8 Replies Latest reply on Oct 14, 2017 11:26 AM by BKBK
    My coldfusion 8 could not be started properly because of some permission problems
    thaic1219697
      Dear,
      I'm try to install my coldfusion 8 by following the steps in
      Aaron West's Technology Blog: Super Guide: Installing ColdFusion 9 on CentOS Linux
      But then I'm facing with permission problem and could not start cfusion 8 properly.
      Is there any expertise can help me a look?
      Thanks.
      Last login: Mon Oct  9 08:29:39 on ttys002
      You have new mail.
      Thais-MBP:~ chuong$ ssh hai.tranthi@10.10.134.10
      hai.tranthi@10.10.134.10's password:
      Authentication failed.
      Last login: Mon Oct  9 00:10:18 2017 from ip-10-10-0-72.eu-west-1.compute.internal
             __|  __|_  )
             _|  (     /   Amazon Linux AMI
            ___|\___|___|
      https://aws.amazon.com/amazon-linux-ami/2017.03-release-notes/
      8 package(s) needed for security, out of 25 available
      Run "sudo yum update" to apply all updates.
      Amazon Linux version 2017.09 is available.
      [hai.tranthi@ip-10-10-134-10 ~]$ /opt/jrun4/bin/jrun stop cfusion &
      [1] 7528
      [hai.tranthi@ip-10-10-134-10 ~]$ Stopping cfusion server.could not stop server, either it's not running, you don't have permission to stop the server or it needs to be killed manually
      /opt/jrun4/bin/jrun stop cfusion &^C
      [1]+  Done                    /opt/jrun4/bin/jrun stop cfusion
      [hai.tranthi@ip-10-10-134-10 ~]$ sudo /opt/jrun4/bin/jrun stop cfusion &
      [1] 7541
      [hai.tranthi@ip-10-10-134-10 ~]$ sudo /opt/jrun4/bin/jrun start cfusion &
      [2] 7542
      [1]+  Stopped                 sudo /opt/jrun4/bin/jrun stop cfusion
      [hai.tranthi@ip-10-10-134-10 ~]$ cd /opt/jrun4/bin
      [2]+  Stopped                 sudo /opt/jrun4/bin/jrun start cfusion  (wd: ~)
      (wd now: /opt/jrun4/bin)
      [hai.tranthi@ip-10-10-134-10 bin]$ ls
      cf-init.sh        jikes   jrunwizard  migrate   wsconfig_jvm.config
      cf-multi-startup  jikesw  jspc        sniffer   wsdl2java
      java2wsdl         jrun    jvm.config  wsconfig  xmlscript
      [hai.tranthi@ip-10-10-134-10 bin]$ cd ..
      [hai.tranthi@ip-10-10-134-10 jrun4]$ ls
      Adobe_ColdFusion_8_InstallLog.log  jre          logs          servers
      bin                                lib          Readme.htm    uninstall
      docs                               license.txt  relnotes.htm  verity
      [hai.tranthi@ip-10-10-134-10 jrun4]$ cd servers/
      [hai.tranthi@ip-10-10-134-10 servers]$ ls
      admin  cfusion  lib  samples  template.zip
      [hai.tranthi@ip-10-10-134-10 servers]$ cd cfusion/
      [hai.tranthi@ip-10-10-134-10 cfusion]$ ls
      cfusion-ear  SERVER-INF
      [hai.tranthi@ip-10-10-134-10 cfusion]$ sudo /opt/jrun4/bin/jrun stop cfusion &
      [3] 7547
      [hai.tranthi@ip-10-10-134-10 cfusion]$ cd /opt/jrun4/bin
      [3]+  Stopped                 sudo /opt/jrun4/bin/jrun stop cfusion  (wd: /opt/jrun4/servers/cfusion)
      [hai.tranthi@ip-10-10-134-10 bin]$ ./jrun start cfusion &
      [4] 7549
      [hai.tranthi@ip-10-10-134-10 bin]$ Starting Macromedia JRun 4.0 (Build 108673), cfusion server
      10/09 10:16:26 info JRun Naming Service listening on *:2902
      10/09 10:16:26 error java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/SERVER-INF/connector.properties (Permission denied)
      [1]java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/SERVER-INF/connector.properties (Permission denied)
      at java.io.FileOutputStream.open(Native Method)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
      at jrun.servlet.session.ReplicationIdService.start(ReplicationIdService.java:81)
      at jrun.servlet.ServletEngineService.createReplicationIdService(ServletEngineService.java:14 3)
      at jrun.servlet.ServletEngineService.start(ServletEngineService.java:111)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java :93)
      at com.sun.jmx.mbeanserver.StandardMBeanIntrospector.invokeM2(StandardMBeanIntrospector.java :27)
      at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
      at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
      at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:262)
