• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Text Size - Photoshop
Explorer ,
Oct 05, 2017 Oct 05, 2017
I am using Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64.
I am using the application on a DELL laptop resolution: 3840x2160. Scale and layout setting on screen 250% (recommended).
Is it possible to increase the text size on the screen?
Richard
Views
234
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Oct 05, 2017 Oct 05, 2017
You have a 4K displa a small laptop 4K display it has a resolution like 300DPI  Photoshop UI will be very small where if you have a large desktop 4K Display  like a 32" or larger  the display resolution will be in the 100DPI range and Photoshop UI will look normal.   My Dell desktop 4K Display is a 24" Display its resolution is 185DPI  Photoshop UI would be on the small size there However,  I keep Photoshop UI on My other displays they have a 100DPI resolution.  All I have on the 4K display is P
Votes
Translate
Translate
Adobe
Community Expert ,
You have a 4K displa a small laptop 4K display it has a resolution like 300DPI  Photoshop UI will be very small where if you have a large desktop 4K Display  like a 32" or larger  the display resolution will be in the 100DPI range and Photoshop UI will look normal.   My Dell desktop 4K Display is a 24" Display its resolution is 185DPI  Photoshop UI would be on the small size there However,  I keep Photoshop UI on My other displays they have a 100DPI resolution.  All I have on the 4K display is Photoshop Image window.  Only the information in the Image windows frame is on the small side.   If you only have a single display and it has a high DPI resolution  Try using  Photoshop CC 2x UI scaling Preference.  You could update your Widows registry and add a manifest file for Photoshop and force Photoshop to use Windows scaling  to use other scaling factors.
JJMack
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Thanks. I have a 16 inch display. Will implement your suggestions
Votes
Translate
Translate
Report
Report
