4 Replies Latest reply on Oct 11, 2017 4:00 AM by alayg1067145
    Getting Started Assignment 8-10
    alayg1067145
      Just recently I started this tutorial for CFML. Going through this course was pretty straightforward and almost without a hassle. But now I have hit a brick wall at using coldfusion components. I followed the instructions in the video and the assignment but I stumble upon this error and cant figure out what is going wrong.
      As I am adding the references to the different functions in the component i stumble upon an error. The reference to the getNewsYears function is at the top of my code(as the assignments says). But the output is somewhere at the bottom. The Error below keeps popping up.
      I cannot find any info on frequent mistakes made during the tutorial. Can anybody see what I am doing wrong?
        • 1. Re: Getting Started Assignment 8-10
          haxtbh Level 4
          This seems like a spelling mistake. You will need to show your code though so we can see.
          This normally means the rsNewsYears does not exists. Check the name you gave the query further up the code.
          • 2. Re: Getting Started Assignment 8-10
            alayg1067145 Level 1
            Hi thanks for your reaction! I tried looking for spelling errors but didnt find anything.
            This is the news.cfm code
            <!---Instance newsService--->
            <cfset newsService = createObject('component', 'cfTraining.components.newsService') />
            <!---Get news years--->
            <cfset rsNewYears = newsService.getNewsYears()/>
            <cfmodule template="customTags/front.cfm" title="HD street band - News" >
              <div id="pageBody">
                <div id="calendarContent">
                <cfif isDefined('url.newsID') >
                <!---Output of a single news article--->
                <cfset rsSingleNews = newsService.getNewsByID(url.newsID) />
                <cfoutput>
                <h1>#rsSingleNews.FLD_NEWSTITLE#</h1>
                <p class ="metadata"> Published on #dateformat(rsSingleNews.FLD_NEWSCREATIONDATE, 'mmm dd yyyy')#
                by #rsSingleNews.FLD_USERFIRSTNAME# #rsSingleNews.FLD_USERLASTNAME#</p>
                #rsSingleNews.FLD_NEWSCONTENT#
                </cfoutput>
                <cfelseif isDefined('url.year')>
            <cfset rsNewsOfYear = newsService.getNewsForYear(url.year) />
            <h1> All the news of year<cfoutput > #url.year#</cfoutput></h1>
                  <table>
                  <!---Output  news in a table--->
                  <cfoutput query="rsNewsOfYear" >
                  <tr>
                  <td>#dateFormat(FLD_NEWSCREATIONDATE,'mm dd yyyy')#</td>
                  <td>#FLD_NEWSTITLE#</td>
                  <td><a href= "news.cfm?newsID=#FLD_NEWSID#">Read More</a>></td>
                  </tr>
                  </cfoutput>
                  </table>
                <cfelse>
            <!---Get all news--->
            <cfset rsAllNews = newsService.getLatestNews()/>
              <h1> News</h1>
              <table>
                <cfoutput query="rsAllNews">
                  <tr>
                  <td>#dateFormat(FLD_NEWSCREATIONDATE, 'mmm dd yyyy')#</td>
                  <td><a href="news.cfm?newsID=#FLD_NEWSID#">Read More</a></td>
                  </tr>
                </cfoutput>
              </table>
              </cfif>
            </div>
            <div id="calendarSideBar">
            <h1>News archive</h1>
              <ul>
                <cfoutput query="rsNewsYears" group="fld_newsYear" >
                  <li><a href="news.cfm?year=#fld_newsYear#">#fld_newsYear#</a></li>
                </cfoutput>
              </ul>
              <p class="alignRight"> </p>
            </div>
              </div>
            </cfmodule>
            This is the newsService.cfc
            <cfcomponent output="false">
            <!---getNewsForYear()method --->
            <cffunction name="getNewsForYear" access="public" output="false" returntype="query">
            <cfargument name="year" type="numeric" required="true" />
            <cfset var rsNewsOfYear = ''/>
            <cfquery datasource= "hdStreet" name= "rsNewsOfYear">
                SELECT FLD_NEWSTITLE, FLD_NEWSCREATIONDATE, FLD_NEWSID
                FROM TBL_NEWS
                WHERE YEAR(FLD_NEWSCREATIONDATE) = #arguments.year#
                ORDER BY FLD_NEWSCREATIONDATE DESC
                </cfquery>
                <cfreturn rsNewOfYear/>
            </cffunction>
            <!---getNewsByID()method --->
            <cffunction name="getNewsByID" access="public" output="false" returntype="query">
            <cfargument name="newsID" type="numeric" required="true" />
            <cfset var rsSingleNews = ''/>
            <cfquery  datasource= "hdStreet" name= "rsSingleNews">
                SELECT TBL_NEWS.FLD_NEWSID, TBL_NEWS.FLD_NEWSCONTENT, TBL_NEWS.FLD_NEWSTITLE, TBL_NEWS.FLD_NEWSCREATIONDATE, TBL_USERS.FLD_USERFIRSTNAME, TBL_USERS.FLD_USERLASTNAME
                FROM TBL_NEWS INNER JOIN TBL_USERS ON TBL_NEWS.FLD_NEWSAUTHOR = TBL_USERS.FLD_USERID
                WHERE FLD_NEWSID = #arguments.newsID#
                </cfquery>
                <cfreturn rsSingleNews/>
            </cffunction>
            <!---getLatestNews()method --->
            <cffunction name="getLatestNews" access="public" output="false" returntype="query">
            <cfset var rsAllNews = ''/>
            <cfquery datasource = "hdStreet" name ="rsAllNews" >
            FROM TBL_NEWS
            </cfquery>
            <cfreturn rsAllNews/>
            </cffunction>
            <!---getNewsYears()method --->
            <cffunction name="getNewsYears" access="public" output = "false" returntype="query">
            <cfset var rsNewsYears = ''/>
            <cfquery  datasource= "hdStreet" name= "rsNewsYears" >
            SELECT YEAR (TBL_NEWS.FLD_NEWSCREATIONDATE) AS fld_newsYear
            FROM TBL_NEWS
            ORDER BY TBL_NEWS.FLD_NEWSCREATIONDATE DESC
            </cfquery>
            <cfreturn rsNewsYears/>
            </cffunction>
            </cfcomponent>
            • 3. Re: Getting Started Assignment 8-10
              haxtbh Level 4
              The only place you have defined this before is further up but its a different spelling - rsNewYears is not rsNewsYears as you are using on the error line
              • 4. Re: Getting Started Assignment 8-10
                Hahaha that did the trick. I dont know how I missed it. Thanks a bunch!
