I've looked pretty extensively for a fix to this, but can't seem to find any other posts about it, at least with a simple Google search.
Essentially, since i updated CC a few months ago, if i rotate the canvas on a work and make a selection i can basically guarantee that the entire program with just crash and quit itself. If i try that same file again, no good; it'll crash any time i rotate the canvas. Ever. It's as if the file is 'infected'.
Has anyone experienced this?
I've tried reinstalling, restarting, going back to an earlier version, but no luck yet; perhaps it wasn't an early enough version and i should keep trying. Regardless, this is annihilating my productivity, and i'd love to not have to go back to cs6 over this.
Hi
Rotate view uses the Graphics Processor (GPU). It could be that you are hitting a bug in the driver and need to update that.
Can you go to Photoshop >Help >System Info and click copy. Then paste the info here.
Dave
Thank you! I'm afraid i don't know much about messing with the GPU, but i've the information here:
Adobe Photoshop Version: 2017.0.0 20161012.r.53 2016/10/12:23:00:00 CL 1094006 x64
Number of Launches: 1
Operating System: Mac OS 10.12.5
System architecture: Intel CPU Family:6, Model:42, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX
Physical processor count: 4
Processor speed: 2700 MHz
Built-in memory: 12288 MB
Free memory: 5001 MB
Memory available to Photoshop: 9875 MB
Memory used by Photoshop: 70 %
Alias Layers: ^0
Modifier Palette: Disabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
Display Bounds: top=0, left=0, bottom=800, right=1280
Display: 2
Display Bounds: top=0, left=-1920, bottom=1080, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=512
glgpu[0].GLName="AMD Radeon HD 6770M OpenGL Engine"
glgpu[0].GLVendor="ATI Technologies Inc."
glgpu[0].GLVendorID=4098
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="AMD Radeon HD 6770M OpenGL Engine"
glgpu[0].GLRendererID=16915206
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[3072]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[3072]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Apr 4 2017 19:07:42)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=512
clgpu[0].CLName="ATI Radeon HD 6770M"
clgpu[0].CLVendor="AMD"
clgpu[0].CLVendorID=16915200
clgpu[0].CLDriverVersion="1.2 (Apr 27 2017 22:10:56)"
clgpu[0].CLBandwidth=2.28461e+10
clgpu[0].CLCompute=64.1081
License Type: Subscription
Serial number: 90970609799863397685
GUIDBucket:
bucket: 238
test: DocumentPanel
Application folder: /Applications/Adobe Photoshop CC 2017/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 930.7G, 317.8G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2017/Plug-ins/
Installed components:
AdbePM.framework AdbePM 2.5.00.37723 1.573920
adobe_caps.framework adobe_caps 10.0.0.6 1.584361
AdobeACE.framework AdobeACE 2.20.02.37194 79.577309
AdobeAGM.framework AdobeAGM 4.30.60.37194 79.577309
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.34320 79.562390
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.34320 79.562390
AdobeBIB.framework AdobeBIB 1.2.03.37194 79.577309
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 79.577309
AdobeCoolType.framework AdobeCoolType 5.15.00.37194 79.577309
AdobeCrashReporter.framework AdobeCrashReporter 7.3.2
AdobeExtendScript.framework AdobeExtendScript 4.5.6.4 80.1060872
AdobeJP2K.framework AdobeJP2K 1.2.2.36529 79.262945
AdobeLinguistic.framework 21429
AdobeMPS.framework AdobeMPS 5.8.1.37174 79.577269
AdobeOwl.framework AdobeOwl 5.2.11
AdobePDFL.framework AdobePDFL 15.0.0.36975 79.195992
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 7.4.1.60.45263
AdobeScCore.framework AdobeScCore 4.5.6.4 80.1060872
AdobeSVGAGM.framework AdobeSVGAGM 1.0.0.37194 79.577309
AdobeSVGRE.framework AdobeSVGRE 6.0 79.577309
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 79.159824 79.159824
AdobeXMPFiles.framework AdobeXMPFiles 79.159824 79.159824
AdobeXMPScript.framework AdobeXMPScript 79.159824 79.159824
ahclient.framework ahclient 2.0.0.1
AIDE.framework AIDE 1.5.0.36540 79.574279
aif.framework aif 6.0.00.1 1.
amtlib.framework amtlib 10.0.0.47
boost_date_time.framework boost_date_time 10.0.0.0
boost_filesystem.framework boost_filesystem 10.0.0.0
boost_signals.framework boost_signals 10.0.0.0
boost_system.framework boost_system 10.0.0.0
boost_threads.framework boost_threads 10.0.0.0
Cg.framework NVIDIA Cg
CIT.framework
CITThreading.framework
dvaaudiodevice.framework dvaaudiodevice 10.0.0.0
dvacore.framework dvacore 10.0.0.0
dvamarshal.framework dvamarshal 10.0.0.0
dvamediatypes.framework dvamediatypes 10.0.0.0
dvametadata.framework dvametadata 10.0.0.0
dvametadataapi.framework dvametadataapi 10.0.0.0
dvametadataUI.framework dvametadataUI 10.0.0.0
dvaplayer.framework dvaplayer 10.0.0.0
dvatransport.framework dvatransport 10.0.0.0
dvaui.framework dvaui 10.0.0.0
dvaunittesting.framework dvaunittesting 10.0.0.0
dynamiclink.framework dynamiclink 10.0.0.0
ICUConverter.framework ICUConverter 3.61 "gtlib_6.0" "." "21287"
ICUData.framework ICUData 3.61 "gtlib_6.0" "." "21287"
ICUUnicode.framework ICUUnicode 3.61 "gtlib_6.0" "." "21287"
LogSession.framework LogSession 7.4.1.60.45263
manta.framework manta 2.0.00.1 1.
