11 Replies Latest reply on Oct 20, 2017 3:43 AM by Alexis Cazes Adobe
    Props and eVar
    cathyw49544988 Level 1
      I took some training classes and read some help pages and I still have question about those 2 types of variables:
      1. For Props, they mentioned that it can hold path. I am wondering is that mean it can hold the path of visitor's journey. If I use prop to hold variable like URL, page name, then I will get the navigation reports ( like landing , exit, full path, next page etc ). Is this the meaning of path?
      2. I read the document mentioned that the recent version, evar and prop are very close to each other. So for right now, which data I have to use prop, can nor use eVar? Please provide some examples
      3. for eVar, they mentioned that it is a persistence variable which can be used to hold conversion related info. The interesting thing I saw was, we tracking a search page load as an event. we used a eVar to hold the search keyword. But in the evar report, for the keyword  against visitors, then 99% are unspecified. Then I noticed that all the visits has this evar, if the user didn't visit the search page, then eVar is a null value, then showed as unspecified. Shouldn't the eVar report only include the visits load the search page?
      4. Actually I really hope I can know more about how internal of adobe worked? How the persistent worked? Then I will know how should I use my variable. For example, when a event fire, some variable and event data will be saved to adobe server. The thing is, how evar can persistently show all the data for the conversion( like first touch, last touch), do they have a special meta-data to side track? I am just thinking in a database view, how this data is joined to show the conversion report.
        • 1. Re: Props and eVar
          Alexis Cazes Adobe Level 4
          If you want to know how the data is stored and processed then the best way is for you to play with Data Feed. It is the most granular data that you can get.
          Check all the columns you can get.
          Check this section of documentation to see how the data and metrics are calculated.
          This will allow you to understand the different layers of processing: Processing Order
          Now in terms of prop and evar differences:
          • Prop
            • Expire on hit (a hit is a row in a data feed). Cannot persist further than the hit. This means that if you want to attribute an event to a prop you need to do it in the same analytics server call
            • Only has linear allocation. So all metrics (events in data feed) that you apply to a prop reports will use linear allocation
            • Pathing can be enable on any props. This means that you can see the sequential order of the values that have been sent. For best result, the prop needs to be specified in all analytics server calls. If a server call is missing the value then it will count as an exit from the path.
            • You can also use a prop as a list prop to send multiple values but I prefer to use list variables as you can assign different allocations
          • Evar
            • The expiration can be set to what you want: hit, visit, never, after x days, when a specific event is sent etc....
            • The allocation can be set to:
              • Most recent (last touch): the most recent values sent to this eVar will persist (see expiration), until expiration end or new value is set. When an eVar is set (via server call) it will be in its corresponding evar column in data feed. And the persisting value will be set in post_evar. If using processing rules then only post_evar will be set. To see instances of the evar chec post_event_list and check for corresponding numeric id of the evar.
              • First touch: the first value send via sever call will persist until expiration. Even if you send new value it will not overwrite first value sent. Reset at expiration
              • Linear: all values send via server calls will get credit for the event when sent.
            • You can also use merchandising evars. More complex and won't go in details here.
            • You can also set an evar as a counter evar.
            • More details
          5 people found this helpful
          • 2. Re: Props and eVar
            marion33678522 Level 2
            Hello Alexis !
            Congrats on the great explanations !
            I already knew all of that , but it's the first time I found a real abstract and short explanation.
            It really helps understanding the data feed before explaining props and evars.
            Cheers !
            Mario
            • 3. Re: Props and eVar
              frankd55973318 Level 1
              When I comes to a Prop and a hit level eVar, what reason is there to use an eVar instead of a prop (other than having linear/participation options)?
              Thanks.
              • 4. Re: Props and eVar
                Use props:
                • if your value is less than or equal to 100 chars. anything above will be truncated.
                • if you want pathing
                • if you only want to see linear allocation for any metrics
                • if you want to use list prop feature
                Use evar:
                • If your value is more than 100 char but less than or equal to 250 characters. Anything above will be truncated
                • If you want other allocation than linear, for example last.
                • If you want to use merchandising eVars
                • if you want to use numeric type for evars
                • if you want to modify expiration at any point to anything other than hit
                might be other use cases but only these ones come to my mind right now.
                • 5. Re: Props and eVar
                  Are you sure you can have numeric evars ?
                  It seems to me that only event can be numeric - I though they could only be counter or text.
