• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
slider blur
Advocate ,
Oct 10, 2017 Oct 10, 2017
I have some trouble with this little script
The problem is that if I put blur at 10 and then return to 0
it does not take the blur
where is wrong?
var box = new Window('dialog', "blur");
box.panel = box.add('panel', undefined, "Gaussian Blur");
box.panel.group = box.panel.add('group', undefined );
box.panel.group.orientation='row';
box.panel.group.text1 = box.panel.group.add('statictext', undefined, "radius:");
var slider = box.panel.group.add("slider",undefined, 0, 0, 255);
var value = box.panel.group.add('edittext', undefined, "0");
box.panel.group2 = box.panel.add('group', undefined );
box.panel.group2.orientation='row';
box.panel.group2.okBtn = box.panel.group2.add('button',undefined, "ok", {name:'ok'});
box.panel.group2.closeBtn = box.panel.group2.add('button',undefined, "cancel", {name:'cancel'});
slider.onChanging = function () {
value.text = slider.value;
var r = value.text;
blur(r);
app.refresh();
value.onChanging = function () {
slider.value = value.text;
var r = slider.value;
blur(r);
app.refresh();
box.panel.group2.okBtn.onClick = function(){
  slider.onChanging();
  box.close();
box.panel.group2.closeBtn.onClick = function(){
  box.close();
box.center();
box.show()
function  blur(r){
var idGsnB = charIDToTypeID( "GsnB" );
    var desc14 = new ActionDescriptor();
    var idRds = charIDToTypeID( "Rds " );
    var idPxl = charIDToTypeID( "#Pxl" );
    desc14.putUnitDouble( idRds, idPxl, r );
executeAction( idGsnB, desc14, DialogModes.NO );
TOPICS
Actions and scripting
Views
1.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
People's Champ , Mar 18, 2018 Mar 18, 2018
Try this code
var curr_blur = 0
with (box.add('panel', undefined, "Gaussian Blur"))
    with (add('group'))
        orientation='row';
        var slider = add("slider",undefined, 0, 0, 255);
        slider.preferredSize.width = 256;
        var value = add('edittext', undefined, curr_blur);
        value.preferredSize.width = 40;
    with (add('group'))
        orientatio
Votes
Translate
Translate
Adobe
Community Expert ,
You do not seem to have included any undo or return to a history state, so what do you expect?
Votes
Translate
Translate
Report
Report
Community Expert ,
When creating a dialog that is supposed to work on an image while still being open one needs to keep in mind whether the operations have an accumulative effect and act accordingly; but also keep in mind that if the dialog gets canceled the operations may be expected to get undone.
Votes
Translate
Translate
Report
Report
Advocate ,
Oct 11, 2017 Oct 11, 2017
Thanks for the answers
I tried adding historystate and improved a bit
but it is not good yet?
var doc = app.activeDocument;
var lay = doc.activeLayer;
var currentStatus = doc.activeHistoryState;
doc.activeHistoryState = currentStatus;
var r = value.text;
blur(r);
app.refresh();
blur(r);
app.refresh();
  box.close();
  box.close();
box.center();
box.show()
function  blur(r){
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 12, 2017 Oct 12, 2017
How so?
Do you mean that you have not included a return to the history state at cancelling?
Votes
Translate
Translate
Report
Report
Community Expert ,
If you catch the result of
box.show()
as a variable you can use that to determine if »OK« or »Cancel« were clicked and have the Script proceed accordingly.
Votes
Translate
Translate
Report
Report
Engaged ,
See also Slider color balance! as an example of a similar issue, i.e. dealing with cumulative effects.
Davide Barranca - PS developer and author
www.ps-scripting.com
Votes
Translate
Translate
Report
Report
LEGEND ,
Mar 17, 2018 Mar 17, 2018
According to your first code put in line 16th:
function ahS() {
    aD.activeHistoryState = (hS = (aD = activeDocument).historyStates)[hS.length - 2]
while between lines 17 & 18 and 35 & 36:
ahS()
Votes
Translate
Translate
Report
Report
Advocate ,
It's not good for me
maybe I put your scripts wrong
can you place them in the starting script?
Votes
Translate
Translate
Report
Report
LEGEND ,
function ahS() {
     ahS()
     ahS()
     box.close();
You may also put ahS() inside value.onChanging = function()
Votes
Translate
Translate
Report
Report
Advocate ,
I tried it but it does not work
function ahS() {
     ahS()
var r = value.text;
blur(r);
app.refresh();
    ahS()
blur(r);
app.refresh();
  box.close();
     ahS()
  box.close();
box.center();
box.show()
function  blur(r){
Votes
Translate
Translate
Report
Report
LEGEND ,
I copied this code you just pasted and tried it in CS6 EXTENDED and CC2018 (19.1.2) - in both versions that worked very well.
Votes
Translate
Translate
Report
Report
Advocate ,
I use mac with high sierra
maybe this is the problem?
Votes
Translate
Translate
Report
Report
LEGEND ,
That has no sense, as with your first script when I changed blur to 10 and then back to 0, then blur level was still at 10 level.
With modified by me script now when you put pointer at 10 and again at 0, then blur effect is reverted, so the blur level is 0.
I guess I know what you want but there's mistake in your question. That should be logically asked: 'it does not take the blur'
It might be because of 'high sierra' - Many people reported some bugs about at: Photoshop Family Customer Community
Votes
Translate
Translate
Report
Report
People's Champ ,
del
Votes
Translate
Translate
Report
Report
LEGEND ,
I tested it, there was lack of one line:
currentStatus = (doc = activeDocument).activeHistoryState;
.activeHistoryState; var active = false
     if (active) return
     active = true
     var r = value.text
     blur(r)
     app.refresh()
     active = false
Edit: I didn't see you deleted it meantime, should I delete it too?
Votes
Translate
Translate
Report
Report
People's Champ ,
There everything does not work right. Maybe later I'll see what I can do.
Votes
Translate
Translate
Report
Report
People's Champ ,
LATEST
Try this code
var curr_blur = 0
    with (add('group'))
        orientation='row';
    with (add('group'))
        orientation='row';
        spacing = 70;
        var okBtn = add('button',undefined, "ok", {name:'ok'});
        okBtn.preferredSize.width = 100;
        var closeBtn = add('button',undefined, "cancel", {name:'cancel'});
        closeBtn.preferredSize.width = 100;
var ok = false;
slider.onChange = function ()
    value.text = slider.value.toFixed(0);
    value.onChanging();
    var n = Number(value.text);
    if (isNaN(n)) { beep(); return; }
    curr_blur = n;
    slider.value = curr_blur;
    box.opacity = 0.7;
    blur(curr_blur);
    app.refresh();
    box.opacity = 1.0;
    ok = true;
    box.close();
    box.close();
function key_handle(e) // in CC2018 does not work correctly, may not be use
    if (!value.active) return;
    switch (e.keyIdentifier)
        case "U+0030":
        case "U+0031":
        case "U+0032":
        case "U+0033":
        case "U+0034":
        case "U+0035":
        case "U+0036":
        case "U+0037":
        case "U+0038":
        case "U+0039":
        case "U+002E":
        case "U+0008":
        case "U+001B":
        case "U+007F":
            return;
        default:
            //alert(e.keyIdentifier)
            e.preventDefault();
            beep();
            return;
box.addEventListener ("keydown", key_handle, false); // in CC2018 does not work correctly, may not be use
box.center();
box.show()
if (!ok) doc.activeHistoryState = currentStatus;
function  blur(r){
Votes
Translate
Translate
Report
Report