mediacoreif.framework mediacoreif 10.0.0.0
PlugPlugExternalObject.framework 7.0.0.67
PlugPlugOwl.framework PlugPlugOwl 7.0.0.67
UpdaterNotifications.framework UpdaterNotifications 10.0.0.1 "10.0.0.1"
WRServices.framework WRServices 12.0.0 12.0.0.1000
Required plug-ins:
3D Studio 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Accented Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 18.0.0, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 18.0.0 ©1993-2016 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 9.12.1 (790), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 9.12.1 (790), Copyright © 2017 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 18.0.0 ©2002-2016 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 18.0.0 ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 18.0.0 Copyright © 2003-2016 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dicom 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “dicom.plugin”
Difference Clouds 18.0.0 ©1993-2016 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 18.0.0 Copyright © 2007-2016 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Entropy 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Export Color Lookup Tables 18.0.0 Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Extrude 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 18.0.0 ©1990-2016 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Flash 3D 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Fresco 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Graphic Pen 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
HSB/HSL 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IFF Format 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
IGES 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Ink Outlines 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 18.0.0 Copyright © 2001-2016 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Kurtosis 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Lens Blur 18.0.0, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 18.0.0, Copyright © 2002-2016 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 18.0.0, Copyright © 2001-2016 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 18.0.0 ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Maximum 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Measurement Core 18.0.0 Copyright © 1993-2016 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Median 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Mezzotint 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Minimum 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
MMXCore Routines 18.0.0 ©1990-2016 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 18.0.0 Copyright © 1990-2016 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 18.0.0 ©1993-2016 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 18.0.0 ©1989-2016 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Photoshop Touch Copyright ©2013-2016 Adobe Systems Incorporated - from the file “PSDX.plugin”
Picture Package Filter 18.0.0 ©1993-2016 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 18.0.0 ©1989-2016 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PLY 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
PNG 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 18.0.0 ©1989-2016 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PRC 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Radial Blur 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 18.0.0 ©2003-2016 Adobe Systems Incorporated - from the file “Radiance.plugin”
Range 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Render Color Lookup Grid 18.0.0 Copyright ©2012-2016 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
Reticulation 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 18.0.0, Copyright © 1999-2016 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 18.0.0, Copyright © 2016 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shake Reduction 18.0.0, Copyright © 2014-2016 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
Shear 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Skewness 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Smart Blur 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 18.0.0 Copyright © 1993-2016 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spaces 18.0.0, Copyright © 2015 Adobe Systems Incorporated - from the file “Spaces.plugin”
Spatter 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Standard Deviation 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
STL 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Sumi-e 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Summation 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Targa 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
U3D 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Underpainting 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variance 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Water Paper 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 18.0.0, Copyright © 1991-2016 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 18.0.0 ©2006-2016 Adobe Systems Incorporated - from the file “U3D.plugin”
Wind 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 18.0.0 ©1989-2016 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 18.0.0, Copyright © 2003-2016 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/purchase.html”
Libraries 2.10.56 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_2_10_56/index.html”
New Document 2.0.1 - from the file “/Users/bwright/Library/Application Support/Adobe/CEP/extensions/CCX_CMDN_EXTENSION_2_0_1_001/fnft.html”
com.adobe.experimentation.extension 2.0.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.experimentation.extension/index.html”
Start 2.0.1 - from the file “/Users/bwright/Library/Application Support/Adobe/CEP/extensions/CCX_START_EXTENSION_2_0_1_044/index.html”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Export As 3.0.8 - from the file “/Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/PSPanel/dialog.html”
Device Preview 1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSPanel/panel.html”
com.adobe.preview.loader 1.3.2 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.previewHD/PSLoader/loader.html”
Installed TWAIN devices: NONE
Hi
A couple of things:
You are not using the latest version of Photoshop. The latest is CC2017.1.1 - you are still using 2017.0.0 you may wish to update.
According to the AMD site the last driver update for your GPU card was Crimson 16.2.1.No further updates were or will be issued after January 2016 However you appear to have GPU updates from 2017 so I it may be worth trying a roll back to the older driver.
AMD Radeon Software Crimson Edition 16.2.1 Beta for Non GCN Products Release Notes
The notes reference a bug where you would be notified of a further update but that update is not compatible with your card.
Also see this : Legacy
Dave
The problem with OSX and graphics adapters is that drivers are issued by Apple as part of OS updates and not the card maker. Only Windows users get to choose their drivers.
Hopefully the CC 2017 updates will solve the problem.
You have MacOS 10.12.5 and 10.12.6 is the latest I would recommend especially if you do not want to play with 10.13 High Sierra yet.
Gene
Ooops - forgot it was MAC - sorry
Slpw - please ignore those Windows driver references .
Dave
Yes, since this seemed to begin with my software update to CC, i keep wondering if there's going to be a new update that will simply solve the problem.
Let's start with the GPU. Adobe Camera Raw has a GPU function that has been known to cause problems in Photoshop, so first step is to uncheck it and restart your Mac. Uncheck "Use Graphics Processor."
If that does not solve it, you can uncheck Photoshop's Use Graphics Processor to isolate the card.
or keep the GPU checked on and tamp down the Advanced Settings to Basic.
Okay, I've done it, but unchecking the GPU option gives me the typical "Could not complete your request because it only works with OpenGL enabled document windows." error. Will next try the basic settings option.
Ok, let me know.
Sadly, neither works, unless I should restart my computer again after turning gpu back on and setting advanced settings to 'basic'. I had merely quit and restarted photoshop.
Will a crash report help?
Restart your Mac. One other trick is resetting Directory permissions.
You do this via Terminal
Copy and Paste this command into Terminal and execute it.
sudo chmod -R 777 /Library/Application\ Support/Adobe
Restart your Mac.
As for the crash report, post it. I can look at it, but I'm not very good at reading them.
