe.length;text_iteration++)
               var space_count_flag = 0;
               if(internaltextframe[text_iteration][internaltextframe[text_iteration].length-1] == " " )
                   for(internal_text_frame_length = internaltextframe[text_iteration].length-1;internal_text_frame_length>=0;internal_text_frame_length--)
                       if(internaltextframe[text_iteration][internal_text_frame_length] == " " )
                          space_count_flag++;
                      else
                          break;
               for(internal_text_frame_length = 0;internal_text_frame_length< internaltextframe[text_iteration].length-space_count_flag;internal_text_frame_length++)
                   internaltextframe_2[text_iteration][internal_text_frame_length] = internaltextframe[text_iteration][internal_text_frame_length];
                  else
                    for(internal_text_frame_length = 0;internal_text_frame_length< internaltextframe[text_iteration].length;internal_text_frame_length++)
              for(i=0;i<internaltextframe_2.length;i++)
              var temp_str,temp_str_space;
              if(i==0 )
                  space_value = String.fromCharCode (32);
                  temp_str = internaltextframe_2[i];
                  temp_str = temp_str.concat (space_value);
              else if(i == internaltextframe_2.length-1 )
                 internaltextframe_2[i].toString();
                  temp_str = temp_str.concat (internaltextframe_2[i]);
              else
                temp = temp_str.concat (internaltextframe_2[i],space_value);
                  temp_str = temp;
        temp_str = remove_hyphen(temp_str);
           temperory_string = temp_str;
      else
          temperory_string = SM_name_near_connector.contents;
      return temperory_string;
        function title_checking_link(title_from_ai_file)
              title_new_ai = title_from_ai_file.toLowerCase();
              var title_ID="";
              var title_ID_with_to="";
              for(title_check_loop = 0;title_check_loop< fileArray_title.length; title_check_loop++)
                    if(fileArray_title[title_check_loop][0]!=null)
                      title_ID = fileArray_title[title_check_loop][0].toLowerCase();
                      title_ID_with_to = "to " + title_ID;
                      if(title_ID_with_to ==    title_new_ai)
                              return fileArray_title[title_check_loop][0];
          return 0;
        function get_file_name_id(text)
                      if(fileArray_title[title_check_loop][0]==text)
                              return fileArray_title[title_check_loop][1];
            function remove_hyphen(SM_name_with_hyphen)
          var SM_name_with_hyphen_buffer = [];
       var hyphenchange_count = 0;
      for(assign_textframe = 0;assign_textframe<SM_name_with_hyphen.length;assign_textframe++)
          if(SM_name_with_hyphen[assign_textframe-1] == "-" &&   SM_name_with_hyphen[assign_textframe] == " " )
                 SM_name_with_hyphen_buffer[assign_textframe] =  SM_name_with_hyphen[assign_textframe+1];
           hyphenchange_count++;
          else
              SM_name_with_hyphen_buffer[assign_textframe - hyphenchange_count ] =  SM_name_with_hyphen[assign_textframe]
        return SM_name_with_hyphen_buffer;
      function autoColor_updation()
          for(var group1=0;group1<sourceDoc.groupItems.length;group1++)
              for(var path1=0;path1<sourceDoc.groupItems[group1].pathItems.length;path1++)
                  var path_items_r=sourceDoc.groupItems[group1].pathItems[path1];
                  if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 && path_items_r.fillColor.magenta>=55 && path_items_r.fillColor.magenta<=75 && path_items_r.fillColor.yellow>=50 && path_items_r.fillColor.yellow<=70 && path_items_r.closed==true && path_items_r.strokeDashes.length==0
                 && (Math.round(path_items_r.area))!=25 && (Math.round(path_items_r.area))!=6)
                      path_items_r.strokeWidth=0.567;
                      path_items_r.strokeColor.black=100;
                       path_items_r.strokeColor.cyan=0;
                        path_items_r.strokeColor.magenta=0;
                         path_items_r.strokeColor.yellow=0;
                         path_items_r.fillColor.cyan=0;
                         path_items_r.fillColor.magenta=70;
                         path_items_r.fillColor.yellow=60;
                         path_items_r.fillColor.black=0;
                     else if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 && path_items_r.fillColor.magenta>=0 && path_items_r.fillColor.magenta<=5 && path_items_r.fillColor.yellow>=10 && path_items_r.fillColor.yellow<=35 &&  path_items_r.closed==true && path_items_r.strokeDashes.length==0
                         path_items_r.fillColor.magenta=0;
                         path_items_r.fillColor.yellow=25;
                     else if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 && path_items_r.fillColor.magenta>=10 && path_items_r.fillColor.magenta<=35 && path_items_r.fillColor.yellow>=10 && path_items_r.fillColor.yellow<=35 &&  path_items_r.closed==true && path_items_r.strokeDashes.length==0
                         path_items_r.fillColor.magenta=25;
                      else if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 && path_items_r.strokeColor.magenta>=25 && path_items_r.strokeColor.magenta<=60 && path_items_r.strokeColor.cyan>=75 && path_items_r.strokeColor.cyan<=100  && path_items_r.strokeDashes.length==2
                      && path_items_r.filled==false)
                      path_items_r.strokeColor.black=0;
                       path_items_r.strokeColor.cyan=100;
                        path_items_r.strokeColor.magenta=50;
                        path_items_r.filled=false;
                     else if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 && path_items_r.strokeColor.black>=75 && path_items_r.strokeColor.black<=100  && path_items_r.strokeDashes.length==2
                     else if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 && path_items_r.strokeColor.black>=75 && path_items_r.strokeColor.black<=100 &&  path_items_r.closed==true && path_items_r.strokeDashes.length==0 &&  path_items_r.pathPoints.length==4
                                    else if((Math.round(path_items_r.strokeWidth*1000))>=500 && (Math.round(path_items_r.strokeWidth*1000))<=580 &&  path_items_r.closed==true  &&  path_items_r.pathPoints.length==4
                    && (Math.round(path_items_r.area))==25 && path_items_r.strokeColor.black>=75 && path_items_r.strokeColor.black<=100 && path_items_r.fillColor.black>=75 && path_items_r.fillColor.black<=100)
                         path_items_r.fillColor.yellow=0;
                         path_items_r.fillColor.black=100;
                    && (Math.round(path_items_r.area))==25 && path_items_r.strokeColor.black>=75 && path_items_r.strokeColor.black<=100 && path_items_r.fillColor.black>=0 && path_items_r.fillColor.black<=5)
                    && (Math.round(path_items_r.area))==25 && path_items_r.strokeColor.cyan>=75 && path_items_r.strokeColor.cyan<=100 && path_items_r.strokeColor.magenta>=25 && path_items_r.strokeColor.magenta<=50 && path_items_r.fillColor.cyan>=75 && path_items_r.fillColor.cyan<=100
                    && path_items_r.fillColor.magenta>=25 && path_items_r.fillColor.magenta<=50)
                         path_items_r.fillColor.cyan=100;
                         path_items_r.fillColor.magenta=50;
                    && (Math.round(path_items_r.area))==25 && path_items_r.strokeColor.cyan>=75 && path_items_r.strokeColor.cyan<=100 && path_items_r.strokeColor.magenta>=25 && path_items_r.strokeColor.magenta<=50 && path_items_r.fillColor.cyan>=0 && path_items_r.fillColor.cyan<=5
                    && path_items_r.fillColor.magenta>=0 && path_items_r.fillColor.magenta<=5)
                    && (Math.round(path_items_r.area))==25 && path_items_r.strokeColor.yellow>=75 && path_items_r.strokeColor.yellow<=100 && path_items_r.strokeColor.magenta>=75 && path_items_r.strokeColor.magenta<=100 && path_items_r.fillColor.yellow>=75 && path_items_r.fillColor.yellow<=100
                    && path_items_r.fillColor.magenta>=75 && path_items_r.fillColor.magenta<=100)
                        path_items_r.strokeColor.magenta=100;
                         path_items_r.strokeColor.yellow=100;
                         path_items_r.fillColor.magenta=100;
                         path_items_r.fillColor.yellow=100;
                    && (Math.round(path_items_r.area))==25 && path_items_r.strokeColor.yellow>=75 && path_items_r.strokeColor.yellow<=100 && path_items_r.strokeColor.magenta>=75 && path_items_r.strokeColor.magenta<=100 && path_items_r.fillColor.yellow>=0 && path_items_r.fillColor.yellow<=5
                      else if((Math.round(path_items_r.strokeWidth*1000))>=1100 && (Math.round(path_items_r.strokeWidth*1000))<=1700 && path_items_r.strokeColor.magenta>=25 && path_items_r.strokeColor.magenta<=60 && path_items_r.strokeColor.cyan>=75 && path_items_r.strokeColor.cyan<=100  && path_items_r.strokeDashes.length==0
                        && path_items_r.height!=6 )
                      path_items_r.strokeWidth=1.417;
                        && path_items_r.height==6 )
                        else if((Math.round(path_items_r.strokeWidth*1000))>=1100 && (Math.round(path_items_r.strokeWidth*1000))<=1700 && path_items_r.strokeColor.black>=75 && path_items_r.strokeColor.black<=100  && path_items_r.strokeDashes.length==0)
                      else if((Math.round(path_items_r.strokeWidth*1000))>=1100 && (Math.round(path_items_r.strokeWidth*1000))<=1700  && path_items_r.strokeColor.magenta>=75 && path_items_r.strokeColor.magenta<=100 && path_items_r.strokeColor.yellow>=75 && path_items_r.strokeColor.yellow<=100  && path_items_r.strokeDashes.length==0)
