• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
applyDevelopSettings fails: ?:0: attempt to call up value '?' (a nil value)
Community Beginner ,
Oct 09, 2017 Oct 09, 2017
I am trying to write a first Lightroom plugin to automatically crop and rotate images.  I should be able to work out the crop settings (assuming I can translate to LR values later, and avoid limitations on setting crop values from the SDK), but I'm getting stuck at a more basic level applying any develop adjustment at all to any image.  Being new to LUA does not help
Whether I use something like photo:applyDevelopSettings({Exposure = 0.1}) or LrDevelopController.setValue("CropAngle", "0.1"), in both cases this fails with:
Am I missing something in the way this call is formatted?  Or do I need a full set of settings from getDevelopSettings(), or a preset or something else?  In case it makes a difference, the target photos do not have any existing develop settings beyond import.
My full plugin that fails:
-- Access the Lightroom SDK namespaces.
local LrApplication       = import 'LrApplication'
local LrDevelopController = import 'LrDevelopController'
local LrTasks             = import 'LrTasks'
local LrDialogs           = import 'LrDialogs'
function MyPluginTopLevel()
  -- Main top level callback
  LrTasks.startAsyncTask(MyPluginTask, "MyPlugin main task")
end
function MyPluginTask()
  local catalog = LrApplication.activeCatalog()
  catalog:withWriteAccessDo("MyPlugin test", MyPluginApplyParams, {timeout = 10})
end
local function MyPluginApplyParams(context)
  local selectedPhoto  = catalog:getTargetPhoto()
  if (selectedPhoto == nil) then
      LrDialogs.message( "Error: cannot get selected photo", nil, "info" );
      return nil
  else
     -- EITHER OF THESE TWO NEXT LINES FAILS:
     -- LrDevelopController.setValue("CropAngle", "0.1")
     selectedPhoto:applyDevelopSettings({CropAngle = "0.1"})
  end
end
-- Call top level:
MyPluginTopLevel()
TOPICS
SDK
Views
678
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Oct 10, 2017 Oct 10, 2017
Also, when this line is executed:
MyPluginApplyParams hasn't been defined yet.  You can move the definition of that function up above where it's called.  Or if you prefer top-down definitions (as I do), you can use this idiom for declaring forward references:
local MyPluginApplyParams -- forward reference
en
Votes
Translate
Translate
LEGEND ,
The value of CropAngle needs to be a number, e.g.
selectedPhoto:applyDevelopSettings({CropAngle = 10})
Also, you might consider using my Debugging Toolkit -- it will take about 45 mins to get up to speed using it, but it will save you a lot of grief down the road.
Votes
Translate
Translate
Report
Report
LEGEND ,
end
  catalog:withWriteAccessDo("MyPlugin test", MyPluginApplyParams) {timeout = 10})
end
Votes
Translate
Translate
Report
Report
LEGEND ,
Scratch my last reply -- I'm up way past my bedtime.  Because you used global variables for your functions, it doesn't matter which order you define them in. It's only if you define them as local variables that you need to declare the forward references.
Votes
Translate
Translate
Report
Report
John - thanks for the replies.  I had already tried using numbers for the parameters rather than "0.1", so this was not the issue.
Instead it was your second guess "local function" issue.  When I changed "local function MyPluginApplyParams(context)" to remove "local" it now works.  Thanks!
I will check out the debug toolkit later.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
I just confirmed with testing that CropAngle requires a number, silently ignoring string values.
Perhaps what happened in your testing is that through repeated loads of different versions of your file, you got inconsistent versions of the functions, adding to the confusion.   It's one reason to use local functions rather than global.
Votes
Translate
Translate
Report
Report