      at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerIntercepto r.java:836)
      at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:761)
      at jrunx.kernel.ServiceAdapter.invokeMethod(ServiceAdapter.java:705)
      at jrunx.kernel.JRunServiceDeployer.invokeOnServices(JRunServiceDeployer.java:460)
      at jrunx.kernel.JRunServiceDeployer.startServices(JRunServiceDeployer.java:312)
      at jrunx.kernel.JRunServiceDeployer.startLifecycle(JRunServiceDeployer.java:260)
      at jrunx.kernel.JRunServiceDeployer.deployServices(JRunServiceDeployer.java:87)
      at jrunx.kernel.DeploymentService.loadServices(DeploymentService.java:46)
      at jrunx.kernel.JRun.startServer(JRun.java:575)
      at jrunx.kernel.JRun.<init>(JRun.java:493)
      at jrunx.kernel.JRun$1.run(JRun.java:346)
      at java.security.AccessController.doPrivileged(Native Method)
      at jrunx.kernel.JRun.start(JRun.java:343)
      at jrunx.kernel.JRun.invoke(JRun.java:180)
      at jrunx.kernel.JRun.main(JRun.java:168)
      [0]javax.management.MBeanException: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/SERVER-INF/connector.properties (Permission denied)
      at com.sun.jmx.mbeanserver.MBeanIntrospector.unwrapInvocationTargetException(MBeanIntrospect or.java:283)
      at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:210)
      Caused by: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/SERVER-INF/connector.properties (Permission denied)
      ... 32 more
      java.io.FileNotFoundException: /opt/jrun4/logs/cfusion-event.log (Permission denied)
      at java.io.FileOutputStream.openAppend(Native Method)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:177)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
      at jrunx.logger.FileLogEventHandler.openFile(FileLogEventHandler.java:370)
      at jrunx.logger.FileLogEventHandler.checkForRotation(FileLogEventHandler.java:278)
      at jrunx.logger.FileLogEventHandler.logEvent(FileLogEventHandler.java:204)
      at jrunx.logger.LogEventHandler.log(LogEventHandler.java:32)
      at jrunx.logger.ThreadedLogEventHandler.processNextInQueue(ThreadedLogEventHandler.java:145)
      at jrunx.logger.ThreadedLogEventHandler.flush(ThreadedLogEventHandler.java:69)
      at jrunx.logger.ThreadedLogEventHandler.logEvent(ThreadedLogEventHandler.java:89)
      at jrunx.logger.LoggerService.log(LoggerService.java:352)
      at jrunx.logger.LoggerService.logError(LoggerService.java:155)
      at jrunx.kernel.JRunServiceDeployer.invokeOnServices(JRunServiceDeployer.java:489)
      java.lang.NullPointerException
      at java.io.File.<init>(File.java:222)
      at jrunx.logger.FileLogEventHandler.openFile(FileLogEventHandler.java:357)
      at jrunx.logger.FileLogEventHandler.checkForRotation(FileLogEventHandler.java:322)
      10/09 10:16:26 error jrun.jms.core.persistence.FailedToCreateStoreException: Initialization of file store in "/opt/jrun4/servers/cfusion/SERVER-INF/jms/db/coremq" failed.
      [1]jrun.jms.core.persistence.FailedToCreateStoreException: Initialization of file store in "/opt/jrun4/servers/cfusion/SERVER-INF/jms/db/coremq" failed.
      at jrun.jms.core.persistence.FilePersistentAdapter.setupPersistentStore(FilePersistentAdapte r.java:204)
      at jrun.jms.core.persistence.FilePersistentAdapter.setupPersistentStore(FilePersistentAdapte r.java:119)
      at jrun.jms.core.persistence.PersistenceManagerService.start(PersistenceManagerService.java: 65)
      at jrun.jms.core.JMSCoreService.start(JMSCoreService.java:122)
      at jrun.jms.adapter.JRunMQAdapter.start(JRunMQAdapter.java:171)
      at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
      at jrunx.kernel.ConfigurableServicePartition.startServices(ConfigurableServicePartition.java :196)
      at jrunx.kernel.ConfigurableServicePartition.start(ConfigurableServicePartition.java:178)
      [0]javax.management.MBeanException: jrun.jms.core.persistence.FailedToCreateStoreException: Initialization of file store in "/opt/jrun4/servers/cfusion/SERVER-INF/jms/db/coremq" failed.
      Caused by: jrun.jms.core.persistence.FailedToCreateStoreException: Initialization of file store in "/opt/jrun4/servers/cfusion/SERVER-INF/jms/db/coremq" failed.