                       else if((Math.round(path_items_r.strokeWidth*1000))>=1100 && (Math.round(path_items_r.strokeWidth*1000))<=1700  && path_items_r.strokeColor.magenta>=0 && path_items_r.strokeColor.magenta<=5 && path_items_r.strokeColor.yellow>=0 && path_items_r.strokeColor.yellow<=5  && path_items_r.strokeDashes.length==2)
                      path_items_r.strokeWidth=1.420;
         else if((Math.round(path_items_r.strokeWidth*1000))>=2100 && (Math.round(path_items_r.strokeWidth*1000))<=3000  && path_items_r.strokeColor.black>=75 && path_items_r.strokeColor.black<=100   && path_items_r.strokeDashes.length==0)
                      path_items_r.strokeWidth=2.268;
                     else
       function list_connector_names()
              for(var group1=0;group1<sourceDoc.layers[lays1].groupItems.length;group1++)
                   var arr=[];
                  if(sourceDoc.layers[lays1].groupItems[group1].name!="AAA")
                       if(check4(sourceDoc.layers[lays1].groupItems[group1].name))
              var array=sourceDoc.layers[lays1].groupItems[group1].name.split(":")
              if(array.length==2)
                  var text2=get_connector_name_cil(array[0]);
                  if(text2=="WIRE TO WIRE" || text2=="BODY GROUND" || text2=="ENGINE GROUND")
                     file_output1.writeln(array[0]+","+text2);
                  else
                  var text3=match_AAA_text(text2);
                  if(text3==1)
                     file_output1.writeln(array[0]+","+text2+","+sourceDoc.name)
                 else
                     var text_found=0;
                     for(var text_4=0;text_4<sourceDoc.layers[lays1].groupItems[group1].textFrames.length;text_4++)
                           if(sourceDoc.layers[lays1].groupItems[group1].textFrames[text_4].lines.length>1)
                              one_line_link_name=Make_one_line(sourceDoc.layers[lays1].groupItems[group1].textFrames[text_4]);
      else if(sourceDoc.layers[lays1].groupItems[group1].textFrames[text_4].lines.length==1)
          text_buffer_array=sourceDoc.layers[lays1].groupItems[group1].textFrames[text_4].contents;
      var text_6=text_buffer_array.replace(/\s/g, "")
      var text_7=array[0].replace(/\s/g, "")
      if(text_6==text_7)
          text_found=1;
        for(var group3=0;group3<sourceDoc.layers[lays1].groupItems[group1].groupItems.length;group3++)
                         for(var text_1=0;text_1<sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames.length;text_1++)
                              if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].lines.length>1)
                              one_line_link_name=Make_one_line(sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1]);
      else if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].lines.length==1)
          text_buffer_array=sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].contents;
      if(text_6==text_7)
          text_found=1;
      if( text_found==0)
                     mainloop3:
                             if(!sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].contents.match(/[A,B,C,D,E,F,H,L,M,N,P,R,T][0-9]{1,3}$/)) continue;
                             if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].contents==array[0])
                             sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].textRange.characterAttributes.fillColor=magentaColor6;
                             sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].textRange.characterAttributes.size=10;
                             break mainloop3;
             else
         else if(array.length>2)
             for(var k=0;k<array.length-1;k++)
                   var text2=get_connector_name_cil(array[k]);
                     file_output1.writeln(array[k]+","+text2);
                  else
                  if(text3==1)
                     file_output1.writeln(array[k]+","+text2+","+sourceDoc.name)
                 else
                       var text_found=0;
      var text_7=array[k].replace(/\s/g, "")
      if(text_6==text_7)
          text_found=1;
      if(text_6==text_7)
          text_found=1;
      if( text_found==0)
                     mainloop3:
                               if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text_1].contents==array[k])
                             break mainloop3;
             else
                  file_output1.writeln(array[k]+","+text2+","+sourceDoc.name);
      else
       function check4 (nme)
              return false; }
          return true;
      function get_connector_name_cil(text)
           for(csv_iter = 0;csv_iter < fileArray_SM_name.length; csv_iter++)
              if(text== fileArray_SM_name[csv_iter][0])
                  return fileArray_SM_name[csv_iter][1]
      function match_AAA_text(text3)
              for(var group3=0;group3<sourceDoc.layers[lays2].groupItems.length;group3++)
                  if(sourceDoc.layers[lays2].groupItems[group3].name=="AAA")
                      var text_found=0;
                      var arr1=[];
                     mainloop1:
                      for(var text4=0;text4<sourceDoc.layers[lays2].groupItems[group3].textFrames.length;text4++)
                          if(sourceDoc.layers[lays2].groupItems[group3].textFrames[text4].lines.length>1)
                              one_line_link_name=Make_one_line(sourceDoc.layers[lays2].groupItems[group3].textFrames[text4]);
      else if(sourceDoc.layers[lays2].groupItems[group3].textFrames[text4].lines.length==1)
          text_buffer_array=sourceDoc.layers[lays2].groupItems[group3].textFrames[text4].contents;
      var text5=text3.replace(/\s/g, "")
      var text6=text_buffer_array.replace(/\s/g, "")
      if(text5==text6)
          text_found=1;
          break mainloop1;
      if(text_found==0 )
          return 0;
      else
      return 1;
      function type_of_path(check_path_prop)
          stroke_weight = Math.round(check_path_prop.strokeWidth*1000);
          stroke_C = Math.round(check_path_prop.strokeColor.cyan);
          stroke_K = Math.round(check_path_prop.strokeColor.black);
          stroke_M = Math.round(check_path_prop.strokeColor.magenta);
          stroke_Y = Math.round(check_path_prop.strokeColor.yellow);
          Fill_C = Math.round(check_path_prop.fillColor.cyan);
          Fill_K = Math.round(check_path_prop.fillColor.black);
          Fill_M = Math.round(check_path_prop.fillColor.magenta);
          Fill_Y = Math.round(check_path_prop.fillColor.yellow);
             path_height = Math.round(check_path_prop.height);
          path_area = Math.round(check_path_prop.area);
          path_area_rect = Math.round(check_path_prop.width*check_path_prop.height);
          path_area_circle= Math.round(3.14*(check_path_prop.height/2)*(check_path_prop.height/2));
               if(path_area<0)
            path_area*=-1;
         if(path_height<0)
            path_height*=-1;
              if(check_path_prop.filled == true)
                       Filled_or_not = 2;
               else
                      Filled_or_not = 1;
               if(check_path_prop.stroked == true)
                       Stroked_or_not = 2;
               else
                      Stroked_or_not = 1;
                  if(check_path_prop.closed == true)
                 Is_closed=1;
             else
                 Is_closed=0;
                            if(check_path_prop.strokeDashes.length == 2)
                  Is_dashed = 1;
                  stroke_dash1=Math.round(check_path_prop.strokeDashes[0]);
                  stroke_dash2=Math.round(check_path_prop.strokeDashes[1]);
                  else if(check_path_prop.strokeDashes.length  == 0)
                     Is_dashed = 0;
                   else
                          Is_dashed = -1;
        if((check_path_prop.pathPoints.length == 1) &&(stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100)  && (Filled_or_not ==1) && (stroke_weight==1000))
        return("Anchor point");//points
        if(path_area==129)
        if((stroke_weight>=560 && stroke_weight<=570)  && (stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100) && (Is_closed==1) && (Filled_or_not ==1))
        return("Rounded Rectangle");//callout
        if((path_area==path_area_rect )&&(stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) )
        if( Fill_C == 0 && Fill_M == 70 && Fill_Y == 60 && Fill_K ==0)
          return("Rectangle Type 1"); //Battery Color
        else if ( Fill_C == 0 && Fill_M == 0 && Fill_Y == 25 && Fill_K == 0)
          return("Rectangle Type 2");//unit color
        else if ( Fill_C == 0 && Fill_M == 25 && Fill_Y == 25 && Fill_K == 0)
          return("Rectangle Type 3");//fuse color
        else if(Filled_or_not == 1 && (Is_dashed==0) && check_path_prop.pathPoints.length == 4 )
            return("Rectangle Type 4");//ignition swithch
       if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 25 && Fill_K == 0))
          return("Rectangle Type 10"); //rectangle Color
           if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) && (Fill_C == 0 && Fill_M == 70 && Fill_Y == 60 && Fill_K == 0))
          return("Rectangle Type 12"); //rectangle Color
          if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 100) && (stroke_M == 50) && (stroke_Y ==0 )&& (stroke_K == 0) && (Is_dashed==1) && (Filled_or_not ==1) )
              return("Rectangle Type 5");//shield unit
        if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) && (Is_dashed==1) && (Filled_or_not ==1) )
              return("Rectangle Type 11");//shield unit
          if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) && ( Fill_C == 0) && (Fill_M == 0) && (Fill_Y == 0) && (Fill_K ==0  ) && (path_area!=25) )
              return("Rectangle Type 6");//Varient unit
          if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) && (Filled_or_not ==1) && check_path_prop.pathPoints.length == 4 )
              return("Rectangle Type 13");//Varient unit
           if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) && (Filled_or_not ==1))
