• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
1
Testing on iOS 11 device not working - installation error apiinternalerror
Explorer ,
Oct 04, 2017 Oct 04, 2017
I am using Air 26 and an iPhone 7. After upadating it on iOS 11 it insn't working anymore to debug/launch/test via Intellij Idea. Get the Installation Error: APIInternalError. Are there any workarounds/fixes for this problem?
TOPICS
Development
Views
3.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner ,
Oct 05, 2017 Oct 05, 2017
I have the same problem with Air 26. I can compile the .ipa but can't install it with ADT commands.
However, we can install the IPA on device with iTunes.
EDIT : Install on device with ADT don't give error with Air SDK 27, but can't see App.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
This issue in known to us and we are working on it.
Ankit | AIR Adobe Engineering
Votes
Translate
Translate
Report
Report
Contributor ,
Oct 30, 2017 Oct 30, 2017
Is there an update on this as I'm getting this with AIR 27.0 now?
Votes
Translate
Translate
Report
Report
New Here ,
Nov 03, 2017 Nov 03, 2017
I'm able to publish to iOS if I use a custom application descriptor file instead of the generated file.
Votes
Translate
Translate
Report
Report
Participant ,
Nov 27, 2017 Nov 27, 2017
Having this set in the app-descriptor.xml will cause this error. (used for TestFlight testing).
<key>beta-reports-active</key><true/>
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Have you tried the latest AIR SDK 28? Please download the latest SDK from Download Adobe AIR 28 Beta - Adobe Labs  and let us know if this fixes your issue.
Ankit | Adobe AIR Engineering
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 29, 2017 Nov 29, 2017
I am reporting the same error using the latest AIR 28 SDK
Votes
Translate
Translate
Report
Report
Engaged ,
Nov 30, 2017 Nov 30, 2017
I can confirm the AIR 28 Beta build 120 did fix this problem for me, but .... What about Windows users? If they use this AIR 28 Beta Build 120 they get no app Icons. I understand you all of a sudden "require" a mac to build some "assets.car" file... but I dont have access to a multi-thousand dollar mac.
Votes
Translate
Translate
Report
Report
Dec 22, 2017 Dec 22, 2017
Hi, i am using AIR SDK 28 and still app is not installing on my iPad that has iOS 11. please let me know what can be done to make apps compatible for iOS 11?
Votes
Translate
Translate
Report
Report
Jan 02, 2018 Jan 02, 2018
We have tried installing application with both mac and windows using AIR SDK 28 and it is working fine.
Could you please recheck at your end if you are using proper provisioning profile while packaging or share any additional information related to problem faced.
Regards,
Amit Baliyan | Adobe AIR Engineering
Votes
Translate
Translate
Report
Report
Apr 17, 2018 Apr 17, 2018
The issue still Persists with the latest AIR29 , MacOS 10.13.2 , and Xcode 9.3
@abaliyan0624 any updates ?
Votes
Translate
Translate
Report
Report
Engaged ,
Apr 18, 2018 Apr 18, 2018
I am still having the issue on iPhone 6s, iPhone 7 Plus, iPhone X with AIR 28 and AIR 29 on Windows.
Votes
Translate
Translate
Report
Report
Apr 19, 2018 Apr 19, 2018
LATEST
It started working for me !
created a new  certificate and provisioning and it worked for me !
had tried this before with failure , but it worked !!!
Votes
Translate
Translate
Report
Report