Oh dear, i thought it had worked, but no good. Will next try updating my photoshop again and send a crash report if i can get one.
Process: Adobe Photoshop CC 2017 [640]
Path: /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
Identifier: com.adobe.Photoshop
Version: 18.1.1 (18.1.1.252)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe Photoshop CC 2017 [640]
User ID: 501
Date/Time: 2017-10-09 15:58:40.990 -0500
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: 474ACEF9-B5A9-900B-5F94-F325108A1B5B
Time Awake Since Boot: 750 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000114122d40
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Bus error: 10
Termination Reason: Namespace SIGNAL, Code 0xa
Terminating Process: exc handler [0]
VM Regions Near 0x114122d40:
mapped file 0000000113f1f000-000000011400f000 [ 960K] r--/rwx SM=COW
--> __TEXT 000000011400f000-000000011415b000 [ 1328K] r-x/rwx SM=COW /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
__DATA 000000011415b000-000000011416a000 [ 60K] rw-/rwx SM=COW /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 MMXCore 0x0000000111bc724a 0x111b60000 + 422474
1 com.adobe.Photoshop 0x00000001021204f7 0x1017ea000 + 9659639
2 com.adobe.Photoshop 0x00000001021341ff 0x1017ea000 + 9740799
3 com.adobe.Photoshop 0x0000000101fb17ed 0x1017ea000 + 8157165
4 com.adobe.Photoshop 0x000000010246c03a 0x1017ea000 + 13115450
5 com.adobe.Photoshop 0x00000001018af79a 0x1017ea000 + 808858
6 com.adobe.Photoshop 0x0000000101887b70 0x1017ea000 + 646000
7 com.adobe.Photoshop 0x0000000101887c39 0x1017ea000 + 646201
8 com.adobe.Photoshop 0x000000010372b78d 0x1017ea000 + 32774029
9 com.apple.Foundation 0x00007fffacdd6e0f __NSFireTimer + 83
10 com.apple.CoreFoundation 0x00007fffab32ee04 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
11 com.apple.CoreFoundation 0x00007fffab32ea93 __CFRunLoopDoTimer + 1075
12 com.apple.CoreFoundation 0x00007fffab32e5ea __CFRunLoopDoTimers + 298
13 com.apple.CoreFoundation 0x00007fffab325fc1 __CFRunLoopRun + 2081
14 com.apple.CoreFoundation 0x00007fffab325544 CFRunLoopRunSpecific + 420
15 com.apple.HIToolbox 0x00007fffaa884ebc RunCurrentEventLoopInMode + 240
16 com.apple.HIToolbox 0x00007fffaa884cf1 ReceiveNextEventCommon + 432
17 com.apple.HIToolbox 0x00007fffaa884b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
18 com.apple.AppKit 0x00007fffa8e1da54 _DPSNextEvent + 1120
19 com.apple.AppKit 0x00007fffa95997ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
20 com.adobe.Photoshop 0x000000010372a441 0x1017ea000 + 32769089
21 com.apple.AppKit 0x00007fffa8e123db -[NSApplication run] + 926
22 com.adobe.Photoshop 0x000000010372b5a2 0x1017ea000 + 32773538
23 com.adobe.Photoshop 0x000000010372c928 0x1017ea000 + 32778536
24 com.adobe.Photoshop 0x000000010188968d 0x1017ea000 + 652941
25 com.adobe.Photoshop 0x0000000101c017df 0x1017ea000 + 4290527
26 com.adobe.Photoshop 0x0000000101c01a69 0x1017ea000 + 4291177
27 libdyld.dylib 0x00007fffc0ef0235 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fffc101f44e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffc1109621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffc110907d start_wqthread + 13
Thread 2:: MPSupport Worker
0 libsystem_kernel.dylib 0x00007fffc101ebf2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fffc110a7fa _pthread_cond_wait + 712
2 MultiProcessor Support 0x0000000111caa0fb 0x111c60000 + 303355
3 MultiProcessor Support 0x0000000111caa01b 0x111c60000 + 303131
4 MultiProcessor Support 0x0000000111ccb7a6 0x111c60000 + 440230
5 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
6 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
7 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 3:: MPSupport Worker
Thread 4:: MPSupport Worker
Thread 5:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fffc101edf6 __recvfrom + 10
1 VulcanMessage5.dylib 0x000000010d0e8308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
2 VulcanMessage5.dylib 0x000000010d0e76cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
3 VulcanMessage5.dylib 0x000000010d0e69c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
4 VulcanMessage5.dylib 0x000000010d0e6888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
5 VulcanMessage5.dylib 0x000000010d0e14c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
6 VulcanMessage5.dylib 0x000000010d0e1f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
7 VulcanMessage5.dylib 0x000000010d0e18ef vcfoundation::io::Serializer::Deserialize() + 9
8 VulcanMessage5.dylib 0x000000010d0e5974 vcfoundation::ncomm::Connection::ReadIn() + 22
9 VulcanMessage5.dylib 0x000000010d0e53cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
10 VulcanMessage5.dylib 0x000000010d0e50ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
11 VulcanMessage5.dylib 0x000000010d0e500d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
12 VulcanMessage5.dylib 0x000000010d0d8848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
13 VulcanMessage5.dylib 0x000000010d0d7a86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
14 VulcanMessage5.dylib 0x000000010d0e620c vcfoundation::thread::AbstractThread::Run() + 72
15 VulcanMessage5.dylib 0x000000010d0e8109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
16 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
17 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
18 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 6:
0 libsystem_kernel.dylib 0x00007fffc1017386 semaphore_wait_trap + 10
1 libtbb.dylib 0x0000000108fce100 tbb::internal::rml::private_worker::thread_routine(void*) + 448
2 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
3 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
4 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 7:
Thread 8:
Thread 9:: BridgeTalk
0 libsystem_kernel.dylib 0x00007fffc101ef46 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fffc0fa5b72 nanosleep + 199
2 com.adobe.PSAutomate 0x00000001161a1ce8 0x115fce000 + 1916136
3 com.adobe.PSAutomate 0x0000000116183b5c 0x115fce000 + 1792860
4 com.adobe.PSAutomate 0x00000001161a1871 0x115fce000 + 1914993
Thread 10:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fffc101734a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffc1016797 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fffab326874 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fffab325cf1 __CFRunLoopRun + 1361
5 com.apple.AppKit 0x00007fffa8f6af02 _NSEventThread + 205
Thread 11:
2 com.adobe.headlights.LogSessionFramework 0x000000010c1fcccc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
3 com.adobe.headlights.LogSessionFramework 0x000000010c1fb5ef boost::this_thread::hiden::sleep_for(timespec const&) + 191
4 com.adobe.headlights.LogSessionFramework 0x000000010c1a9059 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
5 com.adobe.headlights.LogSessionFramework 0x000000010c177cfb RealTimeProcessor::WorkerThread(int, int) + 3633
6 com.adobe.headlights.LogSessionFramework 0x000000010c1fa969 boost::(anonymous namespace)::thread_proxy(void*) + 185
7 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 12:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fffaa461734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fffacd668ad __NSThread__start__ + 1243
Thread 13:
2 com.adobe.headlights.LogSessionFramework 0x000000010c1aa152 boost::condition_variable::wait_until(boost::unique_lock<boost::mutex>&, boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >) + 124
3 com.adobe.headlights.LogSessionFramework 0x000000010c1a90db void boost::this_thread::sleep_until<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > >(boost::chrono::time_point<boost::chrono::system_clock, boost::chrono::duration<long long, boost::ratio<1l, 1000000000l> > > const&) + 124
4 com.adobe.headlights.LogSessionFramework 0x000000010c1a8bae IdleTimeLogger::IdleTimeWorkerThread() + 2804
5 com.adobe.headlights.LogSessionFramework 0x000000010c1fa969 boost::(anonymous namespace)::thread_proxy(void*) + 185
Thread 14:: Update Activation Menu Items
2 com.adobe.Photoshop 0x0000000101b4d3a2 0x1017ea000 + 3552162
3 CITThreading 0x000000010968605e boost::(anonymous namespace)::thread_proxy(void*) + 130
4 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
5 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
6 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 15:
2 libc++.1.dylib 0x00007fffbfa8c4cd std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 com.adobe.Photoshop 0x00000001017ef2fd 0x1017ea000 + 21245
4 com.adobe.Photoshop 0x00000001017eff5b 0x1017ea000 + 24411
5 com.adobe.Photoshop 0x00000001017efd4e 0x1017ea000 + 23886
Thread 16:
Thread 17:
Thread 18:
Thread 19:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fffc101eeb6 __select + 10
1 com.apple.CoreFoundation 0x00007fffab361939 __CFSocketManager + 729