              return("Rectangle Type 7");//Varient unit
            if((stroke_weight>=560 && stroke_weight<=570)&& (stroke_C == 0) && (stroke_M == 0) && (stroke_Y ==0 )&& (stroke_K == 100) &&(Is_closed==1) && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K == 100) && (check_path_prop.pathPoints.length==3) )
              return("Rectangle Type 8");//Triangle
            if((Filled_or_not ==1) && (Stroked_or_not ==1))
              return("GuideLine");//Varient unit
        if((path_area==25)&&(Is_closed==1) && (stroke_weight>=560 && stroke_weight<=570))
        if((stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100) && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K == 100))
        return("Circle Type 1");//circle filled
        else if((stroke_C == 100 && stroke_M == 50 && stroke_Y == 0 && stroke_K == 0) && (Fill_C == 100 && Fill_M == 50 && Fill_Y == 0 && Fill_K == 0))
        return("Circle Type 2");//Ground unit color
        else if((stroke_C == 0 && stroke_M == 100 && stroke_Y == 100 && stroke_K == 0) && (Fill_C == 0 && Fill_M == 100 && Fill_Y == 100 && Fill_K == 0))
        return("Circle Type 3");//battery circle color
        else if((stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100) && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K == 0))
        return("Circle Type 4");//unit not filled
        else if((stroke_C == 100 && stroke_M == 50 && stroke_Y == 0 && stroke_K == 0)&& (Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K == 0))
        return("Circle Type 5");//ground not filled
        else if((stroke_C == 0 && stroke_M == 100 && stroke_Y == 100 && stroke_K == 0) && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K == 0))
        return("Circle Type 6");// Battery Unit filled
        if((path_area==6)&&(Is_closed==1) && (stroke_weight>=560 && stroke_weight<=570))
        return("Circle Type 8");//circle filled
        return("Circle Type 9");//Ground unit color
        return("Circle Type 10");//battery circle color
          else if((stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100) && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 25 && Fill_K == 0))
        return("Circle Type 11")
      // Checking Line Type
            if((stroke_weight>=1410 && stroke_weight<=1420 )&& (Filled_or_not == 1) && (Is_closed==0))
        if(Is_dashed== 0)
            if(stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100)
          return("Line Type 1");//unit line color
          else if (stroke_C == 100 && stroke_M == 50 && stroke_Y == 0 && stroke_K == 0 && (path_height!=6) )
          return("Line Type 2");//ground line color
              else if (stroke_C == 100 && stroke_M == 50 && stroke_Y == 0 && stroke_K == 0 && (path_height==6) )
          return("Line Type 12");//ground line color
          else if(stroke_C == 0 && stroke_M == 100 && stroke_Y == 100 && stroke_K == 0)
          return("Line Type 3");//battery line color
        else if(Is_dashed==1)
          if((stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 0)  && (stroke_dash1==3 && stroke_dash2==6))
        return("Line Type 4");//can line color
        if((stroke_weight>=560 && stroke_weight<=570 )&& (Filled_or_not == 1)&& (Is_closed==0))
        if (Is_dashed== 0)
          return("Line Type 5");
              else if((stroke_C == 100 && stroke_M == 50 && stroke_Y == 0 && stroke_K == 0))
          return("Line Type 6");
        else if(Is_dashed== 1)
                if((stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100) )
          return("Line Type 7");
       if((stroke_weight>=560 && stroke_weight<=570 )&& (Is_closed==0))
        if (Is_dashed== 0)
        if(stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100 && Fill_C == 0 && Fill_M == 0 && Fill_Y == 25 && Fill_K == 0)
              else if((stroke_C == 100 && stroke_M == 50 && stroke_Y == 0 && stroke_K == 0 && Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K == 100))
       if((stroke_weight>=560 && stroke_weight<=570)&& (Is_closed==0) && (Is_dashed== 0))
        if(stroke_C == 0 && stroke_M == 0 && stroke_Y == 0 && stroke_K == 100 && (Fill_C == 0 && Fill_M == 0 && Fill_Y == 0 && Fill_K ==100))
          return("Line Type 8");
        if((stroke_weight>=2260 && stroke_weight<=2268)&& (Filled_or_not == 1) && (Is_closed==0))
          return("Line Type 10");
       else
               return("Incorrect Path Properties");
        • 1. Re: Adobe Illustrator not responding !!
          Silly-V Adobe Community Professional
          That is a lot of code, my own brain stopped responding after  just a few lines. My thought is- your files over 900KB may have some different art inside which may conflict with some of your script logic and cause an infinite loop somewhere.
          • 2. Re: Adobe Illustrator not responding !!
            williamadowling Level 4
            i have carpal tunnel just from reading blocks of code like this:
            for (var group4 = 0; group4 < sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems[group3].groupItems.length; group4++)
              if (sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems[group3].groupItems[group4].name.slice(0, 15) == "connectornumber")
                sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].groupItems[group3].moveToBeginning(sourceDoc.layers[lays1]);
                break;
            I'm curious why you seem to be minimizing the number of variables you use. In my opinion writing things this way makes it very difficult to debug anything.
            But to the root of your question, my guess is that the issue is related to some of your functions that have loops nested 4 or 5+ deep. And after spot checking several different functions, almost all of them start by looping all of the layers in the document. So it looks like every time you want to do something different, or check for another case, you start back at the beginning and begin looping through everything again. In files of any significant size, this is really going to eat away at resources and cause the kind of issues you're describing.
            It's quite difficult to figure out what is actually causing the problem here because i don't have the foggiest idea what these 6600 lines of code are trying to do (and it would take me a week at least to sift through it and figure that out). Perhaps more information on what you're trying to do might help. It's hard to say whether Silly-V is right that there's an infinite loop in there somewhere, but it's possible that there's a "virtual infinite loop" (just made that up) as a result of repeating deeply nested loops over and over causing all the resources to be gobbled up and then illustrator just can't cope.
            **EDIT**
            A possible culprit that i just noticed is that several times throughout the script you run loops using the loop variable "array_iteration_value" and you declare this variable as a global variable, like so:
            for(array_iteration_value = 1; array_iteration_value < something; array_iteration_value++)
                 //do something
            instead of using var to declare that variable within the current scope like so:
            for(var array_iteration_value = 1; array_iteration_value < something; array_iteration_value++)
                 //do something
            Perhaps some of your loop variables are tripping over one another and resulting in unexpectedly high iterations of some loops?
            • 3. Re: Adobe Illustrator not responding !!
              karth80472045 Level 1
              thank you so much for your advice and i am a beginner in java script so only i use this kind of initialisation.
              • 4. Re: Adobe Illustrator not responding !!
                totally understand. Silly-V once politely chastised me for the same thing because i was getting errors as a result of doing the same thing.. in my case i was using nested loops where some loop variables overlapped and everything came crashing down.
                I certainly wasn't trying to be mean or judgmental. Just seeing a lot of the mistakes that i did when i first started. though i never wrote anything nearly as complex as this appears to be, even to this day. The fact that you have this much code working on any file at all is a tremendous accomplishment for a beginner.
                perhaps update your loops by initializing the loop variable with "var" and see whether that helps anything. The only other thing i can think of that might be relatively quick or easy, at least to glean some insight as to where things are going wrong, is to add some log messages to the beginning and end of each function, so you can see what was happening right before the script got hung up. that might help narrow it down to a few places rather than just kind of being completely in the dark.
                • 5. Re: Adobe Illustrator not responding !!
                  Another likely culprit is this function here:
                  group_name_normal()
                  this function loops every single pathItem in the document. this is almost always a bad idea because of the sheer number of pathItems that can exist in even a moderately sized document. Especially since it appears you're working with complex technical drawings, perhaps exploded views of automobile construction?
                  • 6. Re: Adobe Illustrator not responding !!
                    Thank you so much for spending the time with my code , now i have got the logic how to write the code, now i modifying all the functions once it is completed i will let you know if there is any issues. if there is any issues i will contact you.
                    • 7. Re: Adobe Illustrator not responding !!
                      hello sir,
                      now it is working fine but  i am getting parm error in illustrator, is there any solution to resolve parm error
                      • 8. Re: Adobe Illustrator not responding !!
