• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop cc actions not working
Community Beginner ,
Oct 09, 2017 Oct 09, 2017
Hi
I'm pretty new to photoshop. I've recently bought and downloaded Kelly Browns newborn actions. They are great but sometimes they work fine and today the have just stopped working. I'm not sure what I've done , but when I click on an action and try to apply it it just doesn't do the action. I haven't changed my settings, I'm usually in button mode and change if I need to play an action. Can anyone help please? TIA
Views
31.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
Votes
Translate
Translate
Report
Report
Community Expert ,
Actions are nothing more than recorded Photoshop Steps a sequence of using Photoshop tools.  Photoshop tools often depend on things like the be a selection to copy  something, a targets to be transform.  If a tool that depend on something is recorded into an action when that action is played if what the step depends on is not present when the step is played the action will fail with an error message like the command is not available or may not be supported in this version of   Photoshop.    So if you play a action on a document that does not  meet so requirement the action depend on the action will fail.  For example if an Action select the background layer and the current document does not have a background layer the action will fail.   It is very easy to find out why an action fails. All to need do is expand the action so you can see the Photoshop steps in the action. Highlight the First step. Press and hold the Ctrl or Mac CMD key. Keep that key pressed and Click on the Play button every time you Click play the step highlighted will play and you will see what it does. and the next sep will be highlighted.  You can single step the through the action see each step and why a step fails.
JJMack
Votes
Translate
Translate
Report
Report
Thanks for your response, it doesn't seem to be helping. some of my actions work and some just aren't responding when I apply them
Votes
Translate
Translate
Report
Report
Community Expert ,
single step them.
JJMack
Votes
Translate
Translate
Report
Report
Mar 19, 2024 Mar 19, 2024
LATEST
Seven years later and this "step method," helped me with an action I hadn't used in years and wasn't working in PhotoShop 2023. I stepped through it and found one step using a pencil instead of a brush. I fixed it manually, even though I would never have known how to execute the entire action on my own. Stitching action. It worked!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 19, 2018 Mar 19, 2018
I've just restarted my photoshop and make new action below default actions. it's worked for me.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 17, 2019 Nov 17, 2019
Hi!
Did you ever figure out how to fix the issue? I am having the same problem with Kelly Brown's actions for days. Been trying everything. Did this to me before, but I don't remember what I did that fixed it.
Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 18, 2020 Jan 18, 2020
I am curious also as I am having issues as well. Let me know if you figure it out.
Tammy
Votes
Translate
Translate
Report
Report
Community Expert ,
If you are still have trouble, try this so we can help you:
  • Close the document where the action failed without saving it. This will clear the History.
  • Open the document again and play the action. It should fail again.
Send us these screen shots. Resize the panels wide enough that we can read them and tall enough that they include everything (or take more than one). We need to see:
  • The History panel
  • The Layers panel
  • The Action panel — click the arrow to expand the action so we can see all of the steps in the action
~ Jane
Votes
Translate
Translate
Report
Report
New Here ,
Jan 19, 2020 Jan 19, 2020
I have took screenshots of the reqested info. Do I email customer support, or post them here? Thank you for your help.
Votes
Translate
Translate
Report
Report
New Here ,
I just fixed it. I realized I was making a copy of the background to work with first and this was preventing certain actions from working. I initiated an action on the background layer itself and it worked properly. Thank you!!!
Votes
Translate
Translate
Report
Report