Thread 20:: NetworkConfigWatcher
5 com.apple.Foundation 0x00007fffacd56252 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
6 org.chromium.ContentShell.framework 0x00000001492d1eee 0x147d31000 + 22679278
7 org.chromium.ContentShell.framework 0x00000001492d172c 0x147d31000 + 22677292
8 org.chromium.ContentShell.framework 0x00000001492ea113 0x147d31000 + 22778131
9 org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
10 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
11 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
12 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
13 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 21:: DnsConfigService
0 libsystem_kernel.dylib 0x00007fffc101fd96 kevent + 10
1 org.chromium.ContentShell.framework 0x00000001493413e7 0x147d31000 + 23135207
2 org.chromium.ContentShell.framework 0x000000014933eebd 0x147d31000 + 23125693
3 org.chromium.ContentShell.framework 0x00000001492d0e2f 0x147d31000 + 22674991
4 org.chromium.ContentShell.framework 0x00000001492ea113 0x147d31000 + 22778131
5 org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
6 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
Thread 22:: WorkerPool/89863
1 libsystem_pthread.dylib 0x00007fffc110a833 _pthread_cond_wait + 769
2 org.chromium.ContentShell.framework 0x00000001492fa64b 0x147d31000 + 22845003
3 org.chromium.ContentShell.framework 0x000000014930f5d9 0x147d31000 + 22930905
4 org.chromium.ContentShell.framework 0x000000014930fb57 0x147d31000 + 22932311
5 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
Thread 23:: WorkerPool/90115
Thread 24:: Chrome_DBThread
5 org.chromium.ContentShell.framework 0x00000001492d1c4f 0x147d31000 + 22678607
6 org.chromium.ContentShell.framework 0x00000001492d172c 0x147d31000 + 22677292
7 org.chromium.ContentShell.framework 0x00000001492ea113 0x147d31000 + 22778131
8 org.chromium.ContentShell.framework 0x0000000148a07354 0x147d31000 + 13460308
9 org.chromium.ContentShell.framework 0x0000000148a074c3 0x147d31000 + 13460675
10 org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
11 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
12 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
13 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
14 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 25:: Chrome_FileThread
5 org.chromium.ContentShell.framework 0x0000000148a07384 0x147d31000 + 13460356
6 org.chromium.ContentShell.framework 0x0000000148a074d0 0x147d31000 + 13460688
7 org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
8 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
9 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
10 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
11 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 26:: Chrome_FileUserBlockingThread
8 org.chromium.ContentShell.framework 0x0000000148a073b4 0x147d31000 + 13460404
9 org.chromium.ContentShell.framework 0x0000000148a074dd 0x147d31000 + 13460701
Thread 27:: Chrome_ProcessLauncherThread
8 org.chromium.ContentShell.framework 0x0000000148a073e4 0x147d31000 + 13460452
9 org.chromium.ContentShell.framework 0x0000000148a074ea 0x147d31000 + 13460714
Thread 28:: Chrome_CacheThread
8 org.chromium.ContentShell.framework 0x0000000148a07414 0x147d31000 + 13460500
9 org.chromium.ContentShell.framework 0x0000000148a074f7 0x147d31000 + 13460727
Thread 29:: Chrome_IOThread
3 org.chromium.ContentShell.framework 0x00000001492d0e16 0x147d31000 + 22674966
5 org.chromium.ContentShell.framework 0x0000000148a07444 0x147d31000 + 13460548
6 org.chromium.ContentShell.framework 0x0000000148a07504 0x147d31000 + 13460740
Thread 30:: BrowserBlockingWorker1/101635
2 org.chromium.ContentShell.framework 0x000000014930a2cf 0x147d31000 + 22909647
3 org.chromium.ContentShell.framework 0x0000000149309976 0x147d31000 + 22907254
4 org.chromium.ContentShell.framework 0x000000014930cc5d 0x147d31000 + 22920285
Thread 31:: IndexedDB
8 org.chromium.ContentShell.framework 0x000000014930d7d2 0x147d31000 + 22923218
9 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
10 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
11 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
12 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 32:: CompositorTileWorker1/104451
2 org.chromium.ContentShell.framework 0x00000001493c0698 0x147d31000 + 23656088
3 org.chromium.ContentShell.framework 0x000000014930cc5d 0x147d31000 + 22920285
4 org.chromium.ContentShell.framework 0x00000001493092f7 0x147d31000 + 22905591
Thread 33:: AudioThread
Thread 34:: NetworkConfigWatcher
Thread 35:: Chrome_DevToolsHandlerThread
Thread 36:
5 com.apple.Foundation 0x00007ffface69eed -[NSConnection run] + 144
Thread 37:: CEPMonitorThread
5 com.apple.Foundation 0x00007fffacdfc051 -[NSConcreteTask waitUntilExit] + 213
6 com.adobe.PlugPlugOwl 0x00000001099afc4b -[HtmlEngineMonitor monitorThreadProc] + 160
7 com.apple.Foundation 0x00007fffacd668ad __NSThread__start__ + 1243
8 libsystem_pthread.dylib 0x00007fffc110993b _pthread_body + 180
9 libsystem_pthread.dylib 0x00007fffc1109887 _pthread_start + 286
10 libsystem_pthread.dylib 0x00007fffc110908d thread_start + 13
Thread 38:: General Background Service
2 com.adobe.Photoshop 0x0000000101bccfb1 0x1017ea000 + 4075441
3 com.adobe.Photoshop 0x0000000103ad681c 0x1017ea000 + 36620316
4 com.adobe.Photoshop 0x0000000103ad5cac 0x1017ea000 + 36617388
5 com.adobe.Photoshop 0x0000000103ad7ba6 0x1017ea000 + 36625318
6 CITThreading 0x000000010968605e boost::(anonymous namespace)::thread_proxy(void*) + 130
Thread 39:
Thread 40:
Thread 41:: CEPMonitorThread
Thread 42:
Thread 43:: BrowserBlockingWorker2/147511
Thread 44:: BrowserBlockingWorker3/85051
Thread 45:
2 com.apple.CoreServices.CarbonCore 0x00007fffac277984 TSWaitOnConditionTimedRelative + 147
3 com.apple.CoreServices.CarbonCore 0x00007fffac277585 TSWaitOnSemaphoreCommon + 433
4 com.apple.CoreServices.CarbonCore 0x00007fffac23fa8f AsyncFileThread(void*) + 261
Thread 46:
0 libsystem_pthread.dylib 0x00007fffc1109070 start_wqthread + 0
1 ??? 0x6e69740000000000 0 + 7956017760075513856
Thread 47:
1 ??? 0x0000000108fbb000 0 + 4445679616
Thread 48:: Font Initialization
Thread 49:: DeepFont
Thread 50:
1 ??? 0x0000700014d9fbe0 0 + 123145652141024
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000003 rbx: 0x00000000fffffcbd rcx: 0x0000000000000001 rdx: 0x0000000000000000
rdi: 0x0000000114122d40 rsi: 0x00000000000001b0 rbp: 0x00007fff5e412c30 rsp: 0x00007fff5e412988
r8: 0x0000000114122d40 r9: 0x00000000000001b0 r10: 0x0000000114122dc0 r11: 0x0000000000000000
r12: 0x00007fde4cd1bc00 r13: 0x00000000fffa7d40 r14: 0x00000000000001b0 r15: 0x00000000000001b0
rip: 0x0000000111bc724a rfl: 0x0000000000010206 cr2: 0x0000000114122d40
Logical CPU: 2
Error Code: 0x00000007
Trap Number: 14
Binary Images:
0x1017ea000 - 0x107fd7f87 +com.adobe.Photoshop (18.1.1 - 18.1.1.252) <B684F32F-915C-3BEA-B7EC-8B5F5820FAAC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/MacOS/Adobe Photoshop CC 2017
0x108fbf000 - 0x108ff6fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbb.dylib
0x10903b000 - 0x10905efe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
0x109097000 - 0x10913ffff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.5) <0AE6FE3B-AD77-3C9E-AD1B-CEE881FEF5C2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x1091a3000 - 0x109241fff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.5) <678BE576-32AB-3958-9C04-2504856330E5> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x109291000 - 0x109414ff7 +com.adobe.aif (Adobe Image Foundation Library 6.0.00.1 - 6.0.00.1) <EB941620-7550-301A-98C4-69CDB0577834> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/aif.framework/Versions/A/aif
0x109574000 - 0x1095e3ff7 +com.adobe.manta (Adobe Manta Library 2.0.00.1 - 2.0.00.1) <48E3C4F3-461F-3F9F-B83A-11BC5D103508> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/manta.framework/Versions/A/manta
0x109676000 - 0x10968ffff +CITThreading (???) <F6746740-68D1-3F47-9714-94B42B132BD9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/CITThreading.framework/Versions/A/CITThreading
0x1096ce000 - 0x1097ccff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
0x1097fa000 - 0x109900fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x109916000 - 0x109b8cff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x109e62000 - 0x109ed8fff +com.adobe.AdobeSVGAGM (1.0.0 - 1.0.0.37848) <387CF9B9-B873-35B7-8D5E-7ACB4EA61AE7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGAGM.framework/Versions/A/AdobeSVGAGM
0x109fc1000 - 0x10a06aff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x10a097000 - 0x10a09cffb org.twain.dsm (1.9.5 - 1.9.5) <870046C5-F052-3F7C-BB2B-452392CAC599> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