                        Typically that error is caused by corrupted properties under the hood (for example, trying to read the 'name' property of a layer or groupItem). This error happens more frequently when you are opening/closing many files during execution, (for example, trying to batch a folder of files where the script opens one or more files, does some modification, then closes the files, and then opens one or more files, etc.)
                        If the parm error is happening randomly and unpredictably, then it's likely that the above situation is the culprit. If it seems to be happening in the exact same spot every time, then there could be some other error in your code.. I don't know of all of the possible ways to generate this error, but a few examples are as follows:
                        • trying to remove the only artboard in the document (a document must contain between 1 and 100 artboards)
                        • trying to add the 101st artboard (see above)
                        • trying to add a new artboard with invalid bounds. (see example below)
                          • var myArtboard = app.activeDocuments.artboards.add([0,0,50,50]);
                          • the artboard bounds are measured like this: [left,top,right,bottom]
                          • so in the example above, the bottom coordinate is higher than the top coordinate (top is 0, bottom is 50).
                          • to make this work, you'd need to make the last bound negative ([0,0,50,-50])
                        • Trying to duplicate/move an item from one document directly into a group in another document.. unfortunately, you need to duplicate the item into the other document and THEN move it into the desired group.. this particular issue is a thorn in my side for the last several days for a script that i'm working on... frustrating.
                        There are more ways to reliably generate this error i'm sure, but i cannot recall them at this time.
                        Hope this is helpful. Unfortunately the PARM/MRAP errors are NOT helpful as they don't say anything about why the error occurred.
                        • 9. Re: Adobe Illustrator not responding !!
                          Thank you very much sir!!!
                          function unlock()
                          for (var i = sourceDoc.pageItems.length - 1; i >= 0; i--) {
                              pItem = sourceDoc.pageItems[i];
                              if (pItem.locked == true) {
                                  pItem.locked = false;
                          or
                          function unlock ( items ) {
                              var i = items.length;
                              if ( i ) {
                               while ( i-- ) {
                                      items[i].locked = false;
                                      if ( items[i].typename === 'GroupItem' ) {
                                          unlock( items[i].pageItems );              }
                                          else if ( items[i].typename === 'Layer' ) {
                                             unlock( items[i].layers );
                          i am getting parm error on unlock pageitems if it is locked, i have tried in both ways but it shows parm error after looping for several files in a folder.
                          • 10. Re: Adobe Illustrator not responding !!
                            hmmm. it's hard to say what the issue might be. But as a general rule, it's always a bad idea to run a loop on sourceDoc.pageItems.length.
                            Illustrator is sort of wonky with scope when it comes to elements of a document. Let's consider a document that has two rectangles that are grouped together, and this group lives on the first layer ( layer[0] ). So one group, containing only two simple pathItems.
                            If you print out the length of the pathItems on that layer like so:
                            sourceDoc.layers[0].pathItems.length;
                            you will get 0. This is because in the scope of layers[0], there are no pathItems, there's only one groupItem. However, if you print the length of pathItems in the document like so:
                            sourceDoc.pathItems.length;
                            you'll get 2. When you look at any property of the document object as a whole (pathItems, groupItems, compoundPathItems, textFrames, placedItems.... By the way, pageItems encompasses all of these) you will see every single one that exists in the document, even if it is nested 100 levels deep inside different groups or layers.
                            To further illustrate, let's expand the example above. again, with a single layer in the document, on that layer you have 1 simple path item, and one group item that contains 100 subgroups, and each subgroup contains two compound paths that are each comprised of two pathItems.
                            sourceDoc.layers[0].pathItems.length; //returns 1
                            sourceDoc.pathItems.length; //returns 201
                            and lastly, since pageItems encompasses all of the different elements that could be in a document, the numbers get even weirder. Using the exact same example (one path, one group with 100 groups), this is what those numbers would be:
                            sourceDoc.layers[0].pageItems.length; //returns 2, one pathItem and one groupItem
                            sourceDoc.pageItems.length; //returns 302, one pathItem, one groupItem, 100 compoundPathItems, 200 pathItems (two pathItems in each compoundPathItem).
                            So as you can see, every single constituent component of the document is counted when you run a loop over the pageItems in the context of the document object. And you can see that with an extremely simple document (1 layer, 1 path, 1 group) we're already up to 300+ individual items in the document. It's not difficult, especially when working with technical drawings or other complex artwork, to end up with 100,000+ individual items in the document. Not only does this take a long time to process, it eats up memory and makes you more susceptible to parm errors.
                            All that to say, your second version of the unlock() function is much closer to the mark. You should be predetermining what should be unlocked, then pass in only those items to the unlock function. For example, your process dictates that everything that is contained in the layer called "My Locked Stuff" needs to be unlocked. So instead of accessing every pageItem in the document, you'll pass in the pageItems of the layer "My Locked Stuff" to the unlock function, so that only those things will be processed. Now, Since you're passing an array of pageItems, you don't need the conditional statement that determines whether the item is a layer. you already know it's a pageItem, therefore it cannot be a layer. If you're worried about potential sub layers that could have art on them that you need to unlock also, there's a different way to do that. Here's how i'd tackle this problem:
                            function unlockLayer(layer)
                                //check for any subLayers
                                var layLen = layer.layers.length;
                                for(var x=0;x<layLen;x++)
                                    layer.layers[x].locked = false;
                                    unlockLayer(layer.layers[x]);
                                //all the sublayers have been unlocked,
                                //now unlock all pageItems recursively
                                var itemLen = layer.pageItems.length;
                                for(var x=0;x<itemLen;x++)
                                    unlockItem(layer.pageItems[x]);
                            function unlockItem(item)
                                if(item.typename === "GroupItem")
                                    item.locked = false;
                                    var itemLen = item.pageItems.length;
                                        unlockItem(item.pageItems[x]);
                                else
                            unlockLayer(app.activeDocument.layers["My Locked Stuff"]);
                            • 11. Re: Adobe Illustrator not responding !!
                              Thanks for the reply , i will check and let you know
                              • 12. Re: Adobe Illustrator not responding !!
                                Hello sir ,
                                parm error occurs after execution of 5 files out of 170 files in a folder , i have tried this one from this link[Illustrator] Relaunch AI to aviod "PARM" error · GitHub  but it process only one AI file in a folder other files it is not executing.
                                This is my tried code
                                var magentaColor6= new CMYKColor();
                                magentaColor6.cyan = 75;//orange
                                magentaColor6.magenta =100;
                                magentaColor6.yellow = 0;
                                magentaColor6.black = 0;
                                var magentaColor10 = new CMYKColor();
                                magentaColor10.cyan = 18.43;
                                magentaColor10.magenta =100;
                                magentaColor10.yellow = 100;
                                magentaColor10.black = 10.2;//Brown
                                var magentaColor9 = new CMYKColor();
                                magentaColor9.cyan = 0;
                                magentaColor9.magenta =99;
                                magentaColor9.yellow = 0;
                                magentaColor9.black = 0; //magenta 1
                                var magentaColor7 = new CMYKColor();
                                magentaColor7.cyan = 0;
                                magentaColor7.magenta =97;
                                magentaColor7.yellow = 0;
                                magentaColor7.black = 0;//magenta 2
                                var magentaColor8 = new CMYKColor();
                                magentaColor8.cyan = 0;
                                magentaColor8.magenta =95;
                                magentaColor8.yellow = 0;
                                magentaColor8.black = 0;//magenta 3
                                var magentaColor4 = new CMYKColor();
                                magentaColor4.cyan = 60.39;
                                magentaColor4.magenta =32.94;
                                magentaColor4.yellow = 100;
                                magentaColor4.black = 14.51;//Green
                                var magentaColor1 = new CMYKColor();
                                magentaColor1.cyan = 56.47;
                                magentaColor1.magenta =0;
                                magentaColor1.yellow = 63.92;
                                magentaColor1.black = 0;//LIGHT GREEN
                                var magentaColor2 = new CMYKColor();
                                magentaColor2.cyan = 19.61;
                                magentaColor2.magenta =100;
                                magentaColor2.yellow = 69.02;
                                magentaColor2.black = 8.63;//Dark Brown
                                var magentaColor3 = new CMYKColor();
                                magentaColor3.cyan = 0;
                                magentaColor3.magenta =69.8;
                                magentaColor3.yellow = 100;
                                magentaColor3.black = 0;//light orange
                                fileArray_SM_name = get_csvfile("Select CIL CSV List");
                                  fileArray_title = get_csvfile("Select ID List CSV");
                                   function get_csvfile(Str_File)
                                    var csv_file;
                                    csv_file = File.openDialog (Str_File);
                                    if(!csv_file.exists)
                                        return;
                                     else
                                       fileArray_buffer = save_elements(csv_file);
                                    return fileArray_buffer;
                                function save_elements( fileObj )
                                        var thisLine, csvArray;
                                         fileArray_save_elements =[];
                                          fileObj.open( 'r' );
                                         while( !fileObj.eof )
                                                   thisLine = fileObj.readln();
                                                   csvArray = thisLine.split( ',' );
                                                   fileArray_save_elements.push( csvArray );
                                       return fileArray_save_elements;
                                          fileObj.close();
                                rasterizeFolder();
                                function rasterizeFolder()
                                    //Get the source and destination folders.
