8 Replies Latest reply on Oct 6, 2017 6:05 AM by c.pfaffenbichler
    Convert an image to an 'informative'color gradient
    Arvid.Stark
      Dear all,
      I have a rather strange question. I have a black/white photo. I want to 'extract' the information regarding the amount of black-gray-white (light and dark) within the photo, so I in the end I have a gradient map (like the one below) that shows the amount of black and white that the photo consist of.
      So if, for example, the image I want to convert is bw and very very dark with just some spots of light, the gradient map would mostly be black with just some gray and white-tones at the very end at the right side of the map.
      Is this possible? I use Photoshop CC 2017
      I would be super thankful for answers.
        • 1. Re: Convert an image to an 'informative'color gradient
          davescm Adobe Community Professional
          Hi
          The info such a gradient will show you is contained in the luminosity histogram - but I don't know a way to convert that to a cumulative gradient automatically in Photoshop
          Perhaps the scripting experts may be able to help.
          Dave
          • 2. Re: Convert an image to an 'informative'color gradient
            Arvid.Stark Level 1
            Thank you for the fast answer Dave.
            I belive this is the way to go, i.e. to convert the histogram to a gradient. I just hope that someone know how to do this:)
            • 3. Re: Convert an image to an 'informative'color gradient
              c.pfaffenbichler Level 9
              You could evaluate the Histogram with a Script and then have the Script create a representation of that.
              I’m not sure a Gradient Layer would be the way to go, maybe create Shape Layers instead, but this would likely be far from speedy.
              Rounding issues might affect the result, though.
              • 5. Re: Convert an image to an 'informative'color gradient
                You could try this:
                // create rectangular shapes representing percentages of the (composite) histogram;
                // 2017, use it at your own risk;
                #target photoshop
                if (app.documents.length > 0) {
                var originalRulerUnits = app.preferences.rulerUnits;
                app.preferences.rulerUnits = Units.PIXELS;
                var myDocument = app.activeDocument;
                var theName = myDocument.name;
                try {var theName = theName.match(/(.*)\.[^\.]+$/)[1]} catch (e) {};
                try {var thePath = myDocument.path}
                catch (e) {var thePath = "~/Desktop"};
                var theTotal = myDocument.width * myDocument.height;
                // the values;
                var theArray = new Array;
                if (myDocument.mode == DocumentMode.MULTICHANNEL || myDocument.mode == DocumentMode.GRAYSCALE) {
                  var theHistogram = myDocument.channels[0].histogram
                else {var theHistogram = myDocument.histogram};
                // get total number of histogram:
                var theNumber = 0;
                for (var m = 0; m < theHistogram.length; m++) {
                  var thisValue = theHistogram[m];
                  theArray.push(thisValue);
                  theNumber = theNumber + theHistogram[m]
                if (theNumber != theTotal) {alert ("something’s wrong")}
                else {};
                // create shape layers;
                var theX = myDocument.width;
                var theWidth = myDocument.width;
                var theBottom = myDocument.height;
                var theTotal = theWidth * theBottom;
                for (var n = 0; n < theArray.length; n++) {
                // only if non-zero;
                if (theArray[n] != 0) {
                var thePerc = theArray[n] / theTotal;
                rectangleShapeLayer ([0,0,theX,theBottom], n, n, n);
                theX = theX - (thePerc * theWidth);
                // reset;
                  app.preferences.rulerUnits = originalRulerUnits;
                else {
                  alert ("no open document")
                ////// rectangle //////
                function rectangleShapeLayer (theArray, theR, theG, theB) {
                var idMk = charIDToTypeID( "Mk  " );
                    var desc44 = new ActionDescriptor();
                    var idnull = charIDToTypeID( "null" );
                        var ref9 = new ActionReference();
                        var idcontentLayer = stringIDToTypeID( "contentLayer" );
                        ref9.putClass( idcontentLayer );
                    desc44.putReference( idnull, ref9 );
                    var idUsng = charIDToTypeID( "Usng" );
                        var desc45 = new ActionDescriptor();
                        var idType = charIDToTypeID( "Type" );
                            var desc46 = new ActionDescriptor();
                            var idClr = charIDToTypeID( "Clr " );
                                var desc47 = new ActionDescriptor();
                                var idRd = charIDToTypeID( "Rd  " );
                                desc47.putDouble( idRd, theR );
                                var idGrn = charIDToTypeID( "Grn " );
                                desc47.putDouble( idGrn, theG );
                                var idBl = charIDToTypeID( "Bl  " );
                                desc47.putDouble( idBl, theB );
                            var idRGBC = charIDToTypeID( "RGBC" );
                            desc46.putObject( idClr, idRGBC, desc47 );
                        var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
                        desc45.putObject( idType, idsolidColorLayer, desc46 );
                        var idShp = charIDToTypeID( "Shp " );
                            var desc48 = new ActionDescriptor();
                            var idunitValueQuadVersion = stringIDToTypeID( "unitValueQuadVersion" );
                            desc48.putInteger( idunitValueQuadVersion, 1 );
                            var idTop = charIDToTypeID( "Top " );
                            var idPxl = charIDToTypeID( "#Pxl" );
                            desc48.putUnitDouble( idTop, idPxl, theArray[1] );
                            var idLeft = charIDToTypeID( "Left" );
                            desc48.putUnitDouble( idLeft, idPxl, theArray[0] );
                            var idBtom = charIDToTypeID( "Btom" );
                            desc48.putUnitDouble( idBtom, idPxl, theArray[3] );
                            var idRght = charIDToTypeID( "Rght" );
                            desc48.putUnitDouble( idRght, idPxl, theArray[2] );
                            var idtopRight = stringIDToTypeID( "topRight" );
                            desc48.putUnitDouble( idtopRight, idPxl, 0.000000 );
                            var idtopLeft = stringIDToTypeID( "topLeft" );
                            desc48.putUnitDouble( idtopLeft, idPxl, 0.000000 );
                            var idbottomLeft = stringIDToTypeID( "bottomLeft" );
                            desc48.putUnitDouble( idbottomLeft, idPxl, 0.000000 );
                            var idbottomRight = stringIDToTypeID( "bottomRight" );
                            desc48.putUnitDouble( idbottomRight, idPxl, 0.000000 );
                        var idRctn = charIDToTypeID( "Rctn" );
                        desc45.putObject( idShp, idRctn, desc48 );
                    desc44.putObject( idUsng, idcontentLayer, desc45 );
                    var idLyrI = charIDToTypeID( "LyrI" );
                    desc44.putInteger( idLyrI, 5 );
                executeAction( idMk, desc44, DialogModes.NO );
                • 6. Re: Convert an image to an 'informative'color gradient
                  Here are screenshots of results the above Script creates for two images:
                  I make no guarantees about the math (or the Script itself) but in my tests the results seem plausible.
                  • 7. Re: Convert an image to an 'informative'color gradient
                    Arvid.Stark Level 1
                    Thank you so much!
                    As you said, it looks plausible! I will try to do it with the images I have.
                    Thanks once again.
                    • 8. Re: Convert an image to an 'informative'color gradient
                      Just give it a couple minutes, it creates (up to 256) Shape Layers so that can take a while.