0x10a0a6000 - 0x10a0c4fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x10a0d8000 - 0x10a26aff7 +com.adobe.owl (AdobeOwl version 5.2.11 - 5.2.11) <CDF9E325-6035-3EF9-8E03-980CD33D6582> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x10a2b7000 - 0x10a61dff3 +com.adobe.MPS (AdobeMPS 5.8.1.37174 - 5.8.1.37174) <88508A43-6228-39B1-9377-B49EC9BBE1DE> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x10a690000 - 0x10a691ffb libCyrillicConverter.dylib (69) <D4DAFAFD-2465-3769-994B-B476E55CE85F> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x10a697000 - 0x10a6bbfff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x10a6e7000 - 0x10a9b0ffb +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <7DAE22B9-2F91-385B-B4EA-9EC75CBEE0EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x10aa25000 - 0x10ad22ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <46381E3C-77F9-3842-8A13-33BDEFA6E1D7> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x10ad74000 - 0x10ad97ff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x10ada6000 - 0x10adcaff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x10adf0000 - 0x10af1aff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x10af73000 - 0x10b0bdff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <3236E6F5-C286-3C46-AD03-9838AFE1D751> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x10b0da000 - 0x10b0f6ffb +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x10b0ff000 - 0x10b1bfff7 +com.adobe.JP2K (1.2.2 - 1.2.2.38234) <FA7EDCFB-62E7-33C2-89C9-8D745921518F> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x10b207000 - 0x10b381fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <A870682F-0A58-38CB-B15E-E983C131AC32> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x10b4db000 - 0x10ba33fef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/Cg.framework/Cg
0x10c0a4000 - 0x10c23efff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x10c319000 - 0x10d05efff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x10d077000 - 0x10d0a0ff7 +com.adobe.PDFSettings (AdobePDFSettings 1.04.0 - 1.4) <E07D101E-E47A-392A-8A44-005B49393DEC> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x10d0b9000 - 0x10d0bcfff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x10d0ca000 - 0x10d105ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x10d14f000 - 0x10d24bfff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.34320 - 3.8.0.34320) <AFDCC2CF-EF73-323E-A2FA-3034F26F97B9> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x10d2f5000 - 0x10d444ff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <CEC41C30-5517-3C8E-9998-A2F72308D548> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x10d49a000 - 0x10d594ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x10d5ac000 - 0x10d6afff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x10d6fb000 - 0x10d842fef +com.adobe.PM (AdbePM 2.5.00.377243 - 2.5.00.377243) <BA6D73F8-6235-30DA-81C9-A5CA7F54A963> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdbePM.framework/Versions/A/AdbePM
0x10d99c000 - 0x10dbbeff7 +libopencv_core.2.4.9.dylib (0) <305D6C41-9F88-3A40-97D4-DAF5BA2D46EF> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_core.2.4.9.dylib
0x10dc16000 - 0x10ddf3ff7 +libopencv_imgproc.2.4.9.dylib (0) <E5EE040B-2890-35B2-89DB-AA4DADBFDC03> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/libopencv_imgproc.2.4.9.dylib
0x10dedc000 - 0x10e16effb +com.adobe.SVGRE (AdobeSVGRE 6.0 - 6.0) <6A2AF438-1448-33BB-81F2-7058E8E3E1F2> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobeSVGRE.framework/Versions/A/AdobeSVGRE
0x10e1f0000 - 0x10e324fff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <0E2D02C2-0459-3C81-B9F4-AA5D9A2F9000> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x10e612000 - 0x10e614ffb com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1105a6000 - 0x1105c2ffb libJapaneseConverter.dylib (69) <57C00257-C544-3842-BD50-B79B239BCED5> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x1105c8000 - 0x1105eafff libKoreanConverter.dylib (69) <4CDBC2E2-E8AC-33E5-A4BF-CD0B7C757B30> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x1105f0000 - 0x1105ffffb libSimplifiedChineseConverter.dylib (69) <0047A988-B6F7-38F5-936A-EAFDE8A47490> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x110604000 - 0x110616ff3 libTraditionalChineseConverter.dylib (69) <62B80E34-CB09-360D-9CD0-959C59756869> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x110649000 - 0x110651fff +FastCore (18.1.1 - 18.1.1) <F20E2338-3B28-3C34-BB07-CE946978B58B> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
0x111b60000 - 0x111bdcfef +MMXCore (18.1.1 - 18.1.1) <A6B54ABB-D74E-39C7-A606-35B8F3FCDAF4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
0x111c60000 - 0x111cd9ff7 +MultiProcessor Support (18.1.1 - 18.1.1) <A53DC4D5-BB48-3608-94A6-6C839B409A51> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x11400f000 - 0x11415afff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/IMSLib.dylib
0x115409000 - 0x1154acff7 ColorSyncDeprecated.dylib (502.2) <FDB3BCCA-7C71-3DAA-9AB2-528E0CC60616> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x11579d000 - 0x1157e0ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x115a8e000 - 0x115a9fff7 +MeasurementCore (18.1.1 - 18.1.1) <E5DCB5F1-79E2-3B56-B4A9-6A650EE8B6B4> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/MeasurementCore
0x115abb000 - 0x115abffff libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib
0x115fce000 - 0x116403fff +com.adobe.PSAutomate (18.1.1 - 18.1.1) <54B32ED4-0367-3E12-837F-06413A5FF034> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/ScriptingSupport
0x1166f0000 - 0x1167d0ff7 +com.adobe.ps.spaces (18.1.1 - 18.1.1) <976B6154-C2DD-39C4-BF65-9A8AA2EAEB34> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Spaces.plugin/Contents/MacOS/Spaces
0x1167f8000 - 0x116836ff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x11685e000 - 0x116877ffb libexpat.1.dylib (15) <F48F1B7B-BEB4-32EE-8C5D-0370096F3864> /usr/lib/libexpat.1.dylib
0x117678000 - 0x117732ff3 com.apple.AMDRadeonX3000GLDriver (1.51.8 - 1.5.1) <A643313F-AD3F-31FD-B4A1-4F30DB3BFC71> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/AMDRadeonX3000GLDriver
0x117759000 - 0x11795ffff ATIRadeonX3000SCLib.dylib (1.51.8.1) <ADF9910B-EBC5-30A8-B2BA-CCA9AA740F2E> /System/Library/Extensions/AMDRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000SCLib.dylib
0x117c64000 - 0x117c96ff7 +com.adobe.pip (7.4.1.60.45263) <B0E15E67-5403-3159-8A4F-6D3BDB11D77C> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x117ca6000 - 0x117ce3dc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x147d31000 - 0x14d7b3faf +org.chromium.ContentShell.framework (99.77.34.5 - 34.5) <42663479-0F87-37B7-8694-E2701B2A59B6> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Required/Plug-Ins/Spaces/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
0x14e4fb000 - 0x14e524fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Photoshop CC 2017/Adobe Photoshop CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x14e536000 - 0x14e5affff com.apple.xquery (1.3.1 - 30) <031D5366-8C48-3124-93EC-3AB4A5758460> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x15574c000 - 0x15576cfff com.apple.CoreNLP (1.0 - 78.2) <B686BDA2-A162-3D70-9257-FEB0592DBD7E> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fffa5def000 - 0x7fffa6134ff7 com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fffa7966000 - 0x7fffa796affb com.apple.agl (3.3.1 - AGL-3.3.1) <752FDB92-EF67-3D04-BF40-A352BF1075CF> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fffa796b000 - 0x7fffa7b2cfff com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fffa7b2d000 - 0x7fffa7bcfff7 com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fffa7c9a000 - 0x7fffa7c9afff com.apple.Accelerate (1.11 - Accelerate 1.11) <D6A08A72-7758-3CA8-813D-105F6E313E67> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffa7c9b000 - 0x7fffa7cb2ff3 libCGInterfaces.dylib (331.5) <02E9DD16-C5CB-3482-84EF-AA6188A0D28C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffa7cb3000 - 0x7fffa82f3fe3 com.apple.vImage (8.1 - ???) <4C535C25-EF87-35BE-9BE8-D080A5C24084> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffa82f4000 - 0x7fffa84bbfef libBLAS.dylib (1185.50.4) <7AF8DB9A-E33B-30EB-8767-87AFB951E231> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffa84bc000 - 0x7fffa84d3fff libBNNS.dylib (15) <26F32264-148E-35E5-A280-CA035CB3D6F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffa84d4000 - 0x7fffa88dffff libLAPACK.dylib (1185.50.4) <51B2BABA-F736-3663-885A-65A8991D3560> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffa88e0000 - 0x7fffa88f6fff libLinearAlgebra.dylib (1185.50.4) <0EC25E70-05DC-3615-85B6-81721566CF1D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffa88f7000 - 