                                    //If either window is cancelled, end the script.
                                    var sourceFolder = getSourceFolder ();
                                    if(sourceFolder == null){return;}
                                    var destinationFolder = getDestinationFolder ();
                                    if(destinationFolder == null){return;}
                                   error_file_name=sourceFolder.path+'/Tabledata.csv';
                                       error_file_name1=sourceFolder.path+'/Connector Numbers.csv';
                                        file_output=new File (error_file_name);
                                        file_output.open ('e');
                                         file_output.writeln ("CircuitFileName"+","+"LineNumber"+","+"Type"+","+"ConnectorNumber"+","+"TerminalNumber" +","+"FileName"+","+"DisplayName");
                                           file_output1=new File (error_file_name1);
                                        file_output1.open ('e');
                                         file_output1.writeln ("Connector Number"+","+"file Name");
                                    //Stuff for statistics
                                    var fileCount = 0;
                                    var itemsProcessed = 0;
                                    var itemsToReset = 9000;   //Used to periodically close and reopen Illustrator to avoid memory issues.
                                    var startTime = new Date().getTime();
                                    var endTimeMS = 0;
                                    var endSecs = 0;
                                    var endMins = 0;
                                    //Rasterize files by type.
                                    rasterizeAllOfType ("*.ai");
                                    //rasterizeAllOfType ("*.pdf");
                                    //Get the time taken for the script in milliseconds, and convert to minutes and seconds.
                                    endTimeMS = new Date().getTime() - startTime;
                                    endSecs = Math.floor(endTimeMS/1000);
                                    endMins = Math.floor(endSecs/60);
                                    endSecs -= (endMins*60);
                                    function getSourceFolder(){
                                        var sourceFolder = Folder.selectDialog("Choose the folder you wish to rasterize.");
                                            //User cancelled, do nothing.
                                            return;
                                        } else if(sourceFolder.getFiles().length < 1){
                                            //The folder contains nothing, make the user select another.
                                            alert("The source folder you selected contains no files. Select a different one.");
                                            return sourceFolder;
                                        } else {
                                            //We have a usable folder.
                                    }//End of getSourceFolder
                                    function getDestinationFolder(){
                                        var destinationFolder = Folder.selectDialog ("Where should the rasterized files go?");
                                            return;
                                        } else if (destinationFolder.getFiles().length < 1){
                                            //The folder contains nothing and is therefore safe to use.
                                            return destinationFolder;
                                        } else if (sourceFolder.getFiles()[0].path == destinationFolder.getFiles()[0].path){
                                            //The user chose the same folder for the source and destination.
                                            //See if it's okay to overwrite the files in there.
                                            var OKtoOverwrite = confirm("Source and destination are the same. Files will be overwritten. Do you want to continue?");
                                            if (OKtoOverwrite == true){
                                                //Okay to overwrite, proceed.
                                            } else {
                                                //Not okay, make a different choice.
                                        } else {
                                            //Folder has contents, but turned out to be different than the source folder.
                                    }//End of getDestinationFolder
                                    function rasterizeAllOfType(filetype)
                                        //Get all files of the type I'm working on
                                        var fileList = new Array();
                                            fileList = sourceFolder.getFiles(filetype);
                                        if(fileList.length > 0){
                                            //There are files to work with of this type.
                                            //New code here.
                                            var j = 0;
                                            AIrasterize(fileList, destinationFolder, itemsProcessed, itemsToReset, filetype);
                                            fileCount += fileList.length;
                                            return;
                                        } else {
                                            //No files of this type are in the folder.
                                            return;
                                     function AIrasterize(fileList, destinationFolder, itemsProcessed, itemsToReset) {
                                                NOTICE: If a function is sent via bridgetalk, either use <function>.toString()
                                                        or avoid using single-line comments in it. If just sent normally, it
                                                        will be read as if it is all one line, and thus break from comments.
                                            var bt = new BridgeTalk();
                                            bt.target = 'illustrator';
                                            bt.body = rasterizeDoc.toString() + ";rasterizeDoc(" + fileList[j].toSource() + "," + destinationFolder.toSource() + "," + itemsProcessed + "," + itemsToReset + ");";
                                            bt.onResult = function(resultMsg) {
                                                //var myStatus = BridgeTalk.getStatus('illustrator');
                                                itemsProcessed = eval(resultMsg.body);
                                                if (!itemsProcessed) {
                                                    // waiting for illustrator to quit.
                                                    while (BridgeTalk.getStatus('illustrator') != 'ISNOTRUNNING') $.sleep(20);
                                                    // as the last opened file has not been processed, so go back to it.
                                                    j--;
                                                ++j < fileList.length && AIrasterize(fileList, destinationFolder, itemsProcessed, itemsToReset);
                                                $.writeln(itemsProcessed);
                                                if (j == fileList.length) {
                                                    endSecs = Math.floor(endTimeMS / 1000);
                                                    endMins = Math.floor(endSecs / 60);
                                                    endSecs -= (endMins * 60);
                                                    //Tell the user how long this took.
                                                    alert(fileCount + " files rasterized in " + endMins + " minutes, " + endSecs + " seconds.");
                                            bt.onError = function(a) {
                                                alert(a.body + "(" + a.headers["Error-Code"] + ")");
                                            bt.send();
                                            //$.writeln(bt.body); //used to debug.
                                        } //End of AIrasterize
                                        function rasterizeDoc(myDoc, destinationFolder, itemsProcessed, itemsToReset, filetype)
                                            /*Open the file*/
                                            app.open(myDoc);
                                             sourceDoc = app.activeDocument;
                                               itemsProcessed += sourceDoc.pageItems.length;
                                            if (itemsProcessed > itemsToReset) {
                                                sourceDoc.close(SaveOptions.DONOTSAVECHANGES);
                                                alert("Processed " + itemsProcessed + " objects. Resetting to clear memory");
                                                app.quit() /*Workaround for AIrasterize bug. BT only goes to the next when AI is closed. */
                                                /*reset itemsProcessed to 0*/
                                                return 0
                                            var yog_lays=sourceDoc.layers;
                                           if( yog_lays.length==1)
                                                  title_loop:
                                               for(var grp1=0;grp1<yog_lays[0].groupItems.length;grp1++)
                                                if(yog_lays[0].groupItems[grp1].name=="<CIRCUIT TITLE>")
                                        for (var tit=0;tit<yog_lays[0].groupItems[grp1].textFrames.length;tit++)
                                            if(yog_lays[0].groupItems[grp1].textFrames[tit].kind ==  TextType.POINTTEXT)
                                             if(yog_lays[0].groupItems[grp1].textFrames[tit].textRange.characterAttributes.size==12)
                                                 if(yog_lays[0].groupItems[grp1].textFrames[tit].contents.slice(0,3)=="CAN")
                                                      check_artboard();
                                                       unlockLayer(sourceDoc);
                                                        color_empty_pathitem();
                                                        delete_group();
                                                        delete_group1();
                                                         autoColor_updation();
                                                         check_circle_ungroup_CAN();
                                                         ungroup_group();
                                                         ungroup_units();
                                                          AAA_check1();
                                                          ungroup_units1();
                                                           remove_fuse_group1();
                                                            remove_fuse_group();
                                                            check_fuse_ungroup();
                                                             rename_fuse_group();
                                                             check_dot_repeat();
                                                              check_connector();
                                                              reduce_opacity();
                                                               reduce_opacity_1();
        move_rectangle();
        Check_batteryline();
        ungroup_units1();
        remove_dot_pathitem();
        check_text_empty_high();
        line_check1_unit_CAN();
        line_check1_unit_2_CAN();
        group_connector_name();
        check_rect_path_inside_check();
        rectangle_inside_path_items_check();
        variant_terminal_check();
        circleFront();
        group_Circle_name_CAN();
        checking_circleGroup_CAN()
        check_unwantedline_CAN();
        renaming_path();
        renaming_CAN();
        line_pathitem_inside_CAN();
        line_cross(file_output);
        write_to_link(file_output);
        list_connector_names(file_output1);
        check_AAA_names();
        error_check();
        break title_loop;
        else if(yog_lays[0].groupItems[grp1].textFrames[tit].contents.slice(0,7)=="CONSULT")
        check_artboard();
                                delete_group();
                                delete_group1();
                                check_circle_ungroup();
                                ungroup_group();
                                  ungroup_units();
                                  AAA_check1();