      ... 47 more
      10/09 10:16:26 error javax.jms.JMSException: {0) connection factory for RMI transport layer does not exists.
      [1]javax.jms.JMSException: {0) connection factory for RMI transport layer does not exists.
      at jrun.jms.adapter.JRunJMSAdapter.getConnectionFactory(JRunJMSAdapter.java:246)
      at jrun.jms.wrapper.JRunMQServiceWrapper.bindDefaults(JRunMQServiceWrapper.java:48)
      at jrun.jms.wrapper.JRunMQServiceWrapper.start(JRunMQServiceWrapper.java:100)
      [0]javax.management.MBeanException: javax.jms.JMSException: {0) connection factory for RMI transport layer does not exists.
      Caused by: javax.jms.JMSException: {0) connection factory for RMI transport layer does not exists.
      ... 47 more
      10/09 10:16:26 info No JDBC data sources have been configured for this server (see jrun-resources.xml)
      at jrun.jms.wrapper.enterprise.JRunConnectionFactoryWrapper.<init>(JRunConnectionFactoryWrap per.java:106)
      at jrun.jms.wrapper.enterprise.JRunWrapperFactory.getConnectionFactoryWrapper(JRunWrapperFac tory.java:130)
      at jrun.deployment.resource.ResourceDeployer.deployJMSConnectionFactory(ResourceDeployer.jav a:178)
      at jrun.deployment.resource.ResourceDeployer.deployJMSConnectionFactories(ResourceDeployer.j ava:171)
      at jrun.deployment.resource.ResourceDeployer.start(ResourceDeployer.java:85)
      ... 32 more
      10/09 10:16:26 info JRun Web Server listening on *:8300
      10/09 10:16:26 info Deploying enterprise application "cfusion-ear" from: file:/opt/jrun4/servers/cfusion/cfusion-ear/
      10/09 10:16:26 info Deploying web application "Adobe ColdFusion 8" from: file:/opt/jrun4/servers/cfusion/cfusion-ear/
      10/09 10:16:27 INFO License Service: Flex 1.5 CF Edition enabled
      java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfform/logs/flex.log (No such file or directory)
      at flex.services.logging.FileLogEventHandler.openFile(FileLogEventHandler.java:333)
      at flex.services.logging.FileLogEventHandler.checkForRotation(FileLogEventHandler.java:252)
      at flex.services.logging.FileLogEventHandler.logEvent(FileLogEventHandler.java:178)
      at flex.services.logging.LogEventHandler.log(LogEventHandler.java:27)
      at flex.services.logging.ThreadedLogEventHandler.processNextInQueue(ThreadedLogEventHandler. java:153)
      at flex.services.logging.ThreadedLogEventHandler$ProcessQueueTask.run(ThreadedLogEventHandle r.java:125)
      at java.util.TimerThread.mainLoop(Timer.java:512)
      at java.util.TimerThread.run(Timer.java:462)
      at java.io.FileOutputStream.<init>(FileOutputStream.java:172)
      at flex.services.logging.FileLogEventHandler.checkForRotation(FileLogEventHandler.java:300)
      10/09 10:16:27 INFO Starting Flex 1.5 CF Edition
      10/09 10:16:27 user JSPServlet: init
      10/09 10:16:27 error Could not pre-load servlet: JSPServlet
      [1]java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/jsp
      at jrun.jsp.JSPEngine.setOutputDir(JSPEngine.java:233)
      at jrun.jsp.JSPEngine.<init>(JSPEngine.java:145)
      at jrun.jsp.JSPServlet.init(JSPServlet.java:62)
      at jrun.servlet.WebApplicationService.loadServlet(WebApplicationService.java:1213)
      at jrun.servlet.WebApplicationService.preloadServlets(WebApplicationService.java:793)
      at jrun.servlet.WebApplicationService.postStart(WebApplicationService.java:295)
      at jrun.ea.EnterpriseApplication.start(EnterpriseApplication.java:203)
      at jrun.deployment.DeployerService.initModules(DeployerService.java:708)
      at jrun.deployment.DeployerService.createWatchedDeployment(DeployerService.java:243)
      at jrun.deployment.DeployerService.deploy(DeployerService.java:428)
      at jrun.deployment.DeployerService.checkWatchedDirectories(DeployerService.java:179)
      at jrun.deployment.DeployerService.run(DeployerService.java:889)
      at jrunx.scheduler.SchedulerService.invokeRunnable(SchedulerService.java:230)
      at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
      at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      [0]javax.servlet.ServletException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/jsp
      10/09 10:16:27 user ColdFusionStartUpServlet: init
      10/09 10:16:27 user ColdFusionStartUpServlet: ColdFusion: Starting application services
      10/09 10:16:27 user ColdFusionStartUpServlet: ColdFusion: VM version = 10.0-b19
      log4j:ERROR /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/logs/server.log (Permission denied)
      10/09 10:16:27 Information [scheduler-8] - Starting logging...