0x7fffa88fdfff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffa88fe000 - 0x7fffa8911ff7 libSparseBLAS.dylib (1185.50.4) <0BDCF6A7-0228-3719-81C7-B6EBC7911320> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffa8912000 - 0x7fffa8a5fff7 libvDSP.dylib (600.60.1) <F46DF4CB-864D-3541-9913-60521FCBBF4A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffa8a60000 - 0x7fffa8b17fe3 libvMisc.dylib (600.60.1) <F8770D18-FD5D-31C3-9FBA-D9E39B14247A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffa8b18000 - 0x7fffa8b18fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A2FC8240-F62F-3A23-AB10-8CE6B56AF476> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffa8b19000 - 0x7fffa8b56ffb com.apple.Accounts (113 - 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fffa8b57000 - 0x7fffa8dd6ff7 com.apple.AddressBook.framework (10.0 - 1756.20) <E512B69B-8DBE-3085-95BE-750B8EFC97FD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fffa8dd7000 - 0x7fffa9bb0ff3 com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffa9bc2000 - 0x7fffa9bc2fff com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffa9bc3000 - 0x7fffa9c31ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffa9ccb000 - 0x7fffa9dfaff7 libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffa9dfb000 - 0x7fffa9e45fff libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffa9ea2000 - 0x7fffa9ed5fff libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffa9f42000 - 0x7fffa9fecff7 com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffa9fed000 - 0x7fffaa03efff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffaa03f000 - 0x7fffaa04eff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffaa04f000 - 0x7fffaa09cfff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffaa09d000 - 0x7fffaa0d8fff com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffaa0d9000 - 0x7fffaa0e4fff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffaa0e5000 - 0x7fffaa2f1ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffaa2f2000 - 0x7fffaa2f2fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffaa45b000 - 0x7fffaa835fff com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffaa84f000 - 0x7fffaa84ffff com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fffaa850000 - 0x7fffaa853fff com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fffaa854000 - 0x7fffaab5dfff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffaab5e000 - 0x7fffaab61ff7 com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fffaab62000 - 0x7fffaab67fff com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fffaab68000 - 0x7fffaabffff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffaac00000 - 0x7fffaac1afff com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fffaac1b000 - 0x7fffaac1cff3 com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fffaac1d000 - 0x7fffaac1fff7 com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fffaac20000 - 0x7fffaac26ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffaac27000 - 0x7fffaad06ffb com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fffaad07000 - 0x7fffaad07fff com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fffaae51000 - 0x7fffaaedefff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffaaedf000 - 0x7fffaaef2fff com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffaaef3000 - 0x7fffab1f2ff3 com.apple.CoreData (120 - 754.2) <0C9D9D78-758D-318F-9049-D42CC7944363> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffab1f3000 - 0x7fffab2a0ff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffab2a1000 - 0x7fffab734fff com.apple.CoreFoundation (6.9 - 1349.8) <36385A3A-60D3-32DB-BF55-C6D8931A7AA6> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffab735000 - 0x7fffabdd8ff7 com.apple.CoreGraphics (2.0 - 1070.22) <A680AD1F-F65A-3C0D-ACD5-4E5B5B8AD23A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffabdd9000 - 0x7fffac01cffb com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffac01d000 - 0x7fffac082ff7 com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fffac083000 - 0x7fffac134fff com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fffac135000 - 0x7fffac180ff7 com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fffac181000 - 0x7fffac181fff com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffac182000 - 0x7fffac1d3fff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffac1d4000 - 0x7fffac4afff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffac4b0000 - 0x7fffac4e3fff com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffac4e4000 - 0x7fffac4ecff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffac4ed000 - 0x7fffac659ff7 com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffac65a000 - 0x7fffac70affb com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffac70b000 - 0x7fffac76afff com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffac76b000 - 0x7fffac7dbfff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffac7dc000 - 0x7fffac821ff7 com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffac8aa000 - 0x7fffac9f7ffb com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffac9f8000 - 0x7fffaca2dff3 com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffaca2e000 - 0x7fffaca9fffb com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffacad2000 - 0x7fffacaddff3 com.apple.DirectoryService.Framework (10.12 - 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fffacb9d000 - 0x7fffacba2fff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffacd34000 - 0x7fffad0dafff com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffad0db000 - 0x7fffad105ff7 com.apple.GLKit (1.0 - 87) <5131A2B1-86DD-319E-9D78-A3B3D7F6DE3F> /System/Library/Frameworks/GLKit.framework/Versions/A/GLKit
0x7fffad106000 - 0x7fffad137ff7 com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffad138000 - 0x7fffad150ff7 com.apple.GameController (1.0 - 1) <DAC8C83B-7EC8-3A88-A725-E13DD905BF4F> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
0x7fffad1f7000 - 0x7fffad29afff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffad29b000 - 0x7fffad331ff7 com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffad332000 - 0x7fffad338ffb com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffad339000 - 0x7fffad38aff7 com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fffad38b000 - 0x7fffad4eeff7 com.apple.ImageIO.framework (3.3.0 - 1599.12) <7D624511-9E38-323E-86AA-A37BCECE61B0> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffad4ef000 - 0x7fffad4f3fff libGIF.dylib (1599.12) <7D9B14DA-F2A9-3803-A10D-AF7330D4CD53> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffad4f4000 - 0x7fffad5e5ff7 libJP2.dylib (1599.12) <A02ACBD4-662D-382E-A969-C6FEF3963D54> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffad5e6000 - 0x7fffad609fff libJPEG.dylib (1599.12) <10AD5A15-5891-30CF-B003-671724C49070> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffad60a000 - 0x7fffad630fff libPng.dylib (1599.12) <6782415F-2B06-34FD-ACC6-61D91FB23FCF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffad631000 - 0x7fffad633ff3 libRadiance.dylib (1599.12) <2BE02AC8-2D9A-3554-82AE-D577E9540B1B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffad634000 - 0x7fffad682ff7 libTIFF.dylib (1599.12) <845B70BE-6432-32D1-9655-6DAF0639BF9A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffad7e0000 - 0x7fffae3eafff com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fffae3eb000 - 0x7fffae404ff7 com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffae405000 - 0x7fffae43bfff com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fffae68e000 - 0x7fffae694fff com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fffae6aa000 - 0x7fffaebe3ff7 com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fffaebe4000 - 0x7fffaec3ffff com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffaec59000 - 0x7fffaf4d8fff com.apple.ModelIO (1.0 - 1) <366820F9-6795-3D93-AAF2-630D94B395E6> /System/Library/Frameworks/ModelIO.framework/Versions/A/ModelIO