                                  ungroup_units1();
                                  check_dot_repeat();
                                  check_connector();
                                       reduce_opacity();
                                           reduce_opacity_1();
                                           move_rectangle();
                                           ungroup_units1();
                                             check_CAN_normal_AAA();
                                line_check1_unit();
                                line_check1_unit_2();
                                  circleFront();
                                  group_name_normal();
                                  checking_circleGroup_normal();
                                  check_unwantedline_normal();
                                  renaming_path();
                                  renaming_CAN();
                                  line_pathitem_inside_normal();
                                   check_AAA_names();
                                   error_check();
                                       break title_loop;
                                                 else if(yog_lays[0].groupItems[grp1].textFrames[tit].contents.slice(0,4)=="IPDM")
                                delete_group();
                                delete_group1();
                                  ungroup_units();
                                   AAA_check1();
                                      Check_battery_AAA();
                                   ungroup_units1();
                                      check_dot_repeat();
                                       check_connector();
                                       reduce_opacity();
                                           reduce_opacity_1();
                                            move_rectangle();
                                            check_AAA_path_BCM();
                                      error_check();
                                      break title_loop;
                                  else if(yog_lays[0].groupItems[grp1].textFrames[tit].contents.slice(0,3)=="BCM")
                                delete_group();
                                delete_group1();
                                  ungroup_units();
                                   AAA_check1();
                                   ungroup_units1();
                                      check_dot_repeat();
                                       check_connector();
                                       reduce_opacity();
                                           reduce_opacity_1();
                                            move_rectangle();
                                                       error_check();
                                                       break title_loop;
                                              else
                                                 check_artboard();
                                delete_group();
                                delete_group1();
                                ungroup_group();
                                  ungroup_units();
                                  AAA_check1();
                                  ungroup_units1();
                                  check_dot_repeat();
                                  check_connector();
                                       reduce_opacity();
                                           reduce_opacity_1();
                                           move_rectangle();
                                           ungroup_units1();
                                line_check1_unit();
                                circleFront();
                                  renaming_path();
                                  renaming_CAN();
                                   check_AAA_names();
                                   error_check();
                                   break title_loop;
                                           else if(yog_lays.length==3)
                                              for( var lays1=0;lays1<yog_lays.length;lays1++)
                                                  if(yog_lays[lays1].name=="RANGE" ||yog_lays[lays1].name=="ILLUST")
                                                        title_loop4:
                                         for (var tit=0;tit<yog_lays[lays1].textFrames.length;tit++)
                                            if(yog_lays[lays1].textFrames[tit].kind ==  TextType.POINTTEXT)
                                            if(yog_lays[lays1].textFrames[tit].textRange.characterAttributes.size==12)
                                                   if(yog_lays[lays1].textFrames[tit].contents.slice(0,7)=="CONSULT")
                                                        check_artboard();
                                delete_group();
                                delete_group1();
                                ungroup_group();
                                  ungroup_units();
                                  AAA_check1();
                                  ungroup_units1();
                                  check_dot_repeat();
                                  check_connector();
                                       reduce_opacity();
                                           reduce_opacity_1();
                                           move_rectangle();
                                           ungroup_units1();
                                line_check1_unit();
                                  circleFront();
                                  renaming_path();
                                  renaming_CAN();
                                   check_AAA_names();
                                   error_check();
                                       break  title_loop4;
                                   else if(yog_lays[lays1].textFrames[tit].contents.slice(0,7)=="CAN")
                                        check_artboard();
                                                        delete_group();
                                                        delete_group1();
                                                         ungroup_group();
                                                         ungroup_units();
                                                          AAA_check1();
                                                          ungroup_units1();
                                                             check_dot_repeat();
                                                              check_connector();
                                                              reduce_opacity();
                                                               reduce_opacity_1();
        move_rectangle();
        ungroup_units1();
        circleFront();
        renaming_path();
        renaming_CAN();
        check_AAA_names();
        error_check();
        break title_loop4;
        else if(yog_lays[lays1].textFrames[tit].contents.slice(0,4)=="IPDM")
                                delete_group();
                                delete_group1();
                                  ungroup_units();
                                   AAA_check1();
                                   ungroup_units1();
                                      check_dot_repeat();
                                       check_connector();
                                       reduce_opacity();
                                           reduce_opacity_1();
                                            move_rectangle();
                                      error_check();
                                      break title_loop4;
                                sourceDoc.save();
                                sourceDoc.close();
                                app.quit();
                                function check_artboard()
                                var abIdx = sourceDoc.artboards.getActiveArtboardIndex ();
                                var abSrc = sourceDoc.artboards[abIdx];
                                var moveX = 4000;
                                var moveY = 800;
                                if(abSrc.artboardRect[0]<0)
                                var abSrc_L = abSrc.artboardRect[0] + moveX;
                                var abSrc_T = abSrc.artboardRect[1]  + moveY
                                var abSrc_R = abSrc.artboardRect[2] + moveX ;
                                var abSrc_B = abSrc.artboardRect[3] +moveY
                                abSrc.artboardRect = [abSrc_L, abSrc_T, abSrc_R, abSrc_B];
                                for( var i = 0, ii =yog_lays.length; i < ii; i++ ) {
                                    // clear any current selection
                                    sourceDoc.selection = null;
                                      for(var k=0;k<yog_lays[i].groupItems.length;k++)
                                    // translate them using the moveX and moveY variables
                                    var curGroup = yog_lays[i].groupItems[k];
                                    curGroup.translate( moveX, moveY );
                                for(var s=0;s<yog_lays[i].pathItems.length;s++)
                                       var curGroup = yog_lays[i].pathItems[s];
                                for(var t=0;t<yog_lays[i].textFrames.length;t++)
                                       var curGroup = yog_lays[i].textFrames[t];
                                    else
                                function delete_group()
                                for(var i=0;i<yog_lays.length;i++)
                                        var theObj = yog_lays[i].groupItems[k].pageItems;
                                         if( theObj.length==1)
                                        for(var z=0;z< theObj.length;z++)
                                          if (theObj[z].typename == "GroupItem") {
                                            theObj[z].moveBefore(theObj[z].parent);
                                function delete_group1()
                                      var yog_lay=sourceDoc.layers;
                                for(var i=0;i<yog_lay.length;i++)
                                    for(var k=0;k<yog_lay[i].groupItems.length;k++)
                                for(var z=0;z<yog_lay[i].groupItems[k].groupItems.length;z++)
                                    var yog_group1=yog_lay[i].groupItems[k].groupItems[z];
                                    var path_found=0;
                                    for(var zz=0;zz<yog_group1.groupItems.length;zz++)
                                        if(yog_group1.groupItems[zz].name.slice(0,15)=="connectornumber")
                                            if(yog_group1.pathItems.length==0 || yog_group1.textFrames.length==0)
                                            var path_found=1;
                                  if(path_found==1)
                                        yog_group1.groupItems[zz].moveBefore(yog_group1.groupItems[zz].parent)
                                function check_circle_ungroup_CAN()
                                     for(var layer_item_index=0;layer_item_index<sourceDoc.layers.length;layer_item_index++)
                                        if(sourceDoc.layers[layer_item_index].pageItems.length>0)
                                            layer_grp_item=sourceDoc.layers[layer_item_index].groupItems;
                                    for(var grp_main_index=0;grp_main_index<layer_grp_item.length;grp_main_index++)
                                child_path_item_main=layer_grp_item[grp_main_index].pathItems;
                                  child_group_item=layer_grp_item[grp_main_index].groupItems;
                                    var count_groupfound=0;
                                mainloopline:
                                  for(var grp_main_index1=0;grp_main_index1< child_group_item.length;grp_main_index1++)
                                      if(child_group_item[grp_main_index1].name.slice(0,15)=="connectornumber" )
                                           count_groupfound=1;
                                          break mainloopline;
                                   if(count_groupfound==0)
                                           mainloopline:
                                      child_path_item_main1=child_group_item[grp_main_index1].pathItems;
                                      for(var path_1=0;path_1<child_path_item_main1.length;path_1++)
                                           var  path_type = type_of_path(child_path_item_main1[path_1]);
                                           if(path_type=="Line Type 1" || path_type=="Line Type 2"  || path_type=="Line Type 3" || path_type=="Line Type 4"  || path_type=="Line Type 10" || path_type=="Circle Type 1"
                                           || path_type=="Circle Type 2" || path_type=="Circle Type 3"|| path_type=="Circle Type 4"|| path_type=="Circle Type 5"
