5 Replies Latest reply on Oct 11, 2017 7:08 AM by kglad
    How do you use the combobox component to...
    montana321 Level 1
      ...jump to frame labels based on what the user selects in the combobox dropdown component.
      Found the "combobox selection change event" code snippet but am at a loss with what to put inside the brackets.
      Also, I'm noticing a weird quirk with the combox on the stage.  When I first select a value, it works fine, drops down like you'd expect.   However when I select any value other than the top one, the combobox with drop up, meaning that the options will open up above the combobox.  Not sure if this is a bug or if I'm missing something. here.