0x7fffaf528000 - 0x7fffaf530fff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffaf707000 - 0x7fffaf70fff7 libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffaf8d8000 - 0x7fffaf926ff3 com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fffaf927000 - 0x7fffaf940ffb com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffaf941000 - 0x7fffaf94cff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffaf94d000 - 0x7fffaf94ffff libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffaf950000 - 0x7fffaf953ff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffaf954000 - 0x7fffaf958fff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffaf959000 - 0x7fffaf962ff7 libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffaf963000 - 0x7fffaf96efff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffaf96f000 - 0x7fffaf9abff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffaf9ac000 - 0x7fffafb22ff3 libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fffafb23000 - 0x7fffafb64ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffb04cc000 - 0x7fffb04dafff com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffb04db000 - 0x7fffb0681fff GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fffb0682000 - 0x7fffb06acfff GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fffb0749000 - 0x7fffb0890fff com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fffb0891000 - 0x7fffb0afbff7 com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fffb0afc000 - 0x7fffb0bc3fff com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fffb0bc4000 - 0x7fffb10eaff7 com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fffb10eb000 - 0x7fffb110effb com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fffb110f000 - 0x7fffb11fcfff com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fffb11fd000 - 0x7fffb11fdfff com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fffb11fe000 - 0x7fffb13fefff com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffb13ff000 - 0x7fffb1454fff com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fffb1455000 - 0x7fffb146bfff com.apple.SafariServices.framework (12604 - 12604.1.38.1.7) <88D1F7A2-5FC3-3A97-9F7D-28D5D84394B6> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fffb1966000 - 0x7fffb1c68ff7 com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffb1c69000 - 0x7fffb1cdefff com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffb1cdf000 - 0x7fffb1d08fff com.apple.securityinterface (10.0 - 55079.50.4) <C9B0E11A-362B-3C0D-8B2E-B06510BCE20A> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fffb1d09000 - 0x7fffb1d0cff3 com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffb2093000 - 0x7fffb2102ff7 com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffb2103000 - 0x7fffb24b1fff com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fffb4959000 - 0x7fffb4974ff3 com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fffb4975000 - 0x7fffb4982ff3 com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffb4983000 - 0x7fffb49a5ffb com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffb49a6000 - 0x7fffb49b5feb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffb4aa7000 - 0x7fffb4b3297f com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffb4b46000 - 0x7fffb4b61fff com.apple.aps.framework (4.0 - 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fffb4b62000 - 0x7fffb4b6affb com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fffb4b6b000 - 0x7fffb4b6eff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fffb4b6f000 - 0x7fffb4bc1fff com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fffb4bcb000 - 0x7fffb4bd2ff7 com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fffb4f65000 - 0x7fffb4fe3ff7 com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffb567f000 - 0x7fffb56a6fff com.apple.CalendarAgentLink (8.0 - 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x7fffb5c6e000 - 0x7fffb5c95ff3 com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffb5c96000 - 0x7fffb5d22ff7 com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fffb65ba000 - 0x7fffb65c3ffb com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffb668a000 - 0x7fffb66dbff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2250.11) <1324A70E-A093-3DB9-A802-07B8F4A499B5> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fffb66dc000 - 0x7fffb66fefff com.apple.contacts.ContactsPersistence (1.0 - 2250.11) <7CDEB852-B3B7-328F-9537-DFB3A58B882C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fffb6748000 - 0x7fffb6b27ff7 com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fffb6b28000 - 0x7fffb6b58fff com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fffb6bf3000 - 0x7fffb6bfbffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fffb6d0c000 - 0x7fffb6d1cfff com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffb6de1000 - 0x7fffb6df7ff3 com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fffb6dfe000 - 0x7fffb6e8effb com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fffb7057000 - 0x7fffb7087ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffb7318000 - 0x7fffb73a7ff7 com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffb73a8000 - 0x7fffb74e7fe7 com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffb74e8000 - 0x7fffb75b8ff3 com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffb7608000 - 0x7fffb766dff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffb766e000 - 0x7fffb767cff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffb76ee000 - 0x7fffb76f8ffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffb76f9000 - 0x7fffb76fdff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffb7733000 - 0x7fffb77a8ffb com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffb77e4000 - 0x7fffb7823fff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffb7824000 - 0x7fffb7935fff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffb7a78000 - 0x7fffb7a83fff com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fffb7c1d000 - 0x7fffb804eff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffb93a5000 - 0x7fffb93a5fff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffb93b2000 - 0x7fffb93bdff3 libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffb9676000 - 0x7fffb9692fff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffb96ab000 - 0x7fffb9d5dfff com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fffb9da3000 - 0x7fffb9e19ff3 com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffb9e1a000 - 0x7fffb9e2bfff com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fffba434000 - 0x7fffba43bffb com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffba43d000 - 0x7fffba451ff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffba452000 - 0x7fffba474fff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffba510000 - 0x7fffba520ff3 com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fffba55b000 - 0x7fffba712fff com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffba80e000 - 0x7fffba8d0ff3 com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fffbad82000 - 0x7fffbad85fff com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fffbb033000 - 0x7fffbb0acff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffbb210000 - 0x7fffbb21efff com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fffbb22f000 - 0x7fffbb257ff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffbb309000 - 0x7fffbb314fff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffbb761000 - 0x7fffbb763fff com.apple.OAuth (25 - 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fffbbbec000 - 0x7fffbbc2dff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffbbc70000 - 0x7fffbbc77ff3 com.apple.phonenumbers (1.1.1 - 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fffbc2da000 - 0x7fffbc314ffb com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fffbc315000 - 0x7fffbc32ffff com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffbc330000 - 0x7fffbc33fff7 com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fffbc348000 - 0x7fffbc36bff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffbd035000 - 0x7fffbd038fff com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fffbd0c7000 - 0x7fffbd154fff com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffbd155000 - 0x7fffbd174ff7 com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fffbd175000 - 0x7fffbd3eaffb com.apple.SkyLight (1.600.0 - 170.3) <02648329-DEBD-387D-A065-D62A8C0294F5> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffbd5c9000 - 0x7fffbd5d5ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffbdcc1000 - 0x7fffbdd35fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffbe174000 - 0x7fffbe17aff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffbe206000 - 0x7fffbe2ccff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffbe315000 - 0x7fffbe32aff3 com.apple.ToneKit (1.0 - 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fffbe32b000 - 0x7fffbe339ffb com.apple.ToneLibrary (1.0 - 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fffbe340000 - 0x7fffbe341fff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffbe342000 - 0x7fffbe4d2ff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffbefa1000 - 0x7fffbf061fff com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fffbf4ac000 - 0x7fffbf4b2fff com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fffbf583000 - 0x7fffbf585ffb com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffbf5b1000 - 0x7fffbf5d8ff7 com.apple.contacts.vCard (1.0 - 2250.11) <DD615DAF-AF34-3AB4-9CB4-DA0A882D59A5> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fffbf5da000 - 0x7fffbf5f5ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fffbf5f6000 - 0x7fffbf601fff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffbf693000 - 0x7fffbf694ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffbf695000 - 0x7fffbf8a8fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fffbf8c4000 - 0x7fffbf8cbfff libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
