6 Replies Latest reply on Aug 11, 2008 7:30 PM by Nomi_T
    Change from MX_2004 to 11
    Nomi_T
      I'm not a huge Director user, only for specific art projects. I have Director 204MX, which I recently (7 weeks ago), re-installed on a new computer (OSX 1.5 Laptop). It worked fine. In the last 2 days, it keeps quitting again and again - actually, it won't even complete starting. Anyone had similar problem?
      I'm running into a deadline. Calling Adobe, I was told that officially they don't support this anymore... Any ideas - or should I bite the bullet and upgrade?
      BTW - I have an educational version, legally bought and installed. Tones of space. I run after effect and final cut no problem.
      Many thanks
        • 1. Re: Change from MX_2004 to 11
          Level 7
          Nomi_T wrote:
          > OK. I 'm not a huge Director user, only for specific art projects. I have
          > and again - and I'm running into a deadline. Calling Adobe, I was told that
          > bullet and upgrade?
          Hi Nomi,
          Could you give more detail to when Director quits? Does it happen randomly or
          always with a certain file at a certain position? Knowing more about the issue may
          help identify the cause and find a solution. D MX 04 should work. As to upgrading
          to D11, it does have its own quirks. I would never recommend switching versions of
          software in the middle of a project, regardless of what the software is. It just
          new complexities and possible issues.
          regards
          Dean
          Director Lecturer / Consultant / Director Enthusiast
          http://www.deansdirectortutorials.com/
          http://www.multimediacreative.com.au
          email: d.utian@unsw.edu.au
          • 2. Re: Change from MX_2004 to 11
            Nomi_T Level 1
            Hi Dean -
            There is mostly one file I'm working with - it's interactive(input from keyboard), and mostly plays QT clips. I worked on it to update it for a new project I'm planning - all seemed to work fine. No scripts errors, and I didn't change cast, file names etc. I also opened another older file I was working on to look at some scripts, saved and closed (that one was never changed at all).
            Next thing I know, I cannot open the program - not from the file I was working on, and not directly (double clicking the program itself). It quits JUST before the first menu - where it asks you if you want to open a new or an existing file. I get the apple "quit unexpectedly".
            Many thanks - Nomi
            • 3. Re: Change from MX_2004 to 11
              Level 7
              I started usng a new computer with Director and it also crashed and closed
              unexpectedly. I found that it was a Quicktime issue. For some reason, Director
              didn't like QT with certain compression. I'd suggest you reinstall Director and
              reinstall Quicktime. Not sure if it's the same issue as I experinced but can't hurt
              to try. I assume you've installed the 10.1 update as well as the 10.1.1 update
              right?
              regards
              Dean
              • 4. Re: Change from MX_2004 to 11
                Nomi_T Level 1
                Hi Dean - I have mx 2004 10.0 and the latest QT. Director was recently re-installed on this computer, and just did the same with QT. Any thoughts?
                • 5. Re: Change from MX_2004 to 11
                  Level 7
                  Hi Nomi,
                  If you have installed 10.0 only, then download both the 10.1 and the 10.1.1 updates and install them.
                  regards
                  Dean
                  • 6. Re: Change from MX_2004 to 11
                    Nomi_T Level 1
                    YOU ROCK!!!
                    Seems like this is working now - many, many thanks - Nomi