                  For exemple, I won't be able to calculate the Mean of this :
                  Visit 1   :eVar42 = 4
                  Visit 2   : eVar42 = 5
                  Visit 3   :eVar42 = 6
                  Number of visits = 3
                  eVar42 instances = 3
                  Mean of Evar3 = (4+5+6)/3
                  Cheers,
                  Mario
                  • 6. Re: Props and eVar
                    Alexis,
                    Could you please explain more about the " linear allocation "?
                    Thanks.
                    • 7. Re: Props and eVar
                      marion33678522
                      What I meant by numeric evars is Counter evars, sorry for the misunderstanding.
                      See these articles:
                      https://webanalyticsfordevelopers.com/2014/10/21/counter-evars/
                      Counter eVars [Inside Omniture SiteCatalyst] | Adobe
                      • 8. Re: Props and eVar
                        You can find some documentation about allocation here:
                        Allocation
                        Say you have a visit with 5 pageviews, evar1 is last allocation and evar2 is linear:
                        Pages     Prop1     Evar1     Evar2     Order
                        1               a               aa          qq          0
                        2               a               bb          ww         0
                        3               b               cc          ee          0
                        4               c               dd          rr            0
                        5               d               ee          rr          0
                        6               e               ff            rr           1
                        Prop1 report
                        prop     order
                        a               1/6  + 1/6 = 2/6 = 0.333333
                        b               1/6 = 0.166667
                        c               1/6 = 0.166667
                        d               1/6 = 0.166667
                        e               1/6 = 0.166667
                        evar1     order
                        aa               0
                        bb               0
                        cc               0
                        dd               0
                        ee                0
                        ff                   1
                        evar2     order
                        qq          1/6 = 0.166667
                        ww          1/6 = 0.16667
                        ee           1/6 = 0.16667
                        rr          1/6 + 1/6 + 1/6 = 3/6 = 1/2 = 0.5
                        Linear allocation means that all values that where sent prior the event get credit for the event. Each instance of a value get 1/n where n is the number of instance of values prior event
                        2 people found this helpful
                        • 9. Re: Props and eVar
                          This linear and last allocation explanation on how evars work is great !
                          Im' gonna save it somewhere !
                          Keep the good teaching !
                          Cheers !
                          • 10. Re: Props and eVar
                            Alexis,
                            This is very helpful. I still have a very basic question. As you described:
                            1               a               aa          qq          0
                            2               a               bb          ww         0
                            3               b               cc          ee          0
                            4               c               dd          rr            0
                            5               d               ee          rr          0
                            6               e               ff            rr           1
                            In this case, we want to track event for order, you have a visit with 5 pageviews. So the order event is visit based. Is that the same as expired after a session?
                            So all the credit can be shared within this visit. I guess there must have another internal variable to track the unique visit info, correct?
                            Another question I have is, how to link Prop1, Evar1 and eVar2 with order event? From the example, we can see that the first 5 pageview without order. For example, Prop1 is URL, eVar1 is category and eVar2 is division ( something like this ), maybe we have those data from page load event. Then order event happen, in order to link the order with those 3 variables, I will need to setup those 3 variables when the order event fired. Is this correct?
                            Right now, I am trying to thinking thing like a table. Every time a rule fired, then a row  of data will be written to database. If I didn’t setup a variable within that image, then for that row, that variable will be null value. Is this correct? But for the session, visitor ID those info is tracking automatically, correct? If this is the case, then I will know each time, if I want my event to link with any variable, I will have to set up those variables in my rule.
                            • 11. Re: Props and eVar
                              Visitor ID is tracked automatically. There are different ways a unique visitor is identified. See doc for data feed
                              By default the Adobe Analytics library should generate the unique visitor, so unless you send a custom one, you should not have to do anything.
                              Any event is hit based, it does not persist after the hit. For the event to be attributed to a value for an eVar or a prop then this value needs to be set in the adobe analytics server call.
                              Prop value do not persist after the hit (after the analytics server call), so if you want the order to be attributed to this value send you need to send it in the same hit or a hit prior the order in the visit.
                              For eVar it is can be different based on the allocation and expiration.
                              If the evar is set to expire to anything other than hit, then the value set in the evar will persist until expiration. Now the value that persist is directly tied to to allocation. If it is first alllocation, then the first value set in the evar will persist until expiration and all event sent while the value persist will be attributed to it. If it is last allocation then last value that was set will persist until expiration and same as for first all events will be attributed to it.
                              I would advise you to create a new post if you need more details as I think it differs from the initial question asked.