0x7fffbf8cc000 - 0x7fffbf8ccfff libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
0x7fffbf8cd000 - 0x7fffbf8d1ffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
0x7fffbf8d2000 - 0x7fffbf8d3ffb libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
0x7fffbf93f000 - 0x7fffbf96aff3 libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
0x7fffbf96b000 - 0x7fffbfa60fef libate.dylib (1.12.13) <DB9881C3-E24A-3984-91E0-77F6F13F795C> /usr/lib/libate.dylib
0x7fffbfa64000 - 0x7fffbfa64ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffbfa65000 - 0x7fffbfa75ff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffbfa76000 - 0x7fffbfa84ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fffbfa85000 - 0x7fffbfadbff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffbfadc000 - 0x7fffbfb05ff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fffbfb06000 - 0x7fffbfb16ffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffbfb17000 - 0x7fffbfb2dff7 libcompression.dylib (39) <BDAA8CC7-0BFC-36EC-9E75-58BDC15AC3B6> /usr/lib/libcompression.dylib
0x7fffbfb2e000 - 0x7fffbfb2eff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffbfb2f000 - 0x7fffbfb30ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffbfbea000 - 0x7fffbfccfff7 libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
0x7fffbfe6d000 - 0x7fffbfec0ff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
0x7fffbff14000 - 0x7fffbff1bff3 libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib
0x7fffbff3d000 - 0x7fffbff3dfff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffbff4d000 - 0x7fffbff52ff7 libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
0x7fffbff53000 - 0x7fffc0045ff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffc0046000 - 0x7fffc026bffb libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
0x7fffc0271000 - 0x7fffc0272fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffc0273000 - 0x7fffc028cffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffc028d000 - 0x7fffc02a3ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffc02a4000 - 0x7fffc054cff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fffc057f000 - 0x7fffc05f9ff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffc05fa000 - 0x7fffc09cfbc7 libobjc.A.dylib (709.1) <4DF3C25C-52C2-3F01-A3EF-0D9D53A73C1C> /usr/lib/libobjc.A.dylib
0x7fffc09d2000 - 0x7fffc09d6fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffc09d7000 - 0x7fffc0a08fff libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
0x7fffc0a25000 - 0x7fffc0a41ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffc0a42000 - 0x7fffc0a7bfff libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib
0x7fffc0a7c000 - 0x7fffc0a8effb libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
0x7fffc0a8f000 - 0x7fffc0a90ff3 libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
0x7fffc0a91000 - 0x7fffc0bd7fff libsqlite3.dylib (254.8) <058036FD-6EF3-3F9C-BF9B-2CB7A57205D7> /usr/lib/libsqlite3.dylib
0x7fffc0c33000 - 0x7fffc0c83fff libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
0x7fffc0ccc000 - 0x7fffc0cd9fff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fffc0cda000 - 0x7fffc0dc9fff libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
0x7fffc0dca000 - 0x7fffc0df3fff libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
0x7fffc0df4000 - 0x7fffc0e05ff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffc0e14000 - 0x7fffc0e18ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffc0e19000 - 0x7fffc0e23fff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
0x7fffc0e24000 - 0x7fffc0e2bfff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffc0e2c000 - 0x7fffc0e34fff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffc0e35000 - 0x7fffc0eb8fdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
0x7fffc0eb9000 - 0x7fffc0eeafff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
0x7fffc0eeb000 - 0x7fffc0ef0ffb libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
0x7fffc0ef1000 - 0x7fffc0ef1ffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffc0ef2000 - 0x7fffc0efefff libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
0x7fffc0eff000 - 0x7fffc0efffff liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
0x7fffc0f00000 - 0x7fffc0f05ff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffc0f06000 - 0x7fffc0f08ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffc0f09000 - 0x7fffc0f0affb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffc0f0b000 - 0x7fffc0f23ff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffc0f24000 - 0x7fffc0f24ff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffc0f25000 - 0x7fffc0fb2fef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fffc0fb3000 - 0x7fffc0fb6ffb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
0x7fffc0fb7000 - 0x7fffc0fbafff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffc0fbb000 - 0x7fffc0fd3fff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fffc0fd4000 - 0x7fffc0fdafff libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
0x7fffc0fdb000 - 0x7fffc1004ff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffc1005000 - 0x7fffc1027ff7 libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
0x7fffc1028000 - 0x7fffc106ffe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffc1070000 - 0x7fffc108eff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
0x7fffc108f000 - 0x7fffc10e8ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fffc10e9000 - 0x7fffc10f2ff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7fffc10f3000 - 0x7fffc10fcff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7fffc10fd000 - 0x7fffc1105fe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fffc1106000 - 0x7fffc1110ff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7fffc1111000 - 0x7fffc1114ff7 libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
0x7fffc1115000 - 0x7fffc1116ff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7fffc1117000 - 0x7fffc111effb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
0x7fffc111f000 - 0x7fffc1132ff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7fffc1133000 - 0x7fffc1138ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffc1139000 - 0x7fffc1162ff7 libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 383
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=600.5M resident=0K(0%) swapped_out_or_unallocated=600.5M(100%)
Writable regions: Total=2.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.2G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 512K 4
Activity Tracing 256K 2
CG backing stores 21.1M 18
CG image 652K 55
CoreAnimation 112K 18
CoreUI image data 1248K 14
CoreUI image file 184K 5
Foundation 28K 3
Image IO 432K 41
Kernel Alloc Once 8K 2
MALLOC 500.8M 217
MALLOC guard page 64K 13
MALLOC_LARGE (reserved) 824K 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
SQLite page cache 64K 2
STACK GUARD 56.2M 52
Stack 178.9M 60
VM_ALLOCATE 1.4G 89
__DATA 61.2M 379
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 135.0M 72
__TEXT 465.5M 348
__UNICODE 556K 2
mapped file 122.6M 44
shared memory 16.5M 26
TOTAL 3.0G 1451
TOTAL, minus reserved VM space 3.0G 1451
I am aware I am not using the latest version. This problem began when i updated CC a while back, so thinking it was a bug that came with the update and hadn't been fixed yet, i went back to an older version. No luck, unfortunately.
Should I just update again? I think the problem will remain if i do, but nothing has been gained from going backwards.
Just curious, do you have a Automatic switching graphics option in Energy Saver Preferences?
So nothing I can really pick out. This post comes close in crash report similarities. The artist was running a browser at the same time.
https://feedback.photoshop.com/photoshop_family/topics/photoshop-cc-crash-report-10-11-6
But right now I suggest submitting the crash report to Adobe: Submit a crash report for Adobe Photoshop and Lightroom
And contact Customer Care via chat. They can remotely check for problems and they are official support you are entitled to.
Gene
Sadly, it doesn't look like it.
Thank you for helping, regardless, and i will be getting in touch with Adobe, as best i can.
Sure. If they are able to resolve the case, would you let us know what you found out? Hopefully we can save the next Mac user a lot of time.
Gene
Absolutely.