      10/09 10:16:27 Information [scheduler-8] - Starting license...
      10/09 10:16:28 Information [scheduler-8] - Evaluation Edition enabled
      10/09 10:16:28 Fatal [scheduler-8] - Unable to store the license data in the license properties file.
      log4j:ERROR /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/logs/exception.log (Permission denied)
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize License service: coldfusion.server.ServiceException: Unable to store the license data in the license properties file.
      10/09 10:16:28 Information [scheduler-8] - Starting crypto...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Cryptograpic service: java.lang.NullPointerException
      10/09 10:16:28 Information [scheduler-8] - Starting security...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Security service: java.lang.ExceptionInInitializerError
      10/09 10:16:28 Information [scheduler-8] - Starting scheduler...
      10/09 10:16:28 Information [scheduler-8] - Starting WatchService...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize WatchService service: coldfusion.server.ServiceFactory$ServiceNotAvailableException: The '' service is not available.
      10/09 10:16:28 Information [scheduler-8] - Starting debugging...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Debugging service: java.lang.ExceptionInInitializerError
      10/09 10:16:28 Information [scheduler-8] - Starting sql...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize SQL service: coldfusion.server.ServiceRuntimeException: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/neo-drivers.xml (Permission denied)
      10/09 10:16:28 Information [scheduler-8] - Starting mail...
      10/09 10:16:28 Information [scheduler-8] - Starting runtime...
      at coldfusion.runtime.RuntimeServiceImpl.getQueueLimit(RuntimeServiceImpl.java:1699)
      at coldfusion.runtime.RuntimeServiceImpl.load(RuntimeServiceImpl.java:334)
      at coldfusion.server.jrun4.RuntimeHelper.load(RuntimeHelper.java:48)
      at coldfusion.server.ServiceBase.start(ServiceBase.java:59)
      at coldfusion.server.j2ee.CFServiceImpl.setupRuntime(CFServiceImpl.java:97)
      at coldfusion.server.CFService.start(CFService.java:491)
      at coldfusion.server.j2ee.CFStartUpServlet.startCFService(CFStartUpServlet.java:109)
      at coldfusion.server.j2ee.CFStartUpServlet.init(CFStartUpServlet.java:85)
      at javax.servlet.GenericServlet.init(GenericServlet.java:258)
      at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:94)
      at coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59)
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Runtime service: coldfusion.server.ServiceException
      10/09 10:16:28 Information [scheduler-8] - Starting cron...
      coldfusion.server.ServiceRuntimeException: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/neo-cron.xml (Permission denied)
      at coldfusion.server.ServiceBase.doSerialize(ServiceBase.java:258)
      at coldfusion.server.ServiceBase.access$100(ServiceBase.java:37)
      at coldfusion.server.ServiceBase$2.run(ServiceBase.java:204)
      at coldfusion.server.ServiceBase.serialize(ServiceBase.java:200)
      at coldfusion.scheduling.CronServiceImpl.store(CronServiceImpl.java:132)
      at coldfusion.scheduling.CronServiceImpl.updateTasks(CronServiceImpl.java:114)
      at coldfusion.scheduling.CronServiceImpl.load(CronServiceImpl.java:90)
      at coldfusion.server.CFService.setupCron(CFService.java:266)
      at coldfusion.server.CFService.start(CFService.java:497)
      Caused by: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/neo-cron.xml (Permission denied)
      at coldfusion.server.ServiceBase.doSerialize(ServiceBase.java:242)
      ... 27 more
      coldfusion.server.ServiceException: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/neo-cron.xml (Permission denied)
      at coldfusion.scheduling.CronServiceImpl.updateTasks(CronServiceImpl.java:119)
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Cron service: coldfusion.server.ServiceException: java.io.FileNotFoundException: /opt/jrun4/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/lib/neo-cron.xml (Permission denied)
      10/09 10:16:28 Information [scheduler-8] - Starting registry...
      10/09 10:16:28 Information [scheduler-8] - Starting client...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Client Storage service: coldfusion.server.ServiceFactory$ServiceNotAvailableException: The '' service is not available.
      10/09 10:16:28 Information [scheduler-8] - The metrics service is disabled for the J2EE edition
      10/09 10:16:28 Information [scheduler-8] - Starting xmlrpc...