                                           || path_type=="Circle Type 6"|| path_type=="Line Type 12")
                                               theObj=layer_grp_item[grp_main_index].pageItems;
                                                 for(var z=theObj.length-1;z>=0 ;z--)
                                             for (i=theObj[z].pageItems.length-1; i>=0; i--)
                                            theObj[z].pageItems[i].moveAfter(theObj[z].pageItems[i].parent);
                                    break mainloopline;
                                function check_circle_ungroup()
                                mainloopline:
                                      if(child_group_item[grp_main_index1].name.slice(0,15)=="connectornumber")
                                          count_groupfound=1;
                                           break mainloopline;
                                     mainloopline:
                                           if(path_type=="Line Type 1" || path_type=="Line Type 2"  || path_type=="Line Type 3" || path_type=="Circle Type 1"
                                    break mainloopline;
                                function remove_fuse_group1()
                                    var yog_layers=sourceDoc.layers;
                                for(var lays1=0;lays1<yog_layers.length;lays1++)
                                    for(var group1=0;group1<yog_layers[lays1].groupItems.length;group1++)
                                        var yog_group=yog_layers[lays1].groupItems[group1];
                                        if(yog_group.name!="AAA")
                                       var text_found=0;
                                       var r= find_rectangle_path_with_large_area(yog_group);
                                        for(var group2=0;group2<yog_group.groupItems.length;group2++)
                                            for(var text1=0;text1<yog_group.groupItems[group2].pathItems.length;text1++)
                                        var yog_path=yog_group.groupItems[group2].pathItems[text1];
                                        var path_type=type_of_path(yog_path)
                                        if(path_type=="Rectangle Type 2" || path_type=="Rectangle Type 10")
                                            if((Math.abs(Math.round(yog_path.area)))==25 || (Math.abs(Math.round(yog_path.area)))==108)
                                            else
                                           text_found=1;
                                   else if(path_type=="Rectangle Type 4" || path_type=="Rectangle Type 7" || path_type=="Rectangle Type 14" || path_type=="Rectangle Type 15")
                                       if(r.area==yog_path.area)
                                           text_found=0;
                                   else
                                       text_found=0;
                                   if( text_found==1)
                                       var count=0;
                                       for(var group3=0;group3<yog_group.groupItems.length;group3++)
                                           for(var path1=yog_group.groupItems[group3].pathItems.length-1;path1>=0;path1--)
                                                var yog_path3=yog_group.groupItems[group3].pathItems[path1];
                                               var path_type=type_of_path(yog_path3)
                                               if(path_type=="Rectangle Type 3")
                                                  count=1;
                                   if(count==1)
                                               if(path_type=="Anchor point")
                                                   yog_path3.remove();
                                function remove_fuse_group()
                                       var text_found=0;
                                            else
                                           text_found=1;
                                           text_found=1;
                                   else
                                       text_found=0;
                                   if( text_found==1)
                                           for(var path1=0;path1<yog_group.groupItems[group3].pathItems.length;path1++)
                                               var path_type=type_of_path(yog_group.groupItems[group3].pathItems[path1])
                                                   yog_group.groupItems[group3].moveToBeginning(yog_layers[lays1]);
                                                   break;
                                function ungroup_group()
                                for(var i=0;i<sourceDoc.layers.length;i++)
                                    for(var k=0;k<sourceDoc.layers[i].groupItems.length;k++)
                                        var count=0;
                                       var count_group=0;
                                         theObj = sourceDoc.layers[i].groupItems[k].pageItems;
                                for(var z=0;z<theObj.length;z++)
                                    if(theObj[z].typename=="PathItem" || theObj[z].typename=="TextFrame")
                                        count++;
                                for(var zzz=0;zzz<theObj.length;zzz++)
                                     if(theObj[zzz].typename=="GroupItem")
                                         count_group++;
                                if(count==0 || (count==1 && count_group==1))
                                    for(var zz=0;zz<theObj.length;zz++)
                                         if(theObj[zz].typename=="GroupItem")
                                              var count_text=0;
                                             for(var zzzz=0;zzzz<theObj[zz].pageItems.length;zzzz++)
                                                 if(theObj[zz].pageItems[zzzz].typename=="PathItem" || theObj[zz].pageItems[zzzz].typename=="TextFrame" )
                                                     count_text=1;
                                             if(count_text==0)
                                                 theObj[zz].pageItems[zzzz].moveBefore(theObj[zz].parent)
                                    else
                                        theObj[zz].moveBefore(theObj[zz].parent)
                                function ungroup_units()
                                theObj=child_group_item[grp_main_index1].pageItems;
                                  function AAA_check1()
                                    var count=0;
                                        if(sourceDoc.layers[lays1].groupItems[group1].name=="AAA")
                                        {    count =group1;
                                            break;
                                  for(var group2=sourceDoc.layers[lays1].groupItems.length-1;group2>=0;group2--)
                                        if(sourceDoc.layers[lays1].groupItems[group2].name=="AAA")
                                            if(count==group2)
                                        else
                                            sourceDoc.layers[lays1].groupItems[group2].moveToBeginning(sourceDoc.layers[lays1].groupI tems[count])
                                function ungroup_units1()
                                       for(var k=0;k<layer_grp_item.length;k++)
                                if( layer_grp_item[k].name=="AAA")
                                     theObj =layer_grp_item[k].pageItems;
                                            theObj[z].pageItems[i].moveAfter( theObj[z].pageItems[i].parent);
                                function check_dot_repeat()
                                        var arr=[];
                                        arr.length=0;
                                            for(var group2=0;group2<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;group2++)
                                                if(sourceDoc.layers[lays1].groupItems[group1].pathItems[group2].name.slice(0,3)=="pin")
                                                    arr.push(sourceDoc.layers[lays1].groupItems[group1].pathItems[group2].name);
                                            if(arr.length>1)
                                                var sorted_arr = arr.slice().sort();
                                var results = [];
                                results.length=0;
                                for (var i = 0; i < arr.length - 1; i++) {
                                    if (sorted_arr[i + 1] == sorted_arr[i]) {
                                        results.push(sorted_arr[i]);
                                if( results.length>=1)
                                    for(var k=0;k<results.length;k++)
                                        for(var group3=0;group3<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;group3++)
                                             if(sourceDoc.layers[lays1].groupItems[group1].pathItems[group3].name==  results[k])
                                                 sourceDoc.layers[lays1].groupItems[group1].pathItems[group3].remove();
                                                 break;
                                function check_connector()
                                      for(var lays=0;lays<sourceDoc.layers.length;lays++)
                                          var arr=[];
                                var arr1=[];
                                    for(var group1=0;group1<sourceDoc.layers[lays].groupItems.length;group1++)
                                             arr.length=0;
                                arr1.length=0;
                                        for(var group2=0;group2<sourceDoc.layers[lays].groupItems[group1].groupItems.length;group2++)
                                            for(var text1=0;text1<sourceDoc.layers[lays].groupItems[group1].groupItems[group2].textFrames.len gth;text1++)
                                                if(!sourceDoc.layers[lays].groupItems[group1].groupItems[group2].textFrames[text1].conten ts.match(/[A-Z][0-9]{1,3}$/)) continue;
                                                    arr.push(sourceDoc.layers[lays].groupItems[group1].groupItems[group2].textFrames[text1])
                                        if(arr.length>1)
                                        for(var sd=0;sd<arr.length;sd++)
                                              if(arr[sd].contents== fileArray_SM_name[csv_iter][0])
                                                    arr1.push( fileArray_SM_name[csv_iter][1])
                                                    break ;
                                    for(var sd1=0;sd1<arr1.length;sd1++)
                                        if(arr1[0]==arr1[sd1])
                                        else
                                            var count_error=0;
                                            group_main=sourceDoc.layers[lays].groupItems[group1];
                                                  for(var error=0;error<sourceDoc.layers[lays].groupItems[group1].groupItems.length;error++)
                                                              if(group_main.groupItems[error].name==group_main.name+ "Error:")
        var max_area_path=find_rectangle_path_with_large_area(group_main);
                                  var x_axis=Math.abs(max_area_path.pathPoints[0].anchor[0]);
                                                  var y_axis=Math.abs(max_area_path.pathPoints[0].anchor[1]);
                                                  var textRef =group_main.groupItems[error].textFrames.add();
                                textRef.contents =arr[sd1].contents+" Different unit present inside the group" ;
                                textRef.top =y_axis ;
                                textRef.left = x_axis+20 ;
                                textRef.textRange.characterAttributes.size = 10;
                                count_error++;
                                if(count_error==1)
                                else
                                                               var newGroup  =group_main.groupItems.add();
                                                            newGroup.name = group_main.name+ "Error:";
                                                  var textRef = newGroup.textFrames.add();
                                newGroup.moveToEnd(group_main);
                                    arr.length=0;
                                arr1.length=0;
                                function check_fuse_ungroup()
                                    var layer_item=sourceDoc.layers
                                     for(var layer_item_index=0;layer_item_index<layer_item.length;layer_item_index++)
                                        if(layer_item[layer_item_index].pageItems.length>0)
