I have been using Dreamweaver CS3 on my old laptop and when I transferred it over to my new laptop (both are Win10), I was easily able to get it to work but I could not get it to activate.
Ultimately, Adobe tech support tried and then told me to delete and reinstall. Which I did. But now I can't install. Even though this is the only Adobe app I'm trying to install (not include Adobe Reader, which is already installed), I get an error message that says, "Setup Already Running: You can only install one Adobe product at a time. Please complete the other installation before attempting to install Adobe Dreamweaver CS3."
Again, I'm not installing another Adobe product. I've deleted prior versions of Dreamweaver, per Adobe's instructions but nothing seems to work.
I just want to install and activate Dreamweaver, which I didn't think would be so hard since it loaded easily via CDs, Can anyone help me eliminate the error message so I can install and activate Dreamweaver? Thanks in advance!
You will need to log in and follow the instructions here: Activation or connection error when starting CS3 or Acrobat 8
Short version: Adobe took down CS3's activation servers early this year. You'll need to log-in, download a special version of CS3 and prove you have a valid activation # to be given a new # that doesn't require the online authentication.
It's best to uninstall Creative Suite before you install the replacement version. Also, you may need to delete the Adobe PCD folder to wipe out the old activation countdown ticker. The answer in this related thread should help.
Nancy
Microsoft has disabled Macrovision's SafeDisc DRM in updates and in Windows 10 appears that CS3 installs that as part of it's DRM.
See event id 7000 in event viewer
The SecDrv service failed to start due to the following error:
This driver has been blocked from loading
Microsoft actually suggest that obtaining a patch or a crack for the application is safer than allowing SafeDisc or Securom DRM as they are basically root kits.