      10/09 10:16:28 Information [scheduler-8] - Starting graphing...
      coldfusion.graph.GraphingServiceImpl$InvalidCacheDirectoryException: The specified graphing cache directory is invalid: ''.
      at coldfusion.graph.GraphingServiceImpl.setCachePath(GraphingServiceImpl.java:353)
      at coldfusion.graph.GraphingServiceImpl.load(GraphingServiceImpl.java:263)
      at coldfusion.graph.GraphingServiceImpl.start(GraphingServiceImpl.java:174)
      at coldfusion.server.CFService.setupGraphing(CFService.java:311)
      at coldfusion.server.CFService.start(CFService.java:535)
      10/09 10:16:28 Warning [scheduler-8] - Graphing service is unavailable
      10/09 10:16:28 Information [scheduler-8] - Starting verity...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Verity service: coldfusion.server.ServiceException
      10/09 10:16:28 Information [scheduler-8] - Starting archive...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Archive/Deploy service: java.lang.NoClassDefFoundError: Could not initialize class coldfusion.featurerouter.FeatureRouter
      10/09 10:16:28 Information [scheduler-8] - Starting document...
      10/09 10:16:28 Information [scheduler-8] - Starting eventgateway...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Event service: coldfusion.server.ServiceException
      10/09 10:16:28 Information [scheduler-8] - Starting FlexAssembler...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize FlexAssembler service: coldfusion.server.ServiceFactory$ServiceNotAvailableException: The '' service is not available.
      10/09 10:16:28 Information [scheduler-8] - Starting .NET...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize .NET service: coldfusion.server.ServiceFactory$ServiceNotAvailableException: The '' service is not available.
      10/09 10:16:28 Information [scheduler-8] - Starting Monitoring...
      10/09 10:16:28 Error [scheduler-8] - Unable to initialize Monitoring service: java.lang.NoClassDefFoundError: Could not initialize class coldfusion.featurerouter.FeatureRouter
      10/09 10:16:28 Information [scheduler-8] - ColdFusion started
      10/09 10:16:28 user ColdFusionStartUpServlet: ColdFusion: application services are now available
      10/09 10:16:28 user CFMxmlServlet: init
      10/09 10:16:28 user CFMxmlServlet: Macromedia Flex Build: 87315.134646
      10/09 10:16:28 INFO Macromedia Flex Build: 87315.134646
      10/09 10:16:28 Error [Thread-10] - The '' service is not available.
      at coldfusion.CfmServlet.init(CfmServlet.java:74)
      10/09 10:16:29 user failed to load: coldfusion.CfmServlet
      10/09 10:16:29 error Could not pre-load servlet: CfmServlet
      [1]java.lang.NullPointerException
      at coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:102)
      10/09 10:16:29 user CFSwfServlet: init
      10/09 10:16:29 user CFCServlet: init
      at coldfusion.xml.rpc.CFCServlet.init(CFCServlet.java:103)
      10/09 10:16:29 user failed to load: coldfusion.xml.rpc.CFCServlet
      10/09 10:16:29 error Could not pre-load servlet: CFCServlet
      10/09 10:16:29 user FlashGateway: init
      10/09 10:16:29 user MessageBrokerServlet: init
      10/09 10:16:29 user CFFormGateway: init
      10/09 10:16:29 user CFInternalServlet: init
      10/09 10:16:29 error No such binding: SessionReplicationService
      javax.naming.NameNotFoundException: No such binding: SessionReplicationService
      at jrun.naming.ContextManager.getBinding(ContextManager.java:680)
      at jrun.naming.ContextManager.getBinding(ContextManager.java:686)
      at jrun.naming.ContextManager.getObject(ContextManager.java:690)
      at jrun.naming.ContextManager.lookup(ContextManager.java:463)
      at jrun.naming.ContextManager.lookup(ContextManager.java:427)
      at jrun.naming.JRunNamingContext.lookup(JRunNamingContext.java:526)
      at jrun.naming.JRunNamingContext.lookup(JRunNamingContext.java:495)
      at jrun.naming.NamingService.lookupInServerContext(NamingService.java:952)
      at jrun.servlet.session.SessionService.start(SessionService.java:278)
      at jrun.servlet.WebApplicationService.postStart(WebApplicationService.java:299)
      10/09 10:16:29 info Deploying enterprise application "JRun 4.0 Internal J2EE Components" from: file:/opt/jrun4/lib/jrun-comp.ear
      10/09 10:16:29 info Deploying EJB "JRunSQLInvoker" from: file:/opt/jrun4/lib/jrun-comp.ear
      Server cfusion ready (startup time: 4 seconds)