                                            layer_grp_item=layer_item[layer_item_index].groupItems;
                                mainloopfuse:
                                    break mainloopfuse;
                                  function line_check1_unit_CAN()
                                    var count=0;
                                        mainloop12:
                                            for(var group2=0;group2<sourceDoc.layers[lays1].groupItems[group1].groupItems.length;group2++)
                                                for(var path=0;path<sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems.lengt h;path++)
                                                    var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path ]);
                                                    if(path_type=="Line Type 1" || path_type=="Line Type 2" || path_type=="Line Type 3"  )
                                                        for(var text=0;text<sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames.leng th;text++)
                                                            if(!sourceDoc.layers[lays1].groupItems[group1].groupItems[group3].textFrames[text].conten ts.match(/[A-Z][0-9]{1,3}$/)) continue;
        var count_error=0;
                                            group_main=sourceDoc.layers[lays1].groupItems[group1];
                                                  for(var error=0;error<sourceDoc.layers[lays1].groupItems[group1].groupItems.length;error++)
                                textRef.contents ="Unwanted line present inside the group" ;
                                count_error++;
                                if(count_error==1)
                                else
                                break mainloop12;
                                function line_check1_unit_2_CAN()
                                          for(var lays1=0;lays1<sourceDoc.layers.length;lays1++)
                                        var count_group_found=0;
                                          mainloop12:
                                               if(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].name.slice(0,15)=="conne ctornumber")
                                                   count_group_found=1;
                                                   break  mainloop12;
                                           if(  count_group_found==1)
                                                for(var path=0;path<sourceDoc.layers[lays1].groupItems[group1].pathItems.length;path++)
                                                    var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path]);
                                                        var count_error=0;
                                count_error++;
                                if(count_error==1)
                                else
                                function reduce_opacity()
                                            for(var path1=sourceDoc.layers[lays1].groupItems[group1].pathItems.length-1;path1>=0;path1--)
                                                var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].pathItems[path1]);
                                                if(path_type=="Anchor point" && (sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name.slice(0,3)=="pin"
                                                || sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name.slice(0,4)=="FUSE" || sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name.slice(0,2)=="FL"))
                                                    sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].opacity=0;
                                                else if(path_type=="Anchor point" && sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].name=="")
                                                     sourceDoc.layers[lays1].groupItems[group1].pathItems[path1].remove()
                                                     for(var path2=sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems.length-1;pa th2>=0;path2--)
                                                var path_type = type_of_path(sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path 2]);
                                                if(path_type=="Anchor point" && (sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name.slic e(0,3)=="pin"
                                               || sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name.slice (0,4)=="FUSE" || sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name.slice (0,2)=="FL" ))
                                                    sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].opacity=0;
                                                else if(path_type=="Anchor point" && sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].name=="")
                                                     sourceDoc.layers[lays1].groupItems[group1].groupItems[group2].pathItems[path2].remove()
                                function reduce_opacity_1()
                                        for(var path1=0;path1<sourceDoc.layers[lays1].pathItems.length;path1++)
                                            var pathtype=type_of_path(sourceDoc.layers[lays1].pathItems[path1]);
                                            if(pathtype=="Anchor point")
                                               sourceDoc.layers[lays1].pathItems[path1].opacity=0;
                                function circleFront()
                                    for(var group=0;group<sourceDoc.groupItems.length;group++)
                                    for(var path1=0;path1<sourceDoc.groupItems[group].pathItems.length;path1++)
                                        var  path_type = type_of_path(sourceDoc.groupItems[group].pathItems[path1]);
                                        if(path_type=="Circle Type 1" || path_type=="Circle Type 2" || path_type=="Circle Type 3" || path_type=="Circle Type 4" || path_type=="Circle Type 5"
                                          || path_type=="Circle Type 6")
                                      sourceDoc.groupItems[group].pathItems[path1].moveToBeginning(sourceDoc.groupItems[group]. pathItems[path1].parent);
                                function group_Circle_name_CAN()
                                    var count_group =1;
                                     for(var path=0;path<sourceDoc.pathItems.length;path++)
                                           var  path_type = type_of_path(sourceDoc.pathItems[path]);
                                               if((sourceDoc.pathItems[path].parent.name!="AAA" || sourceDoc.pathItems[path].parent.parent.name!="AAA")&& (sourceDoc.pathItems[path].parent.name=="") && (sourceDoc.pathItems[path].parent.name!="Shield") &&  (sourceDoc.pathItems[path].parent.name.slice(0,1)!="L"))
                                                     if(sourceDoc.pathItems[path].parent.pathItems.length>=3)
                                                         sourceDoc.pathItems[path].parent.name="CircleGroup"+count_group;
                                                         count_group++
                                                     else if(sourceDoc.pathItems[path].parent.pathItems.length<3)
                                                         for(var path1=0;path1<sourceDoc.pathItems[path].parent.pathItems.length;path1++)
                                                             sourceDoc.pathItems[path].parent.pathItems[path1].strokeColor=magentaColor1;
        sourceDoc.pathItems[path].parent.pathItems[path1].strokeWidth=3;
                                                     else
                                                     else if(sourceDoc.pathItems[path].parent.name=="Shield")
                                                         sourceDoc.pathItems[path].parent.name="Shield"+count_group;
                                                         count_group++
                                                 else {
                                     function group_name_normal()
                                    var count_group =1
                                               if((sourceDoc.pathItems[path].parent.name!="AAA" || sourceDoc.pathItems[path].parent.parent.name!="AAA")&& (sourceDoc.pathItems[path].parent.name=="") && (sourceDoc.pathItems[path].parent.name!="Shield") )
                                                         count_group++
                                                     else
                                                         count_group++
                                                 else {
                                  function checking_circleGroup_CAN()
                                     var layer_yog=sourceDoc.layers;
                                    for(var lays1=0;lays1<layer_yog.length;lays1++)
                                        var group_yog= layer_yog[lays1].groupItems;
                                      for(var path=group_yog.length-1;path>=0;path--)
                                        if(group_yog[path].name.slice(0,11)=="CircleGroup" || group_yog[path].name.slice(0,6)=="Shield" || group_yog[path].name.slice(0,3)=="AAA"  || sourceDoc.layers[lays1].groupItems[path].name.slice(0,1)=="L")
                                        for(var path_group=0;path_group<group_yog[path].pathItems.length;path_group++)
                                             var path_yog=group_yog[path].pathItems[path_group];
                                           var  path_type = type_of_path(path_yog);
                                           if(path_type=="Circle Type 2" || path_type=="Circle Type 5")
                                               var x_pathtype=Math.round(path_yog.visibleBounds[2]);
                                               var y_pathtype1=Math.round(path_yog.visibleBounds[1]);
                                               var x_pathtype2=Math.round(path_yog.visibleBounds[0]);
                                               var y_pathtype3=Math.round(path_yog.visibleBounds[3]);
                                             for(var lays2=0;lays2<layer_yog.length;lays2++)
                                               for(var path1=layer_yog[lays2].groupItems.length-1;path1>=0;path1--)
                                                 for(var path_group1=0;path_group1<layer_yog[lays2].groupItems[path1].pathItems.length;path_group1 ++)
                                            var path1_yog=layer_yog[lays2].groupItems[path1].pathItems[path_group1];
                                                    var  path_type1 = type_of_path(path1_yog);
                                                    if(path_type1=="Line Type 2" || path_type1== "Rectangle Type 5")
                                                        for(var path_points=0;path_points<(path1_yog.pathPoints.length-1);path_points++)
                                                            var x_pathline=Math.round(path1_yog.pathPoints[path_points].anchor[0]);
                                                            var y_pathline=Math.round(path1_yog.pathPoints[path_points].anchor[1]);
                                                           if((x_pathline> x_pathtype2) &&    (x_pathline<x_pathtype) && (y_pathline> y_pathtype3) &&    (y_pathline<y_pathtype1) )
        if(path1_yog.parent.name==layer_yog[lays2].groupItems[path].pathItems[path_group].parent. name)
        path1_yog.name="Blue Color Line"
        layer_yog[lays2].groupItems[path].pathItems[path_group].name="Blue Color Circle"
        else
        path1_yog.strokeColor =magentaColor1;
        path1_yog.strokeWidth =3;
                                                            else if((x_pathline> x_pathtype2) &&    (x_pathline<x_pathtype) )
        if(y_pathline< y_pathtype3)
        var x_pathline1=Math.round(path1_yog.pathPoints[path_points+1].anchor[0]);
                                                            var y_pathline1=Math.round(path1_yog.pathPoints[path_points+1].anchor[1]);
                                                            if((x_pathline1>x_pathtype2) && (x_pathline1<x_pathtype))
        if((y_pathline1>  y_pathtype3)&&(y_pathline1>  y_pathtype1))
        else
        else if((y_pathline1> y_pathtype3) &&(y_pathline1< y_pathtype1))
        else
                                                     else if(y_pathline> y_pathtype3)
                                                           if((y_pathline1>  y_pathtype3)&&(y_pathline1<y_pathtype1))
        else
        else if((y_pathline1<y_pathtype3) &&(y_pathline1<  y_pathtype1))
        else
                                                      else if((y_pathline> y_pathtype3) &&    (y_pathline<y_pathtype1) )
        if(x_pathline< x_pathtype2)
                                                          if((y_pathline1>y_pathtype3) && (y_pathline1<y_pathtype1))
        if((x_pathline1>  x_pathtype2)&&(x_pathline1>  x_pathtype))
        else
